FREE DOWNLOAD: 86-89 Pathy Vehicle Security System
  • 4 months later...
OK I tried arming the system as described (turn ignition to ON, turn alarm on, turn ignition off, shut doors and wait 30 seconds), the LED didn't flash. After 50 seconds I shook the car jumped up and down on the bumper and nothing. Opened the door and didn't stick the key in the ignition and waited fifteen seconds, nothing. Does the engine have to be running when you turn the alarm switch to on? The manual says that you can't disarm the system completely so what gives?! pssd
Dude, if it doesn't work, it doesn't work. Someone may have pulled the fuse for it or clipped the wires. You're going to have to remove your driver's side seat and get in there to see for yourself.
  • 4 years later...
  • 2 years later...
  • 2 years later...
  • 1 year later...
  • 1 month later...
Take a look at the PDFs in this thread: http://www.nissanpathfinders.net/forum/topic/19755-fix-your-keyless-entry/?p=339766
It's labeled for 1990 models, but it should be similar for 87-89. (For the 90s, it's not actually keyless entry. It's really just for the security system that had the on/off switch on the dash.)
Best of luck. :aok:
Edited by xterra
