dfather99 Posted November 19, 2004 Share Posted November 19, 2004 what is a good entry level air intake, that is both cheap (less a 175 bucks), easy to install and give improvements i can feel, or should i just start up with just a K&N filter if so what width and what size etc. -alcohol- Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 19, 2004 Share Posted November 19, 2004 A generic 3" cone filter and a MAF adapter would be a good start. A stock replacement K&N filter is a bit easier, though. Link to comment Share on other sites More sharing options...
statikuz Posted November 19, 2004 Share Posted November 19, 2004 http://www.jimbennett.net/k__n_installation.htm Search around on the forums for more about this. A drop-in K&N panel filter is a good step too. There aren't any real replacement intakes for our trucks like there are in the import world. =) The JWT popcharger is another option I hear. Search around for that too. Link to comment Share on other sites More sharing options...
dr.cyber Posted November 19, 2004 Share Posted November 19, 2004 I put on the K&N cone filter with a machined "holder" that attaches directly to the intake after you remove the Filter Box. After the ECU got used to it (about a week) I now get a nice "pop" off the line I didn't have before with some added juice to the HP. Sorry I can't remember the name of the company, but found them after researching K&N's for pathfinders. Mine is a 95. Happy hunting. PS: about 100 bucks, all included, took about 30 minutes to tear out the box and put this in. Link to comment Share on other sites More sharing options...
dfather99 Posted November 19, 2004 Author Share Posted November 19, 2004 where do i fine a MAF adapter Link to comment Share on other sites More sharing options...
statikuz Posted November 20, 2004 Share Posted November 20, 2004 Search. http://npora.ipbhost.com/index.php?showtop...=intake+adapter Link to comment Share on other sites More sharing options...
Precise1 Posted November 20, 2004 Share Posted November 20, 2004 I plan to put on a cone filter very soon, and I will make my own aluminum adapter plate. If you take some measurements I'll make you a nice one pretty cheap... Let me know. Bernard Link to comment Share on other sites More sharing options...
dfather99 Posted November 20, 2004 Author Share Posted November 20, 2004 Hey thanks guys for all the help. The fuel line job looks easy enough but i know i would mess up in a heartbeat. turns out ebay has a cheapo cone filter that comes with an adapter for the Pathfinder, so i'll do that and if the filter is a joke at least i still have the adapter. But thanks all for the help i appreciate it and thanks Precise1 for the offer, I might still need it though if this ebay one is a joke. Link to comment Share on other sites More sharing options...
dfather99 Posted December 1, 2004 Author Share Posted December 1, 2004 precise1 is that offer for the MAF adapter this on the table let me know b/c the once i got off ebay is a dud so i dono what measurements you'll need i mean it should be the same as your pathy if it's a 90-95. thanks -alcohol- Link to comment Share on other sites More sharing options...
dfather99 Posted December 2, 2004 Author Share Posted December 2, 2004 does any one know the measurments off the top of their head i need them to be able to fabricate an adapter it would be awsome if you know them Link to comment Share on other sites More sharing options...
statikuz Posted December 2, 2004 Share Posted December 2, 2004 I haven't had any problems with doing it the way it talks about on the MrJim site, using the gold plate out of your stock airbox and sealing it all up with some fuel hose. You should be able to find a adapter that fits though. If you are going to fab one up, all you need to do is take the measurements yourself, all you'd need is the bolt hole pattern, and the inlet would depend on the size of the filter that you bought. Link to comment Share on other sites More sharing options...
mudfinder Posted December 2, 2004 Share Posted December 2, 2004 i just recently put in the K&N replacement airfilter and boy it runs so much better, it used to bog, the acceleration totally sucked, but now, it kicks hiney. and the filter is about 50 bucks and installation is about 10secs. that's the easy route. Link to comment Share on other sites More sharing options...
GrimGreg Posted December 2, 2004 Share Posted December 2, 2004 One thing I saw and thought about trying was an intake for a Maxima of the same year. It looked like the tube for between the MAF and TB had all the right outputs for vacuum lines and such that our's have. Anyone tried that route? Link to comment Share on other sites More sharing options...
Guest tank93 Posted December 8, 2004 Share Posted December 8, 2004 I have a 99 Maxima and a 93 pathy, I know they are differnet, but I will look into my short ram intake on my max bolting to the pathy. If the vacum lines are similar, it could work. My intake is a frankencar unit w/K&N, and an aluminum mid-pipe. Link to comment Share on other sites More sharing options...
GrimGreg Posted December 8, 2004 Share Posted December 8, 2004 I have a 99 Maxima and a 93 pathy, I know they are differnet, but I will look into my short ram intake on my max bolting to the pathy. If the vacum lines are similar, it could work. My intake is a frankencar unit w/K&N, and an aluminum mid-pipe. Cool, let us know. Like I said I almost bought a system for a Maxima off E-bay because it looked like it would work, but didn't want to wind up with a useless intake lying around. Link to comment Share on other sites More sharing options...
Guest brendone Posted December 8, 2004 Share Posted December 8, 2004 Search E-Bay for "Pathfinder intake". Lots of cones w/ adapter cheap. I bought the same thing from the dealer for ~$50. Thinking about switching back to the stock airbox with a drop in K&N. I don't mind the extra growl when I hit the gas, but there's also a squeal that's more apparent with the box off (typical with others that have switched to a cone). Link to comment Share on other sites More sharing options...
Adelard of Bath Posted December 10, 2004 Share Posted December 10, 2004 I see at Walmart that Fram has a new thing called "airhog" it seems to be basically a K&N filter, washable, blah blah blah. I think it was $46, I didn't buy it, but it looked pretty nice Link to comment Share on other sites More sharing options...
Mr. Pickles Posted December 14, 2004 Share Posted December 14, 2004 I see at Walmart that Fram has a new thing called "airhog" it seems to be basically a K&N filter, washable, blah blah blah. I think it was $46, I didn't buy it, but it looked pretty nice Why buy a Fram knock off of a K&N when you can buy a K&N for the same price? :secret: Link to comment Share on other sites More sharing options...
Adelard of Bath Posted December 15, 2004 Share Posted December 15, 2004 Maybe someday I will want one, and I will be at walmart, and I won't have to make a special trip to checkers or autozone? both of which I avoid and all costs. I DID have to break down and go there the other day for some fuel line tho dammit cuz I just can't find that at a normal store. Walmart should start carrying that stuff hee hee they USED TO have 1/8" vacuum line on the shelf above the windshield wipers, it was officially for your washer fluid but it was also vacuum line Link to comment Share on other sites More sharing options...
Mr. Pickles Posted December 15, 2004 Share Posted December 15, 2004 Its a sad state of affairs when people start calling Walmart a "normal" store. More like a venom sucking giant or pariah according to the local west coast folks. That or a communal post for middle America to unite. I'm not overly knocking, as I shop there as well for household things and such. But a comparison of Walmart shopping as "normal" is like calling McDonalds dining a culinary treat. Guess its a midwest thing though. Link to comment Share on other sites More sharing options...
MaritimeMan Posted December 15, 2004 Share Posted December 15, 2004 Here here Mr. P I agree 100% Link to comment Share on other sites More sharing options...
88pathoffroad Posted December 15, 2004 Share Posted December 15, 2004 That's kinda funny you mention that, cause most Wal-Marts actually HAVE a gourmet Wal-Mart Edition McDonalds inside now... Link to comment Share on other sites More sharing options...
Mr. Pickles Posted December 15, 2004 Share Posted December 15, 2004 Yep, nothing like eating some ultra-fat cancer fries while shopping for cheap stuff. I go there for household stuff, but only on like a Tuesday night when the place is at least tolerable. Most of the time its like shopping at a demolition derby/circus. Link to comment Share on other sites More sharing options...
