TrailChaser Posted November 11, 2010 Share Posted November 11, 2010 I have been a welder for a while now and switched jobs to be a machinist about 3.5-4yrs ago. I own a Ready Welder and I love it. I have built both my bumpers and countless other stuff with my RW. Here's a few of the things I've built. Attachment for the Hi-Lift Jack to get a better grip on the sliders. Brackets to not only mount my seats, but give the drives seat a bit of a lift. Skids to cover the vital components. Fastener Protection Sliders and the Big Asre Jackstands Lower Link Skid Rear Diff Skid Link to comment Share on other sites More sharing options...
TrailChaser Posted November 11, 2010 Share Posted November 11, 2010 Windshield Mount for the Camcorder(fail(was too shaky while moving)) Rear Bumper Jerry Can Carrier with Custom Lock Repaired one of the shotty welded L&P Centerlinks for a buddy on these forums. Front Bumper Link to comment Share on other sites More sharing options...
Precise1 Posted November 11, 2010 Share Posted November 11, 2010 TrailChaser wins!! Everyone go home... B Link to comment Share on other sites More sharing options...
TrailChaser Posted November 11, 2010 Share Posted November 11, 2010 I have some stuff for the "shiny" thread also when it gets started. lol Link to comment Share on other sites More sharing options...
wood6078 Posted November 12, 2010 Share Posted November 12, 2010 TrailChaser wins!! Everyone go home... B X2 really nice work Link to comment Share on other sites More sharing options...
ANDY Posted November 24, 2010 Share Posted November 24, 2010 i really like the rear diff cover good work trail chaser Link to comment Share on other sites More sharing options...
TerranoNZ Posted November 28, 2010 Share Posted November 28, 2010 Just for nunya Shiny bog roll holders... Our local govt has far too much money 1.2mm SS BA polished. Link to comment Share on other sites More sharing options...
TrailChaser Posted November 28, 2010 Share Posted November 28, 2010 Toilet paper dispenser? Link to comment Share on other sites More sharing options...
Precise1 Posted November 28, 2010 Share Posted November 28, 2010 That's what I am guessing. They better be built solid like that!! Did you see the coin slot in it?? Imagine having a colonic emergency and no change?? You'd do anything to break into it before you walk out with no socks on!! B Link to comment Share on other sites More sharing options...
nunya Posted November 28, 2010 Share Posted November 28, 2010 Just for nunya Shiny bog roll holders... Our local govt has far too much money 1.2mm SS BA polished. I want one! That's effin hilarious! And thanks B for the sock comment, I officially laughed myself to crying! Link to comment Share on other sites More sharing options...
Tungsten Posted November 28, 2010 Share Posted November 28, 2010 Link to comment Share on other sites More sharing options...
TerranoNZ Posted November 28, 2010 Share Posted November 28, 2010 That's what I am guessing. They better be built solid like that!! Did you see the coin slot in it?? Imagine having a colonic emergency and no change?? You'd do anything to break into it before you walk out with no socks on!! B Coin slot? No, just a slot so you can see how much toilet paper is left. Those fit the BIG rolls too, not the small home kind To give you an idea of size, the opening at the bottom is 5". Link to comment Share on other sites More sharing options...
MY1PATH Posted November 30, 2010 Share Posted November 30, 2010 well I guess I'll post up my first 2 projects with the ready welder. The first is a 3/8 rod weled to a locknut. this will slide into my frame when I bolt up the bumper I'm working on. And the second is a gauge panel for my ranco In-cab ajuster. The top left air valve sticks out the back farther than I planned so I had to move it down leaving me with a small gap to fill. Eventually it will get my favorite BK08 powder coat. But I'd rather bring things to my powder coater in bulk. Link to comment Share on other sites More sharing options...
Mr.510 Posted December 11, 2010 Author Share Posted December 11, 2010 This article was posted to an email list I'm on. Everyone that welds should read it. I de-grease parts for welding with lacquer thinner and make sure they are thoroughly dry before getting them hot! Common Cleaners Can Turn Into Poison Gas Link to comment Share on other sites More sharing options...
OldSlowReliable Posted December 12, 2010 Share Posted December 12, 2010 This article was posted to an email list I'm on. Everyone that welds should read it. I de-grease parts for welding with lacquer thinner and make sure they are thoroughly dry before getting them hot! Common Cleaners Can Turn Into Poison Gas hey, I just referenced that! Alright, I need those blue LED's up there!!! GIMME! Link to comment Share on other sites More sharing options...
MY1PATH Posted December 12, 2010 Share Posted December 12, 2010 today I modified the banjo bolt on the transmission line to accept a 1/8 NPT temp sensor for my tranny gauge. First I drilled thru the bolt untill I was completely thru the head with a 5/16 drill. Then I reamed from the head down to the edge of banjo ports with a 3/8 drill to isolate the tip of the sender from the walls of the bolt and allow a small amound of fluid to pass around it. You can see how I ground near the holes at the transition from 3/8 to 5/16. You can also see that the bung has a 5/64 lip on it that is meant to postion it in a pan when welding. I used this same lip to center it on the bolt by drilling a counter bore into the head and it fits nice. Once all the drilling, reaming and boreing was done I gave it a good cleaning and welded the bung inplace. Once welded I ground down some of the weld to allow a 19mm wrench to fit on it. I gave it one more good cleaning and instealled the sensor. The installed sensor sits about 1/16 or less from the banjo ports so it will get a good read as the ATF passes by it and partially arround it (3/8 ream). Lastly there it is with some black paint installed back on the tranny and hooked up to the sensor. Nope that's not frost. That is what oil and ATF soaked parts look like whey they encounter heavy fog. Tranny pan gasket is next... Link to comment Share on other sites More sharing options...
JamesRich Posted December 12, 2010 Share Posted December 12, 2010 This article was posted to an email list I'm on. Everyone that welds should read it. I de-grease parts for welding with lacquer thinner and make sure they are thoroughly dry before getting them hot! Common Cleaners Can Turn Into Poison Gas I did that once! I was welding on an aluminum truck body and using brake parts cleaner to clean the metal first. Anyone who ever welded used aluminum knows it's a pain. Using the brake parts cleaner worked really well but when the fumes got under my helmet I almost passed out and fell off the truck, good thing I was young enough to bounce back then! I was welding on top of a beverage body truck. Aluminum was not made for the highway, I was constantly welding up cracks. James Link to comment Share on other sites More sharing options...
TerranoNZ Posted April 20, 2011 Share Posted April 20, 2011 I started a new job a couple of months ago and they mostly make benches. My second bowl.... not bad Tacked Welded Mostly polished Finished Link to comment Share on other sites More sharing options...
Precise1 Posted April 20, 2011 Share Posted April 20, 2011 I want one!! (looks great!! ) B Link to comment Share on other sites More sharing options...
TerranoNZ Posted April 24, 2011 Share Posted April 24, 2011 If you were closer it wouldn't be a problem B In other news I finally got round to making a snorkel.... A real one Of course I had to go overboard I will not be doing another like this.... WAY too much work Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 24, 2011 Share Posted April 24, 2011 NICE, you should have left the vise grips on it !! LOL Link to comment Share on other sites More sharing options...
2milehi Posted April 24, 2011 Share Posted April 24, 2011 Downpipe for the turbo Link to comment Share on other sites More sharing options...
nismothunder Posted April 25, 2011 Share Posted April 25, 2011 Welded a piece of sheet metal where my muffler split and filled ahole in the bottom, it shouold be good for another 100k. Link to comment Share on other sites More sharing options...
RF600 Posted April 26, 2011 Share Posted April 26, 2011 (edited) The car I have has struts on it. Noone makes replacement struts. I want to lower it some and others have cut their housings down and put in different inserts. So I figured why not. They are not finished yet. I still need to order a few more parts. I cut the tops off. Took more out of the body and welded the tops back on. Now I have more options for strut replacements. Edited June 12, 2011 by RF600 Link to comment Share on other sites More sharing options...
TerranoNZ Posted April 26, 2011 Share Posted April 26, 2011 Not bad for CO2 Link to comment Share on other sites More sharing options...
