dragracerjosh Posted October 31, 2010 Share Posted October 31, 2010 Im looking to pick your brains here is whats going on: When you go over a bump it shakes violently in the steering wheel. The Tires are all newer and in good shape, made no difference when I rotated them. Everything feels tight in the front in and looks ok which is what confused me! Other than this it drives pretty good and runs real nice. Thanks in advance for the help!!! Link to comment Share on other sites More sharing options...
nunya Posted October 31, 2010 Share Posted October 31, 2010 Lug nuts all on snug? Age/condition of the shocks? How did you check the front end, juts visually looking or jack it up and feel for wheel bearign/b.j./tie rod end/etc play? Does your truck have a steering stabalizer on it? Link to comment Share on other sites More sharing options...
Precise1 Posted October 31, 2010 Share Posted October 31, 2010 I'd guess idler arm, center link, ball joints, tie rod ends, bushings, etc. Just a matter of which... I'm willing to bet that your lower control arm brace bushings (towards the rear, a bar that goes through the frame) are shot (most are, they don't last long) and that affects the ability to handle a hit greatly. B Link to comment Share on other sites More sharing options...
JamesRich Posted November 1, 2010 Share Posted November 1, 2010 When my OEM center link was sloppy it would bump steer pretty bad. Grassroots fixed that problem. I would like to put a stabilizer but really don't need it now. James Link to comment Share on other sites More sharing options...
Kingman Posted November 1, 2010 Share Posted November 1, 2010 Check the compression rod bushings. They are in between a part of the frame and a "rod" that extends from the lower control arm back. Link to comment Share on other sites More sharing options...
Precise1 Posted November 1, 2010 Share Posted November 1, 2010 Good idea!! B Link to comment Share on other sites More sharing options...
Kingman Posted November 1, 2010 Share Posted November 1, 2010 Good idea!! B I just noticed you posted about it already, I was skimming for "tension rod" and "compression rod" specifically here before I replied so I didn't catch your post. So X2 to what B already said. Link to comment Share on other sites More sharing options...
adamzan Posted November 2, 2010 Share Posted November 2, 2010 X3 To tension rod bushings. Also check your Centerlink. Does it vibrate at highway speeds too? I had a mystery shake/handling issue that I finally fixed after 2 years turns out it was the upper control arm bushings... Link to comment Share on other sites More sharing options...
sewebster Posted November 2, 2010 Share Posted November 2, 2010 How do you tell if your compression rod bushings are shot? Mine don't exactly look new, but I can't wiggle them around by hand (front end jacked). Of course, I'm not very strong... Link to comment Share on other sites More sharing options...
adamzan Posted November 2, 2010 Share Posted November 2, 2010 With the truck on the ground, have someone bounce it up and down to look for any noticeable slop in the rods. It will be fairly easy to tell if they are worn badly. Link to comment Share on other sites More sharing options...
porsche4786 Posted November 4, 2010 Share Posted November 4, 2010 Where do you get the compression rod bushings? I've looked at rock auto, napa, autozone, O'Reilly, nobody seems to have them..... Link to comment Share on other sites More sharing options...
adamzan Posted November 4, 2010 Share Posted November 4, 2010 In a parts store ask for strut rod bushings. I have no idea why they call them that. Link to comment Share on other sites More sharing options...
Kingman Posted November 5, 2010 Share Posted November 5, 2010 Neither do I, the correct term per Nissan is "compression rod." "Tension rod" is used on the 2WD and older (pre-'87) Nissan trucks. Rockauto has them. $23 for a set of polyurethane Moog ones. Look under suspension. Link to comment Share on other sites More sharing options...
porsche4786 Posted November 5, 2010 Share Posted November 5, 2010 (edited) Love it when they have 3 names....people look at you like you are an idiot. Thanks for the help! Edited November 5, 2010 by porsche4786 Link to comment Share on other sites More sharing options...
Precise1 Posted November 6, 2010 Share Posted November 6, 2010 Yep, that's why I only describe them. People can sub in their own word for it but they know what I mean... B Link to comment Share on other sites More sharing options...
lint Posted November 28, 2010 Share Posted November 28, 2010 Replace your front (anti) sway bar bushings and endlinks. Replacing mine made a huge difference on the handling when going over bumps and in changing lanes. A kit should cost 25-50 dollars depending on your location. Link to comment Share on other sites More sharing options...
unccpathfinder Posted November 28, 2010 Share Posted November 28, 2010 i've had that with bent TRE's, compression rod (strut rod as advance calls it), and UBJ's...then again no the worst was with a busted compression rod bushing and busted UBJ she would dance every bump i hit and was unpredictable Link to comment Share on other sites More sharing options...
lint Posted November 28, 2010 Share Posted November 28, 2010 Here: http://www.nissanpathfinders.net/forum/index.php?showtopic=28544 Link to comment Share on other sites More sharing options...
unccpathfinder Posted November 28, 2010 Share Posted November 28, 2010 I don't have sway bars and know they make a difference but i would suspect that a different component that was worn out wore out the sway bar bushings and it will soon come back...typically the sway bar only helps in roll where a bump or excitement in the suspension will give you bump steer being the sway bar has no impact on steering just body roll also with the compression rod bushings i had bad vibrations on the highway and a pot hole or crosswind would give me "bump steer" and the only way to correct was to reduce my speed and let it oscillate out then accelerate...driving cross country with a trailer was not fun like this... Link to comment Share on other sites More sharing options...
GrimGreg Posted November 28, 2010 Share Posted November 28, 2010 The sway bar made bumps worse on mine, I love it without that POS on there! Link to comment Share on other sites More sharing options...
