XSrcing Posted October 5, 2010 Share Posted October 5, 2010 There is nothing in the area to connect it to, that I can see, but I'm curious as to what it is. Front passenger side of the engine compartment, just behind the battery. Link to comment Share on other sites More sharing options...
Tungsten Posted October 5, 2010 Share Posted October 5, 2010 looks like it's for the headlight Link to comment Share on other sites More sharing options...
Kingman Posted October 5, 2010 Share Posted October 5, 2010 I'm not sure what it is exactly, but it plugs into the wires that run along side the positive battery cable, and the other end routes back up the conduit going to the firewall. Link to comment Share on other sites More sharing options...
Nismojunky Posted October 5, 2010 Share Posted October 5, 2010 i was wondering the same thing i ahve it nothing to plud into maybe factory fog lights justa guess o and ps ur engine bay is to clean Link to comment Share on other sites More sharing options...
JamesRich Posted October 6, 2010 Share Posted October 6, 2010 That looks like the plug for the shock absorber. James Link to comment Share on other sites More sharing options...
KovemaN Posted October 6, 2010 Share Posted October 6, 2010 For all of us SE owners that have ditched the factory adjustable shocks, we could run some rock lights off of that circuit. I'm sure I can figure out the current draw for each shock. It seems like it should be enough to power some LEDs. I know the thought had popped into my head before, but I failed to write it down. I you still have the original shocks you could cut off the pigtail to wire into the lights. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted October 6, 2010 Share Posted October 6, 2010 it's definitely not for the headlights or factory fogs lights as the plugs are different. Maybe it's for the factory adjustable shocks. I never had them so I don't know how they look. Link to comment Share on other sites More sharing options...
Kingman Posted October 6, 2010 Share Posted October 6, 2010 The plugs for the factory shocks are down on the frame, right next to the UCAs. Link to comment Share on other sites More sharing options...
silverton Posted October 6, 2010 Share Posted October 6, 2010 I have an XE truck with that plug behind my battery as well. Not connected to anything of course. Link to comment Share on other sites More sharing options...
Specv1973 Posted October 9, 2010 Share Posted October 9, 2010 (edited) That is the plug from the wiring harness to the Nissan factory adjustable shocks as stated previously. Guaranteed. Just checked mine. Edited October 9, 2010 by Specv1973 Link to comment Share on other sites More sharing options...
frecklecolouredbrain Posted October 10, 2010 Share Posted October 10, 2010 I've played this game before..check out the post Things not connected to stuff. i have the same connector, i'm sure everyone does. its not for the shocks, cause my shock connectors are in the wheel wells. and this one behind the battery has a factory jumper wire plugged into it. you have A/C? Link to comment Share on other sites More sharing options...
Specv1973 Posted October 11, 2010 Share Posted October 11, 2010 I've played this game before..check out the post Things not connected to stuff. i have the same connector, i'm sure everyone does. its not for the shocks, cause my shock connectors are in the wheel wells. and this one behind the battery has a factory jumper wire plugged into it. you have A/C? Uhhhhh......His truck is a 92' and yours is a 89' LittleReD89 and mine is a 95'......so there MAY be differences grand wizard. But there are 2 plugs that have that connector on the back of my battery area. One is DEFINITELY the oil pressure sender (wires are yellow/blue stripe and black/white stripe) and the other plug is DEFINITELY for my factory Nissan adjustable shocks(white/black stripe, white/red stripe, black solid). What color are the wires on the back of the plug and are there 2 or 3 wires on it? I will post more pictures or a video if you need absolute proof. (FYI....my shocks have 2 plugs as well up front anyways, didn't check the backs, one at the shock and one about a foot away coming from the main wiring harness, in the engine bay. Link to comment Share on other sites More sharing options...
frecklecolouredbrain Posted October 20, 2010 Share Posted October 20, 2010 ok there gorilla-love. you don't gotta be snotty with the grand wizard thing. were all just puuting in a couple of pennies in here. Link to comment Share on other sites More sharing options...
adamzan Posted October 20, 2010 Share Posted October 20, 2010 Calm down kids. Why don't you look in the FSM they have a diagram explaining what every plug is for. Link to comment Share on other sites More sharing options...
