hardlydangerous Posted March 5, 2010 Share Posted March 5, 2010 Has anyone tried or currently running a welled diff or two? I had a welded 9" ford diff in my 84 s-10 w/400sb and mini spool in my 99 Chevy Xtreme. I never had any issues but these were street/drag machines with low pro tires, never used off road. I plan on wheelin this truck, but keeping fairly small tires on it, maybe 31's. I would love to have a locker but thats a lot of coin to spend on a bugdet build. If these diffs are strong enough I think I would just weld up the rear. Any thoughts? Link to comment Share on other sites More sharing options...
adamzan Posted March 5, 2010 Share Posted March 5, 2010 If you have the LSD rear i would just stick would that... Link to comment Share on other sites More sharing options...
sammyb33 Posted March 5, 2010 Share Posted March 5, 2010 Yea, staying on 31s i dont see any strength problems with welding up the diff, aside from the expected wear that happens in result of the welded rear. You'll be fine Link to comment Share on other sites More sharing options...
MY1PATH Posted March 5, 2010 Share Posted March 5, 2010 yes but watch out, if you dump your clutch in low range on the one below you may twist a driveshaft... Link to comment Share on other sites More sharing options...
GrimGreg Posted March 5, 2010 Share Posted March 5, 2010 You'll chew up tires like crazy if you see a lot of road use. Otherwise not a bad thing. Link to comment Share on other sites More sharing options...
hardlydangerous Posted March 5, 2010 Author Share Posted March 5, 2010 yes but watch out, if you dump your clutch in low range on the one below you may twist a driveshaft... Thats just too funny.... Link to comment Share on other sites More sharing options...
Kingman Posted March 5, 2010 Share Posted March 5, 2010 The only problem with welding a rear differential is the extreme tire wear from going around corners. Drag car owners do it all the time. Link to comment Share on other sites More sharing options...
hardlydangerous Posted March 6, 2010 Author Share Posted March 6, 2010 like I said I have run a mini spool and welded diff in trucks before but... one was a 9" ford (VERY STRONG) the only other set up was a mini spool in a stock chevy s-10 so I understand about the tire wear completely. The truck will not be a dialy driver, just a back up machine, hauling bikes to the track, off roading and winter beater. No city town driving around here I have never run a welded diff on a small stuck/SUV. I know some of the Subaru, DSM and nissan cars run them and its said that the lighter diffs tend to break pretty easy. If these are a fairly strong differential then I would have no problem mig welding one up solid. but if they tend to have issues then I would rather leave it stock. Link to comment Share on other sites More sharing options...
Precise1 Posted March 6, 2010 Share Posted March 6, 2010 They are quite strong and I have rarely heard of people having issues with them be they open, LSD or locked although mechanical or air lockers are preferred over welded. It should be fine from what I understand. B Link to comment Share on other sites More sharing options...
SC88Pathy Posted March 6, 2010 Share Posted March 6, 2010 The Nissan H233B axle is just as strong as a Ford 9", you're not going to break it with 31's We have members running up to 35's with little problems. They only start running into problems when running 35's with extra low gears locked in the rear. You would have to be thrashing it really hard to do any damage to the rear with 31's The front is a different situation entirely though, the CV joints aren't really designed to handle the stress of being locked. Some members run front lockers with no issues though Link to comment Share on other sites More sharing options...
hardlydangerous Posted March 6, 2010 Author Share Posted March 6, 2010 I think I would keep the front open or find a LSD... Link to comment Share on other sites More sharing options...
MY1PATH Posted March 7, 2010 Share Posted March 7, 2010 I had 1 extra disc (each side)in my LSD and arround sharp turns It pretty much acted like it was welded. I took them out but one day I may get the extra disc machined down and try again. Link to comment Share on other sites More sharing options...
GrimGreg Posted March 9, 2010 Share Posted March 9, 2010 The Nissan H233B axle is just as strong as a Ford 9", you're not going to break it with 31's Actually, the H233b is larger and stronger stock vs stock. Link to comment Share on other sites More sharing options...
