ant Posted January 15, 2010 Share Posted January 15, 2010 i have an 88 pathfinder 2 door xe.. the frame just exploded in the rear.. what year pathfinder frames will fit under my body? and i also have the stock steel rims can i put 31's on them? Link to comment Share on other sites More sharing options...
MY1PATH Posted January 15, 2010 Share Posted January 15, 2010 87-95 frames will work.@ some point the rear body mount bolts are differant but I think all else is the same. If yo want a leaf sprung pathy (I don't know why anybody would) 86.5-97 Hardbody pikcup may also fit with some modifactions to gas tank mounting on the donor. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted January 15, 2010 Share Posted January 15, 2010 Honestly, if your considering swapping frames, why not consider just rebuilding that section? Just some box steel and effort and it would be good for another 20 years vs something that has the same problem. Link to comment Share on other sites More sharing options...
edicer2 Posted January 15, 2010 Share Posted January 15, 2010 x2 to what OldSlowReliable said Link to comment Share on other sites More sharing options...
jbdevega Posted January 15, 2010 Share Posted January 15, 2010 ive heard we can use 1st gen xterra frames as well...the only nice thing i see about doing that would be if you got the frame and axles so you have the wider wheel base. but personally, x3 to OldSlowReliable Link to comment Share on other sites More sharing options...
RedPath88 Posted January 15, 2010 Share Posted January 15, 2010 Yes 31's up to 10.5in wide will mount on the stock 15x6 steel chrome, but that is at the extreme end of what will work. However, the frame sounds far more importnat at this point Link to comment Share on other sites More sharing options...
MY1PATH Posted January 16, 2010 Share Posted January 16, 2010 the xterra has a better UCA system for those who have suffered poor uca anchors you will know what I mean. Link to comment Share on other sites More sharing options...
GrimGreg Posted January 16, 2010 Share Posted January 16, 2010 the xterra has a better UCA system for those who have suffered poor uca anchors you will know what I mean. The Xterra UCA mounts direct to the frame instead of to a spindle. Instead of using shims for alignment they use offset cam bolts. Link to comment Share on other sites More sharing options...
ant Posted January 17, 2010 Author Share Posted January 17, 2010 at this point the frame is so rotted it isnt even worth rebuilding.. i got an estimate and its more than the truck is worth.. thats why i was trying to find what years fit mine i found a nice one at the junkyard with absolutely no rust.. its out of a 94... thank you for all the help.. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted January 17, 2010 Share Posted January 17, 2010 pics? Im curious Link to comment Share on other sites More sharing options...
ant Posted January 19, 2010 Author Share Posted January 19, 2010 ill get pics asap Link to comment Share on other sites More sharing options...
RJSquirrel Posted February 17, 2010 Share Posted February 17, 2010 car-part.com has quite a few frames available, quite a few from down south. If you have access to a trailer, you could go on a roadtrip and bring a good one up north. Get it hot-tanked and galvanized before you swap it in and it'll outlive you! Good Luck! Link to comment Share on other sites More sharing options...
Dowser Posted February 18, 2010 Share Posted February 18, 2010 when checking for frame rot at the wreckers don't just look for rust on the outside. Its very deceiving. There are holes in our frame by the rear wheels, stick your fingers in there and feel the INSIDE of the frame as well. Lots and LOTS of frames are rotting from the inside out. Good luck. Link to comment Share on other sites More sharing options...
GrimGreg Posted February 22, 2010 Share Posted February 22, 2010 when checking for frame rot at the wreckers don't just look for rust on the outside. Its very deceiving. There are holes in our frame by the rear wheels, stick your fingers in there and feel the INSIDE of the frame as well. Lots and LOTS of frames are rotting from the inside out. Good luck. Hammer test, lightly tap along the frame and you'll know when you hit a rot spot. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted February 22, 2010 Share Posted February 22, 2010 I know mine is rusting from inside out, you will notice paint bubbling around the holes along the frame, atleast thats how I know on mine Link to comment Share on other sites More sharing options...
Simon Posted February 22, 2010 Share Posted February 22, 2010 the xterra has a better UCA system for those who have suffered poor uca anchors you will know what I mean. Better in some ways, worse in others. Replacing the UCA's on an X, usually requires cutting the Camber bolts out. Not to mention, the camber can go out of alignment easier. Link to comment Share on other sites More sharing options...
