YoungWheelsCT Posted November 29, 2009 Share Posted November 29, 2009 so as the title states my key has snapped in the ignition n i was wondering how easy is it to swapped the ignition from one pathfinder (of the same year 1995) to mine n for the key locks if a keysmith would be able to fab up a new key using my door key lock. any ideas would be great thanks Link to comment Share on other sites More sharing options...
adamzan Posted November 29, 2009 Share Posted November 29, 2009 If you can get the broken part of the key out of the ignition the locksmith can make you a new key from it. Link to comment Share on other sites More sharing options...
Day95 Posted November 29, 2009 Share Posted November 29, 2009 can u solder? Link to comment Share on other sites More sharing options...
edicer2 Posted November 29, 2009 Share Posted November 29, 2009 i would take your igniton out and try to get the key out or take it to a locksmith and see if he can get it out. that would be the best and cheapest thing to do i think Link to comment Share on other sites More sharing options...
Precise1 Posted November 29, 2009 Share Posted November 29, 2009 All good advice so far. The housing set up is different for manual and auto trannys but I don't know if the lock cylinder is any different. Just keep it in mind if you swap out from another truck. B Link to comment Share on other sites More sharing options...
Toby Posted November 29, 2009 Share Posted November 29, 2009 Just break the rest of the key off in there and you'll never have to insert your key again! or just try and get the broken part out and get a locksmith to make a copy. Link to comment Share on other sites More sharing options...
morpheus Posted November 29, 2009 Share Posted November 29, 2009 If it's close enough to the surface of the lock, you could try small tweezers. Link to comment Share on other sites More sharing options...
RedPath88 Posted November 29, 2009 Share Posted November 29, 2009 If you need a locksmith to make a copy from the broken key (don't have a spare?) you could just let them remove the broken piece while they are at it. Just remove the cylinder assembly and take it to a locksmith Also, when you have it out, check to see if there is a hole on the other side that you can insert a pin or something to push it out. I don't know if there is one, but it can't hurt to look (and hope) Link to comment Share on other sites More sharing options...
nunya Posted November 29, 2009 Share Posted November 29, 2009 It's done for...just buy a new truck and donate that one to a member in need. Seriously though, just call a locksmith. Either take it to them or sometimes they come to you. No need to pull the ignition then! Link to comment Share on other sites More sharing options...
RedPath88 Posted November 29, 2009 Share Posted November 29, 2009 Nunya... in the spirit of automotive forums, it's about saving a buck and doing it (as much as you can) yourself Link to comment Share on other sites More sharing options...
nunya Posted November 29, 2009 Share Posted November 29, 2009 I know, just some locksmiths have mobile service and might be worth the extra buck for someone who reads this some time in the future and don't want involved in pulling the ignition out. Just an added suggestion to add to the list of already good ones that covered the basics already Link to comment Share on other sites More sharing options...
Day95 Posted November 30, 2009 Share Posted November 30, 2009 Get a toothpick, and some superglue. apply some superglue to the toothe pick... then apply the gluey side of the toothpick to the key... hold for a min or so untill the glue cures... then pull out, and hope of course. Link to comment Share on other sites More sharing options...
YoungWheelsCT Posted December 5, 2009 Author Share Posted December 5, 2009 thanks yall for the ideas im off to go try these ideas out till then Link to comment Share on other sites More sharing options...
