KJ139 Posted November 10, 2009 Share Posted November 10, 2009 I searched but did not find the info I am looking for. Does anyone know what the standard gear ratio is in the axle of a 1995 Pathfinder with the 6 cylinder engine? I checked on line and it listed it as a 4.3++ gear ratio, which seems a little short (numerically high) with a 6 cyl and 31-inch tires. Thanks! KJ Link to comment Share on other sites More sharing options...
SteeevO Posted November 10, 2009 Share Posted November 10, 2009 I searched but did not find the info I am looking for. Does anyone know what the standard gear ratio is in the axle of a 1995 Pathfinder with the 6 cylinder engine? I checked on line and it listed it as a 4.3++ gear ratio, which seems a little short (numerically high) with a 6 cyl and 31-inch tires. Thanks! KJ Yes This is correct. it may also be a 4.6++ To double check you can take a look at the plate riveted to the inner fender on the passenger side near the firewall. look for a HG43 or a HG46 printed on the plate. Link to comment Share on other sites More sharing options...
87pathy Posted November 10, 2009 Share Posted November 10, 2009 Yes This is correct. it may also be a 4.6++ To double check you can take a look at the plate riveted to the inner fender on the passenger side near the firewall. look for a HG43 or a HG46 printed on the plate. auto is 4.6x manual is 4.3x to the best of my knowledge. Link to comment Share on other sites More sharing options...
KJ139 Posted November 11, 2009 Author Share Posted November 11, 2009 auto is 4.6x manual is 4.3x to the best of my knowledge. Great, thanks guys. Link to comment Share on other sites More sharing options...
DavefromOZ Posted November 11, 2009 Share Posted November 11, 2009 take a look at the plate riveted to the inner fender on the passenger side near the firewall. look for a HG43 or a HG46 printed on the plate. The only way to know for sure Link to comment Share on other sites More sharing options...
sammyb33 Posted November 24, 2009 Share Posted November 24, 2009 no not all autos are 4.6, and not all manuals are 4.3 I have seen both in JYs Link to comment Share on other sites More sharing options...
MY1PATH Posted November 24, 2009 Share Posted November 24, 2009 x2 check the data plate Link to comment Share on other sites More sharing options...
kbjj Posted November 25, 2009 Share Posted November 25, 2009 Talking ratios... some might be interesed that the D21 Nivara (twin cab ute), has CA48 (4.875 ratio or 39 to 8 teeth).The front diff bolts into Pathfinder, rear on Nivara is leef spring setup. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 25, 2009 Share Posted November 25, 2009 Talking ratios... some might be interesed that the D21 Nivara (twin cab ute), has CA48 (4.875 ratio or 39 to 8 teeth).The front diff bolts into Pathfinder, rear on Nivara is leef spring setup. yes but for us USA & canada members if we want gears that low we can take the HG49 (4.93 ratio) front and rear out of R51's (frontys & x's) Link to comment Share on other sites More sharing options...
180sx Posted November 28, 2009 Share Posted November 28, 2009 Do those really bolt into ours??!?! Or is it just for you W/D21 guys? We R50 people are always left out. Link to comment Share on other sites More sharing options...
TerranoNZ Posted November 28, 2009 Share Posted November 28, 2009 Talking ratios... some might be interesed that the D21 Nivara (twin cab ute), has CA48 (4.875 ratio or 39 to 8 teeth).The front diff bolts into Pathfinder, rear on Nivara is leef spring setup. Or just get the factory 4:88's out of a later model Terrano, like the 94 I wreaked Link to comment Share on other sites More sharing options...
