Clinometer
Tungsten
Are those a stand alone unit, is wiring involved? How do they compare to the more expensive ones I've seen? I belive I saw one at 4x4parts.com?
Usually most are going to involve some wiring up. Some are a manual style so I dunno if you'd just need to wire up the lights or not.
The factory ones only wiring is for the lights. Other than that (when you get one) The holes to mount it are actually in the dash's metal skeleton under the pad. Take you center vents out and you can see where they are(with some light that is). You will need the clips as well though, or some nuts/bolts/washers
there is some sort of adapter for the rounded dash. Pretty sure someone on here has one, but I've never seen a pic of it though.
I is a Someone :lol:
Also here is a very useful thread on how to install the square ones. http://www.nissanpathfinders.net/forum/index.php?showtopic=1499&st=40
BTW Tungsten, What colour? Brown grey or grey like the one in the pic?
  • 1 month later...
