ItsTheBone Posted August 6, 2009 Share Posted August 6, 2009 Preface: 1994 Pathy, just got finished with timing belt and cam seal as well as installing a new starter. Truck won't start and can't get past the starter click. So as I'm trying to hunt down the reason for my starter click (installed new starter and still get just a click) I find this burnt wiring harness and I'm curious as to what part its connected to! The part in question has the wires going into it. The harness is burnt and melted. What could have done that? I've been following "A Starter Story" by k9sar and other posts. I have a feeling its going to take a bypass between the ignition switch and the starter. Just have to get to that point first! Any help is greatly appreciated! Link to comment Share on other sites More sharing options...
beavis0076 Posted August 6, 2009 Share Posted August 6, 2009 I believe thats your wiper motor... Link to comment Share on other sites More sharing options...
adamzan Posted August 6, 2009 Share Posted August 6, 2009 I believe thats your wiper motor... Yup Link to comment Share on other sites More sharing options...
94extreme Posted August 6, 2009 Share Posted August 6, 2009 3x Link to comment Share on other sites More sharing options...
frecklecolouredbrain Posted August 6, 2009 Share Posted August 6, 2009 does it rain that hard in oregan(?) to actually make that happen??? wow. dud, if you starter only clicks once when you turn the key it usually means that your battery is dead. please tell us that you checked that first. Link to comment Share on other sites More sharing options...
jadm4x4 Posted August 6, 2009 Share Posted August 6, 2009 had the same isuuse with mine. but wasnt the battery or the wipers.....lol it was the smaller wire on the starter motor. was connected but was loose. was getting the click but no go. have a look there to. Link to comment Share on other sites More sharing options...
beavis0076 Posted August 6, 2009 Share Posted August 6, 2009 Try tappin on the starter and selonoid with a hammer... Link to comment Share on other sites More sharing options...
87NPFnewbie Posted August 6, 2009 Share Posted August 6, 2009 (edited) Try tappin on the starter and selonoid with a hammer... IDK man, if its a new starter the brushes should be fine. I've only found that the hammer trick works when the brushes or windings are bad. Put a cupple "pecker tracks" on a new starter and there goes the warranty... Edited August 6, 2009 by 87NPFnewbie Link to comment Share on other sites More sharing options...
edicer2 Posted August 6, 2009 Share Posted August 6, 2009 might be a bad starter....its not uncommon o get a bad new starter from the store Link to comment Share on other sites More sharing options...
87NPFnewbie Posted August 6, 2009 Share Posted August 6, 2009 No argument about that. Thats why i recomend against using a hammer... Link to comment Share on other sites More sharing options...
Kingman Posted August 6, 2009 Share Posted August 6, 2009 The plunger on the starter might be defective and not properly engaging, so tapping it with a hammer may cause it to engage. If you're worried about dinging up the starter then put a small cloth over it where you beat on it. It works if you can manage to even get a cloth down there... I'd take that starter back and have whatever store you bought it from test it. If it's bad, cool you fixed the problem. If not, at least that's one thing ruled out. Link to comment Share on other sites More sharing options...
k9sar Posted August 6, 2009 Share Posted August 6, 2009 (edited) find where the noise (click) comes from. That will help you tremendously. small single click is probably your starter relay, hence the problem occurs after that. usually in the trigger wire or a bad solenoid on the starter rapid clicks - most likely weak battery or bad cable to terminal connection on battery big click (or thunk) - problem either in pos feed to starter or internal. Check voltage at big red wire on starter. If good, it's probably the internal contacts Edited August 6, 2009 by k9sar Link to comment Share on other sites More sharing options...
ItsTheBone Posted August 6, 2009 Author Share Posted August 6, 2009 (edited) Wiper motor eh. I haven't used it that much! Yes, I've checked the battery and even replaced it since it was dead and under warranty. I'd rather not have to start bangin on a new starter like my old one. Would rather take it back to test it. The click does come from the starter tho. Sounds like its pushing the spindle out, but can't get going past that. I'm following a wire diagram and finding no luck in locating the color of wires its indicating for different parts. I'm wondering if the click is a result of fried wiring somewhere like my wiper motor. Crash course in auto electrical! Edited August 7, 2009 by ItsTheBone Link to comment Share on other sites More sharing options...
OldSlowReliable Posted August 7, 2009 Share Posted August 7, 2009 Hit it with a rubber mallet? No ding! Link to comment Share on other sites More sharing options...
beavis0076 Posted August 8, 2009 Share Posted August 8, 2009 I often stick a long screwdriver on it with the handle touching the selonoid and tap on the screwdriver with a hammer, wont leave any marks. I would try that before yanking the starter off! Link to comment Share on other sites More sharing options...
