FUELER Posted March 10, 2009 Share Posted March 10, 2009 This weekend i drove through a long creek (about 300' long) where at its deepest point, the water was near the top of the tire, entire rim submerged at what point should i worry about water getting in the diffs? Should I open fill hole and check? Or dont worry bout it? heres a photo, this was almost the deepest part THANKS IN ADVANCE Link to comment Share on other sites More sharing options...
Pezzy Posted March 10, 2009 Share Posted March 10, 2009 Are you sure yours doesn't already have breathers? Link to comment Share on other sites More sharing options...
FUELER Posted March 10, 2009 Author Share Posted March 10, 2009 what i mean is how deep before i should worry about water getting into the breathers. sorry for the unclear title. Thanks Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted March 10, 2009 Share Posted March 10, 2009 From the pic it looks like you should be fine. I would look into extensions anyways, though. Nice shot BTW. Link to comment Share on other sites More sharing options...
MY1PATH Posted March 10, 2009 Share Posted March 10, 2009 if its anything like my 89 the t-case & front diff breathe into the tranny. and the rear diff breathes into the x-member above it. Hmm... maybe differant for the rear but if the rest is the same you shouldn't have to worry. Link to comment Share on other sites More sharing options...
alexrex20 Posted March 10, 2009 Share Posted March 10, 2009 ya, my rear diff breather goes all the way into the frame/body above it, pretty high up. i wouldn't worry about water that deep unless the breather hose is missing. Link to comment Share on other sites More sharing options...
tmorgan4 Posted March 10, 2009 Share Posted March 10, 2009 I can't seem to remember where the stock breathers hook up to. Here's what I did awhile back on the rear but I shouldn't be one to give advice on how to go through deep water!!! Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted March 10, 2009 Share Posted March 10, 2009 ya, my rear diff breather goes all the way into the frame/body above it, pretty high up. i wouldn't worry about water that deep unless the breather hose is missing. Did you do that yourself or is that the OEM set-up? Link to comment Share on other sites More sharing options...
adamzan Posted March 10, 2009 Share Posted March 10, 2009 (edited) I think it's like that from the factory. Not tmorgans. I mean alex's Edited March 10, 2009 by adamzan Link to comment Share on other sites More sharing options...
alexrex20 Posted March 10, 2009 Share Posted March 10, 2009 ya, mine came like that from the factory. Link to comment Share on other sites More sharing options...
XPLORx4 Posted March 11, 2009 Share Posted March 11, 2009 Just an FYI: that breather tube ends about 2" after it goes into that crossmember. It's worth considering a higher mounting location. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted March 11, 2009 Share Posted March 11, 2009 I can't seem to remember where the stock breathers hook up to. Here's what I did awhile back on the rear but I shouldn't be one to give advice on how to go through deep water!!! That's a sick breather set-up, Tyler. Where did you locate the hose, and what kind of hose did you use? Link to comment Share on other sites More sharing options...
01silvapathy Posted March 11, 2009 Share Posted March 11, 2009 (edited) I noticed alot later after I went through this water that my diff breather had come undone (water was up past top of running boards at deepest part) But it was noticed after this also occured (after the water crossing, but before I noticed the diff breather was not connected) Edited March 11, 2009 by 01silvapathy Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted March 11, 2009 Share Posted March 11, 2009 I noticed alot later after I went through this water that my diff breather had come undone (water was up past top of running boards at deepest part) But it was noticed after this also occured (after the water crossing, but before I noticed the diff breather was not connected) Check your diff, Andrew. If it's milky pink, change the fluid. Link to comment Share on other sites More sharing options...
Kingman Posted March 11, 2009 Share Posted March 11, 2009 It looks like 3/8ths tubing like you'd use for transmission fluid lines. Link to comment Share on other sites More sharing options...
01silvapathy Posted March 11, 2009 Share Posted March 11, 2009 Check your diff, Andrew. If it's milky pink, change the fluid. Whats the best way to do this, where do I open teh diff and what tools do I need, Im a college and dont have many Link to comment Share on other sites More sharing options...
SteeevO Posted March 11, 2009 Share Posted March 11, 2009 FUELER! looks like to were out in borrego! coyote canyon is always a cool run. I wouldn't worry about water in the breather from that crossing as long as you still have the breather hose connected. Link to comment Share on other sites More sharing options...
01silvapathy Posted March 12, 2009 Share Posted March 12, 2009 So im still confused on how to check for water in the diff?? Anyone want to chip in some advise? Link to comment Share on other sites More sharing options...
alexrex20 Posted March 12, 2009 Share Posted March 12, 2009 remove the fill plug, stick your finger in there and check the fluid. if it looks like chocolate milk, there's water. Link to comment Share on other sites More sharing options...
01silvapathy Posted March 12, 2009 Share Posted March 12, 2009 So Far I have heard Milky Pink and Chocolate Milk color......WTF? Link to comment Share on other sites More sharing options...
alexrex20 Posted March 12, 2009 Share Posted March 12, 2009 it's not ATF so it won't be milky pink. it's gear oil so it will be like chocolate milk. if it looks bubbly and frothy, time to change the fluid. make sure you can get the top fill plug loose before you open the lower drain plug - for obvious reasons. Link to comment Share on other sites More sharing options...
FUELER Posted March 12, 2009 Author Share Posted March 12, 2009 i changed the rear diff oil at about 80k and i changed the front diff and trasfer case at 130k Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted March 12, 2009 Share Posted March 12, 2009 it's not ATF so it won't be milky pink. it's gear oil so it will be like chocolate milk. if it looks bubbly and frothy, time to change the fluid. make sure you can get the top fill plug loose before you open the lower drain plug - for obvious reasons. Then clearly my buddy's not using the right fluid in his rear diff... Link to comment Share on other sites More sharing options...
