beastpath Posted November 25, 2008 Share Posted November 25, 2008 Just recently my truck has been taking a long time to start, im talking 10 turnovers or so. But this is intermittant, occasionally it will start in 2-3. Thought it might have been my starter, had it checked and its fine. Any ideas of what else it could be? Link to comment Share on other sites More sharing options...
Kittamaru Posted November 25, 2008 Share Posted November 25, 2008 battery/alternator possibly. Also visually check your wiring and play with your ground connections. Maybe the TPS? Though I'm sure someone more experienced than I could tell yea/nea on that:) Link to comment Share on other sites More sharing options...
94extreme Posted November 25, 2008 Share Posted November 25, 2008 yeah, check your wiring and your grounding. sounds like a week battery or the connections to it. Link to comment Share on other sites More sharing options...
Precise1 Posted November 25, 2008 Share Posted November 25, 2008 Coil, dizzy, cap, rotor, timing, plug wires, spark plugs, fuel pressure regulator, battery, ground, etc. A lot of little things can do that but most are easy to check. When was the last tune up? B Link to comment Share on other sites More sharing options...
Simon Posted November 25, 2008 Share Posted November 25, 2008 Try this..... Turn the key to the on position....wait for the fuel pump to stop, then turn the key to the start position. If it starts quickly (normally) then you've got a leak in the fuel system somewhere that's not allowing the truck to retain the fuel pressure when the pump is off. I had that issue on my old truck. Link to comment Share on other sites More sharing options...
beastpath Posted November 26, 2008 Author Share Posted November 26, 2008 hmmm. last tune was bout 6 months ago. New everything. Ill scrape up the battery connectors tomorowz and see if that helps, and try the fuel pump thing. Link to comment Share on other sites More sharing options...
edicer2 Posted November 26, 2008 Share Posted November 26, 2008 sounds like no spark but im not a expert. Link to comment Share on other sites More sharing options...
adamzan Posted November 26, 2008 Share Posted November 26, 2008 I had this same problem a while back. Changing my fuel filter solved it. Link to comment Share on other sites More sharing options...
