brake pads
beastpath
EBC?or something like that... I heard good things about em.
Stillen if you want the pro stuff. but I haven't heard anything one way or the other about them
Edited by MY1PATH
I had the Stillen, but I did not like them; After they heated up they were OK, but the first 10 kminutes of driving they were absolutely dangerous with barely any stopping power. I guess they are race pads, so afetr you ride them hard on a track and heat them up they stop OK. I would NOT get them for a daily driver. I got rid of them after 1000 miles. I now have the Hawks and they are much better. Goodluck - glenn
  • 2 months later...
I ended up getting raybestos, not cheap ones but somewhere in the middle.
Only problem is the pads are so thick after I clip them into the caliper, the swinging section wont close over them!?!
What am I doing wrong?
Did you retract the pistons all the way?
there is a "srewdriver hole" in the side of the caliper stick a large flat head thru it and use it to pry the piston back into the caliper.
and yes my manual actually calls it a "screwdriver hole"
