Synthetic Oil Phenomena
laxman0324
So every time I change my oil with full synthetic I cannot get a reading on the dipstick until like 2,000 miles later...I use the lucas oil additive, which is clear, but I wouldn't think it would give me no reading...is anyone else experiencing this?
I have that issue at times with dino oil.
Use a clean dry rag, as soon as you pull it out grab the tip off the dip stick with the rag and the without moving open the rag and see where it is wet compared to your stick.
Yep, it's just hard to see which is good; your crank case is very clean. ;)
I pull the dip stick out and quickly hold it horizontal, and use light reflection to determine where the oil is/isn't. Well, only occasionally. Most of the time, I don't have a hard time seeing it...
my oil always comes out black... but I use conventional oil (Valvoline Conventional) + Lucas...
I'm tempted to go to Synthetic... but I'm afraid to do so before I fix my leaky valve cover gasket - the synthetic oil with more detergents would make it leak again (atm, it's plugged up and thus not leaking)
I also still need to replace my radiator + install a tranny cooler :(
Have you tried just tightening the screws (with in reason)? The vast majority of valve cover leaks I have seen were fixed by another 1/4 turn of the screw as they were too loose...
This is true. My dad's wifes 86 corvette needs this done EVERY year. And new seals ever 2 years. That's b/c she hardly drives the thing, though.
But back on topic, I have the same issue. I find if you stick it in and out a couple times (wiping it off in between), that I can get a good enough reading.
Edited by redfinder
No, because I don't have a torque wrench to use and I'm afraid to try with the air gun... daily driver fears
IMPACT GUN!!!
:blink:
Definately don't use an air rachet. The torque specs for the valve cover bolts are in inch lbs, you could just use a screwdriver and twist them down a little.
Most specs are in the 6-12 ft/lb range. ie, screwdriver/nutdriver and a twist of the wrist. You can easily tell if they are too loose and if you managed to strip one out by hand, you should never be allowed under the hood of your truck again...
IMPACT GUN!!!
:blink:
I didn't know that... huh. I guess I'll give her a go once I have a little spare time. 3x final projects on the run = ARGH
