Extreme90path Posted May 23, 2008 Share Posted May 23, 2008 (edited) This last weekend I went wheeling with a buddy that has a Toyota 4runner (85; 35" cooper STTs ARBx2 blah blah) Anyways, I had heard of people converting their A/C compressor to an air compressor. After seeing his in action (resetting my bead and his xD) I was sold on converting mine. I just wanted to find out if anyone here has done it yet, and if yes, what kind of oil are you using for the nizzy compressor. I have done a bit of research on it, and most people I have found are either running a York A/C compressor (Self contained oil) or air tool oil. What do you guys think? I am pretty excited to get on board Air. xD. Also I have been busy with the ol nizzy. I finally have a custom front bumper and I am currentlly working on my sliders. Oh yeah and I am ordering Trxus M/T tomarrow YAY! So anyways any input would be awesome! -Ben Edited May 23, 2008 by Extreme90path Link to comment Share on other sites More sharing options...
packie88 Posted May 23, 2008 Share Posted May 23, 2008 i was looking into the same thing. your not going to be able to use the stock a/c compressor from the pathfinder Link to comment Share on other sites More sharing options...
Extreme90path Posted May 23, 2008 Author Share Posted May 23, 2008 Why is that? I know a toyota guy running the stock toyota one with just standard compressor oil, and it proforms awesome. I am going to give it a shot, and if it works I will post a write-up. Link to comment Share on other sites More sharing options...
sw Posted May 24, 2008 Share Posted May 24, 2008 i was looking into the same thing. your not going to be able to use the stock a/c compressor from the pathfinder & that would be why? its only going to stop if its got no oil in it. an inline oiler is an easy answer to that i use generic light machine oil in my sd7 Link to comment Share on other sites More sharing options...
GrimGreg Posted May 24, 2008 Share Posted May 24, 2008 So, do you just use the A/C button to turn it on and off? How do you plumb it (intake, output etc.) I've always been curious and have heard people talk about doing this mod, just never saw a completed system with a how-to write up. Link to comment Share on other sites More sharing options...
packie88 Posted May 24, 2008 Share Posted May 24, 2008 i was told that since our a/c units use oil in the refigerant that once drained of the refigerant it no longer has oil. i may not have looked into as much Link to comment Share on other sites More sharing options...
Extreme90path Posted May 24, 2008 Author Share Posted May 24, 2008 (edited) Well that is the plan, Air tool oil or compressor oil. Here is a diagram of what I am going for: Found this on the net: Now what I am going to do to control the A/C compressor is use a pressure switch that is rated for 125psi, and it will engage and disengage the compressor using the ac clutch to maintain a consistant 125psi in the air tank. I will also install a 140 psi popoff valve just incase the pressure switch fails. For an airtank I pulled an old airtank off of a semi truck, that is going to mount between my frame rails with a custom skid for protection. Then I will put a power switch in the cab (hopfully reusing the A/C switch with a different label) with a remote pressure gage mounted in the back next to where the stock in-cab tire carrier was. Then for the outlets I am going to run airhose with "quick connects" mounted in the back next the the pressure gage and upfront on the bumper. So that is the plan. I will post pics of the install, I hope to have it done here in the next week or so. oh yeah kind of off topic, here is a pic of the new bumper for those interested haha yeah it's not perfectlly straight, but it was my first bumper build after all xD Edited May 24, 2008 by Extreme90path Link to comment Share on other sites More sharing options...
Extreme90path Posted May 24, 2008 Author Share Posted May 24, 2008 Oh yeah on a side note, I will just keep oil with me and add it every couple of times I use it through the intake. Link to comment Share on other sites More sharing options...
sw Posted May 25, 2008 Share Posted May 25, 2008 theres a few schematics kickn around on the net, that is basiaclly the same as the rest. However, as it show, its for a york. yorks have a sump, therefore they dont need to be oiled for round sanden style compressors you need to add an oiler to the air inlet. i have a fitting from my engine air intake that goes to my oiler then to my compressor inlet. this is my oiler: the blue & grey thing next to the washer bottle. Link to comment Share on other sites More sharing options...
sw Posted May 25, 2008 Share Posted May 25, 2008 Oh yeah on a side note, I will just keep oil with me and add it every couple of times I use it through the intake. i wouldnt recommend it. inline oilers are cheap and effective. Link to comment Share on other sites More sharing options...
Extreme90path Posted May 25, 2008 Author Share Posted May 25, 2008 (edited) Cool, I didn't know they made inline oilers like that, I am going to have to get one of those. Thanks! Also I do realize that was for a york, and that is has it's own oiling system, I just used the diagram to give a basic idea of what I am shooting for =) Edited May 25, 2008 by Extreme90path Link to comment Share on other sites More sharing options...
packie88 Posted May 25, 2008 Share Posted May 25, 2008 so it is possible to use the a/c compressor, how does the inline oiler work Link to comment Share on other sites More sharing options...
Extreme90path Posted May 26, 2008 Author Share Posted May 26, 2008 (edited) Not sure yet, but I what I think is it acts like a drip system. So as the air goes by (via vacume caused by intake) it sucks it into the compressor to keep it consistanlly lubricated. Edited May 26, 2008 by Extreme90path Link to comment Share on other sites More sharing options...
sw Posted May 26, 2008 Share Posted May 26, 2008 it acts on the principle of a venturi yes it lets little drops of oil in to the air going to the compressor. you can vary the flow of the drips of oil Link to comment Share on other sites More sharing options...
RedPath88 Posted May 26, 2008 Share Posted May 26, 2008 Why is that? I know a toyota guy running the stock toyota one with just standard compressor oil, and it proforms awesome. I am going to give it a shot, and if it works I will post a write-up. I actually picked up a "new" yota AC Comp today from a wrecking yard to replace the one that I have stored in the garage, it's in geat shape (much better than the one I had before) But this is for the yota of course. About the nizzy comp.. not sure as I have heard little about the amount of air it can push, Toyota compressors have a good rep (among the highest afaik) of being a prime choice for converting for OBA. I would be very intersted in the results you end up with using the Nissan unit. Link to comment Share on other sites More sharing options...
adamzan Posted May 27, 2008 Share Posted May 27, 2008 (edited) If it's of any importance, the compressors in the wd21's AFAIK are (at least the OEM ones) made by calsonic. I'm looking into OBA for my 95 once i finish the 93. I think this is the right link http://www.calsonic.com/pdf's/compressor.pdf Edited May 27, 2008 by redfinder Link to comment Share on other sites More sharing options...
sw Posted May 27, 2008 Share Posted May 27, 2008 (edited) my d21 was fitted with a 'diesel ki-ki' compressor dont know much about em, i have a feeling they are tied back to zexel somewhere. tho i could be barking up the wrong tree. Edited May 27, 2008 by sw Link to comment Share on other sites More sharing options...
adamzan Posted May 27, 2008 Share Posted May 27, 2008 my d21 was fitted with a 'diesel ki-ki' compressor dont know much about em, i have a feeling they are tied back to zexel somewhere. tho i could be barking up the wrong tree. Probably different for the canadian/us models than the aussie ones. Link to comment Share on other sites More sharing options...
packie88 Posted May 27, 2008 Share Posted May 27, 2008 so been looking into this and it has been done by somejeep owners anway have you started on yours yet Link to comment Share on other sites More sharing options...
RedPath88 Posted May 28, 2008 Share Posted May 28, 2008 Jared, it's really nothing new or all that unusual. This has been done by lots of people for many years Link to comment Share on other sites More sharing options...
packie88 Posted May 28, 2008 Share Posted May 28, 2008 lol, new to me... anyway ill worry about it a little later more pressing issues to deal wth on the truck Link to comment Share on other sites More sharing options...
Extreme90path Posted May 28, 2008 Author Share Posted May 28, 2008 I am just gathering parts at the moment. Though I was doing my timing belt on my Audi 4000 last night and I decided to pull the A/C and I found out it has a York so I am thinking about throwing that into the pathy, dunno yet though, depends on how excited I get. Link to comment Share on other sites More sharing options...
