slimer Posted May 3, 2007 Share Posted May 3, 2007 So I'm a new member here, I have a few suspension mods, but thats not why I'm posting. I just got done with putting in new headlamps and it is such a PITA. Is there an easier way? 1. Took out the corner lights 2. Popped the tabs and unscrewed the front grille 3. Unscrewed the Headlights 4. Lost some of the screws and then found them again. 5. Exchanged the Headlamps 6. Tried to figure out how the tabs popped back in and figured it out. 7. Put everything back together. I know in my other Nissans you just unscrewed the harness and replaced the lamp. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 3, 2007 Share Posted May 3, 2007 Um, I've always just taken off the retainer ring and pulled the bulbs out from the back. There's enough room in there unless you have massive hands. Link to comment Share on other sites More sharing options...
slimer Posted May 4, 2007 Author Share Posted May 4, 2007 I guess I have massive hands. Link to comment Share on other sites More sharing options...
unccpathfinder Posted May 4, 2007 Share Posted May 4, 2007 yea pop the retainers out...i usually have to pull the battery out to get the pass side b/c my hands too big to get in there...the retainers will only go on 1 way...the slots on the lamp and studs on the retainer are spaced differently (IIRC) so that it will only go on 1 way... once those are loose pull the bulb out the backside and fight with getting the bulb out of the connector and then put it all back together... Link to comment Share on other sites More sharing options...
slimer Posted May 4, 2007 Author Share Posted May 4, 2007 (edited) Going through the font end wasn't too bad. The headlights tilt out nicely. Edited May 4, 2007 by slimer Link to comment Share on other sites More sharing options...
GrimGreg Posted May 4, 2007 Share Posted May 4, 2007 I just got done with putting in new headlamps and it is such a PITA. Is there an easier way? Going through the font end wasn't too bad. The headlights tilt out nicely. Why ask if you don't want an answer? Link to comment Share on other sites More sharing options...
slimer Posted May 4, 2007 Author Share Posted May 4, 2007 It just seemed like it would be a tight fit to go that way. Link to comment Share on other sites More sharing options...
RedPath88 Posted May 4, 2007 Share Posted May 4, 2007 I just replaced my RH light and as noted above, just pull the plug, turn and remove the retainer then swap the bulb/lamp and replace the retainer and plug Link to comment Share on other sites More sharing options...
packie88 Posted May 4, 2007 Share Posted May 4, 2007 I guess I have massive hands. well you know what they say about ugys with big hands... Link to comment Share on other sites More sharing options...
MadManMike Posted May 5, 2007 Share Posted May 5, 2007 (edited) So I'm a new member here, I have a few suspension mods, but thats not why I'm posting. I just got done with putting in new headlamps and it is such a PITA. Is there an easier way? 1. Took out the corner lights 2. Popped the tabs and unscrewed the front grille 3. Unscrewed the Headlights 4. Lost some of the screws and then found them again. 5. Exchanged the Headlamps 6. Tried to figure out how the tabs popped back in and figured it out. 7. Put everything back together. I know in my other Nissans you just unscrewed the harness and replaced the lamp. I think step 4 could be eliminated. -Mike Edited May 5, 2007 by MadManMike Link to comment Share on other sites More sharing options...
slimer Posted May 5, 2007 Author Share Posted May 5, 2007 What do they say? Yeah, step 4 could have been eliminated, but working with cars always needs to be interesting. Link to comment Share on other sites More sharing options...
