Gabriel Posted July 27, 2006 Share Posted July 27, 2006 So after oh, I'd say 6 months since I hand the entire cooling system re-paired here I am with a puddle the size of the truck and no visible hoses leaking... It might just be the last time I drive this G'Damn thing. Has anyone delt with these cooling system issues is it common or just my Sh'T luck??? :furious: Link to comment Share on other sites More sharing options...
k9sar Posted July 27, 2006 Share Posted July 27, 2006 maybe the block drain plug not sealing well? did the people who worked on your system drain the block? Link to comment Share on other sites More sharing options...
94extreme Posted July 27, 2006 Share Posted July 27, 2006 yeah or the freeze plugs have gotten loose. search and find where the leak actually is othersiwe it's all just a speculation. Link to comment Share on other sites More sharing options...
Gabriel Posted July 27, 2006 Author Share Posted July 27, 2006 It's going back in we'll see, I would think they did and then refilled it w/ new coolant. Link to comment Share on other sites More sharing options...
Gabriel Posted July 27, 2006 Author Share Posted July 27, 2006 That's the thing, the heads and everything has to come of/ out to find out . Link to comment Share on other sites More sharing options...
The Drift Posted July 27, 2006 Share Posted July 27, 2006 Check the stupid obvious stuff too. Radiator drain plug, stupid crap that would be a no brainer is often the culprit. Maybe it's just me...lol Link to comment Share on other sites More sharing options...
94extreme Posted July 27, 2006 Share Posted July 27, 2006 That's the thing, the heads and everything has to come of/ out to find out . huh? just look will you? to check the freeze plugs nothing has to come out.. they are on the outside of the engine... you said middle. which middle? any mixing of fluids? Link to comment Share on other sites More sharing options...
Filthy Luker Posted July 27, 2006 Share Posted July 27, 2006 (edited) There is a very short 90 degree bend hose that's just above the thermostat and under the distributor. It's very hidden and you can really see it when you take the accessory belts off and the bracket that holds the idler pulley. I had to deal with a mysterious leak recently on Nissie's WD21 and it turned out to be that little hose. Edited July 27, 2006 by Filthy Luker Link to comment Share on other sites More sharing options...
k9sar Posted July 27, 2006 Share Posted July 27, 2006 ask Slick. It was hers Link to comment Share on other sites More sharing options...
94extreme Posted July 27, 2006 Share Posted July 27, 2006 ask Slick. It was hers and there are picstures and the whole description.. maybe worth a search? Link to comment Share on other sites More sharing options...
k9sar Posted July 27, 2006 Share Posted July 27, 2006 is there a button for that? Link to comment Share on other sites More sharing options...
94extreme Posted July 27, 2006 Share Posted July 27, 2006 lol. allright then: Link to comment Share on other sites More sharing options...
GrimGreg Posted July 28, 2006 Share Posted July 28, 2006 Need to put that pic in a sticky thread in the New Member section. Link to comment Share on other sites More sharing options...
RedPath88 Posted July 28, 2006 Share Posted July 28, 2006 There is a very short 90 degree bend hose that's just above the thermostat and under the distributor. It's very hidden and you can really see it when you take the accessory belts off and the bracket that holds the idler pulley. I had to deal with a mysterious leak recently on Nissie's WD21 and it turned out to be that little hose. Yep, the designer at Nissan who came up with that idea should be shot.... include his boss too. for allowing it to go through Link to comment Share on other sites More sharing options...
unccpathfinder Posted July 28, 2006 Share Posted July 28, 2006 yea i'd go with the obvious..all of the coolant hoses, water pump, rad plug, crack in overflow resivoir...etc etc Link to comment Share on other sites More sharing options...
RedPath88 Posted July 28, 2006 Share Posted July 28, 2006 Late last week I had a coolant leak... first noticed it on the ground just behind the radiator... Saturday I investigated it and found it to be one of the small TBI hoses... the clamp (original) had simply given up. New clamp solved the problem -thnkboutit- Link to comment Share on other sites More sharing options...
