OE812 Posted July 20, 2006 Share Posted July 20, 2006 My 99.5 Pathfinder is making a whistling noise eminating from the rear. This happens when coasting at about 22 mph (1200rpm's) with the overdrive on. When coasting at 22mph, pressing the OD button off eliminates the noise. Pressing it on again, the noise is back. Any suggestion? Thanks, Jeff Link to comment Share on other sites More sharing options...
SaKaNa Posted July 20, 2006 Share Posted July 20, 2006 is it more of a whirrr.... cause when im going like 70 and holding the gas at like a 50mph level, i hear a noise, but i think thats just something like, not catching since im not moving slow enough to need it Link to comment Share on other sites More sharing options...
OE812 Posted July 20, 2006 Author Share Posted July 20, 2006 Link to comment Share on other sites More sharing options...
94extreme Posted July 20, 2006 Share Posted July 20, 2006 why are you hiding? did you check ECU codes? Link to comment Share on other sites More sharing options...
vengeful Posted July 20, 2006 Share Posted July 20, 2006 Check out this Technical Service Bulletin for Transfer Case Bearing Noise at Low Speeds... http://www.fnd4pth.com/R50/TSB/NTB01-085A.pdf Link to comment Share on other sites More sharing options...
OE812 Posted July 20, 2006 Author Share Posted July 20, 2006 Just hiding from SaKaNa's answer which I don't completely understand. BTW, nice profile photo... There are no ECU codes. Thanks, Jeff Link to comment Share on other sites More sharing options...
vengeful Posted July 20, 2006 Share Posted July 20, 2006 Just hiding from SaKaNa's answer which I don't completely understand. Don't worry....nobody completely understands SaKaNa. Link to comment Share on other sites More sharing options...
OE812 Posted July 20, 2006 Author Share Posted July 20, 2006 I should have mentioned that I have a 2wd pathfinder. Link to comment Share on other sites More sharing options...
94extreme Posted July 20, 2006 Share Posted July 20, 2006 ah, ok. not me but my truck with a hood ornament. Link to comment Share on other sites More sharing options...
vengeful Posted July 20, 2006 Share Posted July 20, 2006 Well, then in that case, disregard the TSB. Have you checked the fluid level in the tranny? Link to comment Share on other sites More sharing options...
94extreme Posted July 20, 2006 Share Posted July 20, 2006 Check out this Technical Service Bulletin for Transfer Case Bearing Noise at Low Speeds... http://www.fnd4pth.com/R50/TSB/NTB01-085A.pdf you own a 99 and an 04? Link to comment Share on other sites More sharing options...
OE812 Posted July 20, 2006 Author Share Posted July 20, 2006 The fluid is fine. I own a 99. Link to comment Share on other sites More sharing options...
XPLORx4 Posted July 20, 2006 Share Posted July 20, 2006 is it more of a whirrr.... cause when im going like 70 and holding the gas at like a 50mph level, i hear a noise, but i think thats just something like, not catching since im not moving slow enough to need it That's probably differential whine, which isn't a big problem, it's just sort of an annoyance caused when the gears have worn in. It is often loudest when there is no load on the gears. This only happens if the engine is decelerating at exactly the same rate as the vehicle. In other words, no acceleration and no engine braking. Shift to neutral isn't the same as no engine braking, because then the driveshaft puts a very slight decelerating load on the pinion gear, which is usually enough to hide the whining. Link to comment Share on other sites More sharing options...
XPLORx4 Posted July 20, 2006 Share Posted July 20, 2006 My 99.5 Pathfinder is making a whistling noise eminating from the rear. This happens when coasting at about 22 mph (1200rpm's) with the overdrive on. When coasting at 22mph, pressing the OD button off eliminates the noise. Pressing it on again, the noise is back. Any suggestion? Thanks, Jeff When you switch OD on and off at 22mph, does the RPM change? This could be the same thing as what I just posted about differential whine. With OD on at 22mph, the tranny might shift into a gear that happens to put nearly no load on the gears. Link to comment Share on other sites More sharing options...
vengeful Posted July 20, 2006 Share Posted July 20, 2006 you own a 99 and an 04? Nope.... I posted the 04 for someone, and I'm working on getting the rest up, too. Link to comment Share on other sites More sharing options...
OE812 Posted July 20, 2006 Author Share Posted July 20, 2006 When you switch OD on and off at 22mph, does the RPM change? This could be the same thing as what I just posted about differential whine. With OD on at 22mph, the tranny might shift into a gear that happens to put nearly no load on the gears. Yes, the rpm changes. What is the best diff fluid to use? Link to comment Share on other sites More sharing options...
XPLORx4 Posted July 20, 2006 Share Posted July 20, 2006 (edited) Use 80-90W GL5 gear oil. If you have an LSD, use the same type which includes an LSD additive. But that may not help with the whining noise, which isn't a serious problem. Edited July 20, 2006 by XPLORx4 Link to comment Share on other sites More sharing options...
Trainman Posted July 20, 2006 Share Posted July 20, 2006 On my 02, shifting the OD button at 35 kph (22 mph) does not do anything, it is too slow (school zone slow). Need to get up to 50 kph (30 mph) or so before the OD will kick in. I know no help, just my experience Link to comment Share on other sites More sharing options...
