Due to a hardware failure on the hosts systems, all posts and messages created between May 26th and Jan 13th have been lost. Additionally, if you joined the NPORA Forums community during that time, you'll need to re-register. -NPORA Mod Team *Updated: 05/19/2022 12:15AM PST
Everything posted by Channel595
Wheel bearings are pretty forgiving and don't need to be exactly 7 ft lbs, and there is no special puller just a brass punch.
Is it worth having a vehicle repaired at a dealer repair shop?
Channel595 replied to jwblue's topic in The Garage
I have worked at many dealerships and independent shops and here is the absolute truth. At the dealer: the techs are usually more passionate about that car line, will do a good job, factory trained, and the dealer will have every special tool to do every job. At independant shops: more focused on beating "flat rate time", usually use after market(cheap) parts, will have to fab(m)ricate special tools My personal experiance at independent: if I had a car that I didn't like (almost every chevy) I would not even change the oil, but rather top off oil and put new sticker on it, I almost never did any fluid flushes because they were messy, if you pissed me off I will make sure to leave bolts out of your car When I worked for the dealer I always did a good job and never had any complaints because the cars are easier to work on as they mostly all newer with no rust or leaks. If you take it to a specialty independant shop they will usually do a good job because they only focus on certain car lines. By the way I also am an ASE master tech -
Ok follow up to my question. I got the evo shift and I would have to say that droid is the biggest piece of crap ever made. I can honestly say almost everything doesent work on it. I searched and asked my other friends why does this app just stop working and the answer is "it happens" lol. Welcome to the chevrolet of phones. First chance I get I'm going I phone.
Who wants a better Cat? Magnaflow cats $75
Channel595 replied to MY1PATH's topic in 90-95 WD21 Pathfinders
My1path did you randomly come up with those numbers? A stock cat will always clean the tail pipe emissions better then after market. If your cat is restricted then its just flat out bad and needs to be replaced. A cat can't get carbon fouled it burns too hot for carbon to collect, but it can melt the core and cause a restriction -
If your a motor sport enthusiust like me you may have heard of this. its coming to a town near you most likely. I have went the past 2 years and had a blast, the best part is its all free check out http://www.rally-america.com/ travis pastrana, ken block, and dave mirra have been on the circuit before
Sounds like you over tightened the bolts, I woul re check the rest and see if you tore the steel on the body of the truck
It has a weak cylinder, but still has some compression. Rough idle and smoke is normal on diesel engines but with that one weak cylinder it will make a rough engine as long as that is the only problem.
There is a reason the factory cat is bigger then the after market one... it works better and makes less emissions, if its not carb cat I wouldn't expect it to last more then 3 years. You can sell a non working factory cat for about 60 bucks I don't see how this can be that good -
Clicking/snapping under acceleration
Channel595 replied to Tungsten's topic in 90-95 WD21 Pathfinders
There is no way an injector could make enough noise to hear over the engine being on. Sound like a single bad lifter, if you hear the lifters at all they are bad -
3.3L 2003 engine interferance? (broken Tbelt)
Channel595 replied to lunchindabox's topic in The Garage
The valve dish in the pistons is for higher compression, not to make it a free spinning engine... as for snapping the timing belt, if you have an automatic and you snap the t belt while cruising you have a chance that there was no piston to valve contact but if you try and start the car after words your chance just got smaller. If you have a stick and snap the belt while cruising, the rear wheels are directly connected to the crank and you are still spinning the engine while bending valves, hope this helps -
why would you need to remove the upper intake manifold again and again? sounds like thats your problem... as for the oil pressure problem, if your pressure is below spec at the given rpm it usually means worn bearings. it is normal for the oil light to turn on at very low rpm.
so my pathfinder is pretty dented, the paint is oxidised, it burns oil, needs: idle air valve, front ball joints, valve cover gaskets, tires, clutch soon. the transmission never had the tsb with the extra fluid level installed so it whines pretty bad. oh and the amplifier or sub just broke... by the time i fix all that i could buy a pretty decent car and if i do sell my pathfinder i will probably just get the same body style pathfinder because i love this car. it has 238,000 miles by the way.
blinking cel = potential cat dammage like a missfire from no spark. condensation in the cap? like frost melting when it gets warm and turning to water?
most of the media(torrents) i download is from http://thepiratebay.org/ probably the last remaining totally free torrent search site
you cant ever trust hacking sites just think who put the content there, a hacker and where are they going to test their hack programs. but if you really want to learn read articles and the factory service manuals... i think most linux stuff is still free. the other day i found this useful site not about pathfinders but still helpful http://www.aircooled.net/gnrlsite/resource/articles.htm
looks like more of a cool input and output device... instead of a mouse it uses his finger tips and no monitor there is a projector linked up to a laptop in his back pack. it would be cool if it could link to a smart phone or such. i dont think it will catch on though, i remember a few years back they had a camera device that you place on your monitor and it sences where your eye is looking and removes the mouse but what ever happened to that?
i could see how they would lift a toyota because the torsion bars are connected to the upper control arm but why would a nissan need one?
why would i want to use them? has any one used them on their pathfinder and can give input.
when you turn your car off thats when it is the hottest and if your cap isnt bleeding off right it will tend to leak at the weak point if its a head gasket
if your really afraid its coolant you can taste it (a small amount wont hurt) it will taste bitter. the easiest way to see if your loosing coolant mark your coolant resevoir with a sharpie in the morning and then after you go driving for some bit check your level and make sure you park in the same spot and check when your engine is cold again
damper delete is the next thing i will be doing, i noticed it makes the clutch disengage slower. no damper no problems.
left pocket cell phone, right pocket keys, back pocket wallet. i am the exact same way have to check before i leave.
if you were getting straight dripps of coolant out of the exhaust you would definitely see white smoke and lots out the tail pipe... warning dont eat the yellow snow!
Build up your VG30E to get 160-170hp and have 20mpg!
besides the electric fan most of that is basic maintenance. i still doubt 20 mpg unless it was the best conditions with down grade or back wind actual mpg -
i find it hard to believe that a 19 year old engine can get 17 more horse power by those small things, maybe some from the msd but not even 17. one thing that can help gas mileage is put mud flaps in front of your tire (just look at hybrids), and for horse power eneos oil
