u13turbo
    1991 Terrano, 4dr, gun metal grey, black spokes, 31" Kumho kl71 muds, 2" suspension lift, td27t
    Terrano R3m
    New Zealand
    New Zealand
u13turbo's Achievements
  1. Keep turning key, may take an hour of it, but if it eventually works, it'll be a burnt out part of the armichure, just buy a secondhand starter. Mine does the same thing, I still use it but 2 times in last 3months iv been stuck trying to start for over an hour..... and one of those times when it finally worked i had a flat battery... all in good fun.
  2. Its easy enough to do, If i remember correctly you dont even have to move injector lines, Just undo all the bolts, take the intake pipe off that comes over the rocker cover off, and pull its out.
  3. Awhile ago i chucked some 2" springs in, and reindexed torsions, the anchor for torsions was sitting low and one got bent abit, so today i reindexed again, aswel as bending the bent one straight, up into the crossmember, But now the front sits really low, i tried the next spline up and that made it sit to high... There is a little bit more room for cranking up so im hoping it will make enough difference. When i done the lift, i didnt worry about shocks. Currently i have one standard one and one aftermarket one, done by previous owner....... I can see that the side with the newer shock, sits quite abit higher, so im guessing my old standard one is shot? Im on a tight budget atm, still studying, so were would i get some ok shocks for a good price? in New Zealand. Cheers
  4. My auto is near farked, When i let off throttle at 100, revs drop, then i apply throttle and it just slips for abit until it hooks O.D gear again....
  5. I'd love to. Bit more difficult to do it in New zealand.
  6. Oh really? to find out is it on the chassis plate thing or somewere on the diff?
  7. Yep we both autos. And you must definitly have the 4.8 ratio diffs?
  8. From what I've heard that happens with 33's..
  9. Cheers for that Pete, I think i will give it ago to go 3" the whole way. As for the park lights, should i be looking around the steering column for a feed? just use a voltmeter to find some voltage when park lights are turned on?
  10. Hey guys, got a boost gauge in and connected, just don't know where to wire the light in for it? Also, my new snorkel is 3", should i take the filter box out and chop the old 2" one off and weld on a 3" bit?
  11. Yeah its nothing to do with key in the ignition because the locking use to work and the key has always been stuck. I checked for voltages today, and on the drivers door im getting voltage change as i press the unlock/lock button(around 10.7V) all the way down to the little rubber sealed thingy, so im wondering if the fault is in there?
  12. Cheers Pete, yeah i wll have to start fault finding, thought i would just check first to make sure there isnt a common fault point. And yeah, the key hasnt bothered me much, except it would be an easy steal for someone
  13. Hey guys, my central locking packed a sad, it was locking and not unlocking, now it wont do either...... Kinda bad as even if i manually lock doors, the boot is still unlocked. And whats worse is a key is stuck in the ignition(If anyone knows how to fix this it would be a great help too). Cheers
  14. Hmm.. im pulling 2500rpm at 100km/h on 31's.. I really want to get 33's but abit outta budget atm
  15. Yeah so there definitly something up with mine.... How many RPM are you pulling at 100km/h?
