Nismojunky
Everything posted by Nismojunky
  1. your speakers may be blowing it if the factory amp isnt powering the speakers it may be overloading the decks amp
  2. it works sometimes when its really cold out other then that it just hits 8k and sits there untill i shut the car off, what could it be>?
  3. fill weild and drill and tap new holes
  4. yep went up a part that was about 3-4 feet high rolled off of it
  5. front in rear out 3" BL 33" MT 75% left wet, the snow is from the bank i hit i had my rear out since i bought it its alright with it out you jsut have to watch your turns you get use to what it can handel and i rolled because i went up and off the bank
  6. i was thinking of cutting the roof off and getting leather seats and turning it into a bogger take the front fenders off and get some 35"s on it lol
  7. well guys i totaled my pathfinder 2 days ago, Someone cut me off causing me to hit a snow bank and roll my pathfinder. i walked away with out a scrach, but beasty is totaled im going to be stripping her for the parts that i want and then parting out the rest, ive all ready found a nice mint 94 pathfinder just have to scrape some money to gether to get it... heres some pictures. From my cell, will have more photos after i get down to my buddies farm to get some shots of it.
  8. to narrow down your serch for the leak, (if it idles steaddly when shes warm) get a torch and rus the gas around your vacume lines if theres a leak the idle with change massively because it will suck the gas in and burn it
  9. sounds like the clutch go to your local part store and get a full clutch kit (pressure plate everything) and install it your self or get some one to
  10. its really not that hard to do
  11. i ran bfg 32"X11.5" At's with a 3" body lift i just had to remove the inner feder walls no rubbing what so ever
  12. thats exactly what minw did try disconneting your coolant tempurature sensor
  13. try reving it past four grand and see if the alty kicks in simon has this problem where it doesnt charge untill he revs it up
  14. when was the last time you changed your fuel filter?
  15. is there a heavy smell of fuel comming from the engine? when it dies?
  16. accually it has nothing to do with the temperature is there a heavy smell of gas comming from the engine when this happends?
  17. sounds interisting i want to hear more
  18. heres where its located http://z.about.com/d/autorepair/1/0/s/9/42331543.gif
  19. thats your coolant temperature head sensor mine did that untill i unpluged it and replaced it
  20. did u try unpluging you coolant tempature sensor?
  21. my power steering box is leaking, where the pitman arm connects to it. im trying lucas stop steering leak right now. if that doesnt work someone suggested motor oil to help seal things up. do i have any other options other then replacing it?
