fleurys
Vendors
fleurys last won the day on May 16 2025
fleurys had the most liked content!
4 Followers
About fleurys
  • Birthday 09/10/1970
    Yakima LoadWarrior + Extension Cargo rack + Tire Carrier + Hi-Lift Jack Brackets 48" Hi-Lift Jack PIAA 520ATP lights Daystar Light Switch Cobra 75WXST and Wilson Fiberglass 3' KYB Struts + AC Coils + Rancho 9000XL BF Goodrich KM2 255/85R16 (33.4) Front & Rear Arb Lockers Custom aluminum full belly skid plate Custom steel+hdpe rock sliders sfcreation.com 1" front and rear coil spacers 1.25" wheel spacers
    qc
    Canada
23,165 profile views
fleurys's Achievements
NPORA Old-Timer (5/5)
419
  1. yep ! that's a good guy ! happy that the forum is back online... facebook groups are just not my thing when you search things ! way to go adam
  2. If you found the issue, it would be nice for you to update your findings.. everyone could benefit from it.
  3. On my side I received the 10 code which specifically pointed to the neutral-4lo switch... I assume you got the 18 code which could also be the neutral-4lo switch but it could be one of the other 2 also... so If I were you i would start with checking continuity between the different switches by checking pins 40, 25 and 43 directly on the tcu connector. It should be pretty easy, just follow the instruction page tf-115. disconnect the tcu connector, key off, and start checking continuity and you will get to the bottom of which switch has failed. Here the procedure from tf-115 . The tcu is inside the truck (see TF-49 (I)) ( you could also go directly at the switches underneath the truck at the transfer case and start testing also there (see TF-149 at the bottom and tf-150) Operate 4WD shift switch and check continuity between the following terminals. Continuity: Terminal 40 (ATP switch) and body ground “4H” position: No continuity should exist. Between “4H” and “4LO”: Continuity should exist. “4LO” position: No continuity should exist. Terminal 25 (Neutral-4LO switch) and body ground“4H” position: No continuity should exist. “4LO” position: Continuity should exist. Terminal 43 (Wait detection switch) and body ground“4H” position: No continuity should exist. (*1)“4LO” position: Continuity should exist Once you know which switch is bad, then you can start looking for the parts... comeback here with the results and i'll help you find it. S.
  4. Get yourself the oem repair manual and follow the diagnostic procedure on page tf-62 and tf-63. This will make your 4wd light flash a number of times and then repeat. The number of time if flashes will give you the code you need in order to know what is wrong using pages tf-64 and 65. If you don't have the manual, I can put it here if you need. I used this procedure in order to find the issue I was having and it turned out to be my neutral-4low switch on the transfer case. Easy to change and everything went back to normal. but you need to know the code or else you're just shooting in the dark.
  5. Do any of you guys know of a company (us or Canada), that sells pre-formed brake or fuel lines for R50 2001 - 2004 ? I will have to soon redo rusting brake and fuel lines from the abs pump up to each wheel... I am looking to find pre-formed lines... The nissan dealer I checked only offers very little on this (like a small rubber brake line but nothing on the hard lines)... I found some aftermarket companies but they do not offer anything for my R50s... Any of you guys found these so I don't have to form them myself ? Cheers. S.
  6. beautiful... Love your posts.. keep them coming
  7. Well.. yes it took me that long to find the time to change the bleeder screw..lol... I confirm M7x1 are the good numbers... just too bad for me that the bleeder was rusted stuck, which I eventually snap in two while the other part stayed in the wheel cylinder.... so had to change the wheel cylinder and of course the brake line snapped also trying to unscrew it... which led to a new brake line all together... real nice example of a 5 minute project that turns into a half a day... welcome to rust country ! Thanks again @hawairish
  8. Thank you... I will give it a shot and come back here to confirm... Cheers ! S.
  9. I need to order some bleeder screws for the rear, but unfortunately I felt short of getting the specs of it and apart from knowing the nissan part number (41128-8J100) which cost almost as much as a complete wheel cylinder, I am asking this : Does anyone know what are the specs and possibly a good alternative to the nissan oem part ? (part number please and/or link to order)... Tks.
  10. Body Lift spacers only (NO HARDWARE) , now available for the R51. Source your bolts locally and save ! Now available on sfcreation.com... all details available here : https://sfcreation.com/products/r51-pathfinder-body-lift-spacers-only
  11. NEW Affordable Body Lift Now Available If your are looking for an extra 1" or 1.5" without changing the suspension geometry, have a look at the newest addition to sfcreation`s product line. It comes with all the hardware and the installation procedure is probably the most complete one available on the net. Cheers. Steve. https://sfcreation.com/t/pathfinder-r51-platform
  12. I will chime in...even though I have tried to skip the subject because there is alot of "experts" on facebook and all that have their opinions and people that know me, knows that i'm not a big fan of arguing over a keyboard.. Some would say I lack diplomacy ..but i'll give it a shot Lifting a an ifs front with either stiffer springs or spacers does exactly the same thing to the half-shaft...which is to accentuate the angle.. I have said it many times, the quality of the half-shaft is essential and I am glad that someone actually made some tests and measurements... Thank you !... I have run my first trail pathy hard as I had 2 arb lockers installed on it and I ran at first the ac coils, then my spacers (2.5") and I never had binding in them. mind you they were OEM Nissan... One thing I did was to change the neoprene boots with thermoplastics ones made by rockford...I actually made a post about that explaining how I made them add this boot to their catalog...that's another story.. The only time I broke something with a cv was doing a full send climb, locked all 4 on a steep hill and my right tire got stuck in a rut while having the skinny pedal floored... that ended up in the halfshaft snapping in two.... not the cv joint....the shaft... you can barely hear it at the end :https://photos.smugmug.com/Trail-gazoduc-4-jours-juillet-2010/i-FrTDTBn/0/bf7a4533/640/broken-cv-640.mp4 That being said, I also did limiting straps on my struts in order to prevent too low of a drop..therefore saving the over extension... I have over 1000 kits sold and of course my kits are for the beginner off-roader that don't want to break the bank in order to start...but I have demonstrated that with some modifications (limiting straps, thermoplastic boots and good oem quality half-shaft), you can go a long way. That's all i'm gonna say as I just wanted to share my opinion and experience... I'm sure others will have something to say about this and I will respect that. Bringing a product to market is not an easy thing...there is always some that will say why it is crap and why it will not work or it cost too much etc... All I have to said to you is bravo and keep at it if you believe in it. I'm sure you'll end up with a great kit to sell and i'll be the first one to refer you guys when your kit is ready for primetime. S.
  13. Tks for the feedback.. I have created a poll on FB and I seem to have more answers there... The bolts are the issue right now and that is why I have doing this poll... S.
