vanuatoo
Everything posted by vanuatoo
  1. it tells me everything except the amount of fluid between L and H mark, that is my question.
  2. Hello people I've got 2003 nissan pathfinder SE 4x4. I've checked the transmission fluid as stated in the manual and it's on L mark of HOT Range. Does anyone know what amount of fluid should I add to make it to H mark, or at least tell me what is the safe amount to add step by step? Thanks everyone.
  3. Today I've checked my ATF level and it's a little bit high than MAX. How dangerous is this?
  4. If you have high mileage car, it's probably O2 Sensor P0138, that causes code P0300 to come. I would first change O2 sensor and see what'd happen.
  5. If you look at http://www.nicoclub.com/FSM/pathfinder/2001_Pathfinder/fe.pdf on FE-9 Page 1 and 3 denote to Heated Oxygen Sensor and it seems that bank 2 is the driver's side.
  6. My sticker says 30 psi on all tires.
  7. 4runner is better suited for offroad than pathfinder. 4runner is body on frame and has double wishbone front suspension. pathfinder is unibody and has struts in front. Expert offroaders know what I'm talking about 4runner has one weak point. Its nose is little bit down in stock form and first thing owners do is at least 2 inch lift in front and 1 inch in rear and the car is ready to go everywhere. If we compare 4x4 systems, all 4runners (4th gen, >2003) have traction control, stability control, DAC (Downhill assist control), Hill start assist control, also they have multimode 4 wheel drive system that allows you to engage 4lo without locking center differential, almost forgot they have torsen center differential. In real life, stock pathfinder has great off-road capabilities but it was not meant to be off-roader by design. I love my 2003 SE. I've had few cases when I engaged 4hi but when I did it worked great. Also 4lo and 1st gear greatly helped me several times to crawl down a muddy hill securely.
  8. My car came with these tires. It's OEM option I guess. on www.tirerack.com these tires are rated below average and I've read many bad reviews about them? I've driven 13k miles on them and they were good in light snow,rain and dry conditions. What's your experience?
  9. I could not find fully synthetic 5w-30. OEM 5w-30 mineral and synthetic blend 5w-30-s are available here. If there was Mobil 1 fully synthetic 5w-30 I would buy it immediately but it's not. BTW I read on some forum that Mobil1 0w-40 is really good for VQ35DE
  10. Hello guys I don't live in US and in my area I could not find fully synthetic 5w-30 oil. I've found this oil instead http://www.aral-lubricants.com/lubricants/com/automotive_lubricants/our_products/supertronic_0w-40.html That is fully synthetic and conforms to API SM. Do you think it's ok for my VQ35DE? My mileage is 57k miles.
  11. I have a moonroof and it's probably leaking. I'm gonna look at it today and see if any drain hole is clogged.
  12. It was raining for 2 days. Today when I was going downhill and did a hard right turn, one drop of water caught my eye. I looked up and there were two or three drops of water accumulated in the right map light. What do you recommend to isolate the issue?
  13. Manual says DOT 3, is it safe to use DOT 4?
  14. I'm going to flush brake fluid with classic method. pumping brake pedal and dealing with air bleeder valve. Do you know how much fluid will I need for that, max? is 1 quart enough for the whole job?
  15. I'm going to buy this grease gun and use it with 14.5oz cartridges http://www.amazon.com/Lincoln-Industrial-1134-Pistol-Grease/dp/B0002NYDZ8/ref=cm_cr_pr_product_top I've also found Mobile Grease XHP 222 grease that is NLGI No. 2 certified and is lithium complex based. I don't know if my car was lubed with the previous owner and it was not lubed in my hand since October 2008. Is it safe to do 4-5 shots or more? I don't want to have some problems because of "overdosing". I know that it's safe with U-joints. Also is there any notion from nissan of how much grease you should use every lubrication?
  16. I'm going to just remove drain plug, drain the fluid and add the same amount through the dipstick hole. Can anyone tell me what is the approximate amount that will be drained? I know that most of the fluid will stay in torque converter. I know that 8.5 liters is needed for flush. Without removing torque converter will it be more than 4 quarts?
  17. Hello I'm going to buy a socket set and try to do some things myself. I'm 99% sure that I need Metric sockets, just wanted to make sure.
  18. It's bad that fluid is dirty. There are 2 methods for changing tranny fluid. 1. drain and refill From factory manual 1. Warm up A/T fluid. 2. Stop engine. 3. Drain A/T fluid from drain plug and refill with new A/T fluid. Always refill same volume with drained fluid. Fluid grade: Nissan Matic “D” (Continental U.S. and Alaska) or Canada NISSAN Automatic Transmission Fluid. You can also use Dexron III but I would definitely go with Genuine Nissan Matic D. 4. Run engine at idle speed for five minutes. 5. Check fluid level and condition. Refer to MA-23, “Checking A/T Fluid”. If fluid is still dirty, repeat steps 2 through 5. 2. Flush This method requires a special machine that circulates new fluid through the transmission lines and ultimately pushes old fluid out of the transmission. This video demonstrates how it works. I've read somewhere that if the transmission is damaged (I don't know if your case qualifies) flush may finish off the transmission and this method is not recommended. If your fluid is pretty dirty it means that the drain and refill method will require several steps to clean it, because this method only replaces third of the fluid at a time. I would do the drain and refill and if I notice that tranny works better, repeat the steps to replace as much fluid as I can.
  19. On my 2003 SE 4wd there is a one nipple on the front drive shaft. On 2wd models the nipple is located on the rear drive shaft. I guess there is one drive shaft on 2wd models. Here is the picture from the FSM
  20. I've found many greases on Amsoil site and all the greases that are NLGI 2 are also synthetic. Mobil1 seems to have only one universal multi-purpose synthetic grease.
  21. I've looked at the manuals and I have only one nipple to grease and it's on the front drive shaft. Amsoil and Mobil 1 both have synthetic greases. Is it safe to use? I mean is this the same case as with engine oils where you can safely buy synthetic because it's better than conventional?
  22. I'm going to lubricate drive shaft and decided to buy a cartridge type grease gun. I've found many choices on amazon.com. Can you recommend one? I just need simple, cheap one. Also what grease do you use? Nissan recommends NLGI No. 2 (Lithium soap base) for drive shaft.
  23. every 3 months if I'm too conservative and follow Nissan's premium maintenance schedule. I plan to switch two dual change mode in a year. First change before summer on the 1st of June and the second change before winter on the 1st of December.
