40
Everything posted by 02_Pathy
Sorry to hear man Sent from my SM-G960U using Tapatalk
4WD Light Blinking When Put into 4wd????
02_Pathy replied to joshrichard's topic in 96-2004 R50 Pathfinders
Yeah you're gonna need the hand pump to fill up the t case, that's what I used Sent from my SM-G960U using Tapatalk -
Just ATF, same as the transmission Sent from my SM-G960U using Tapatalk -
When was the last time you checked your fluid level in the T case? That might have to do something with the light blinking. I would check that and put some fluid in the fill hole till it comes out. It could be low Sent from my SM-G960U using Tapatalk -
I know on some rigs the 4wd light will be on if you're driving around in 2wd with the hubs unlocked, it's just the computer sensing something wrong because the front end isn't rotating. But since it's on in 4wd it might be a little different. Did you make sure that the hubs are fully locked when switching to 4wd? They might've not fully engaged when you switched to 4wd perhaps, just my perspective on how I see it but maybe someone has the answer. Sent from my SM-G960U using Tapatalk -
Yeah of course man! If you have more questions feel free to ask anytime Sent from my SM-G960U using Tapatalk
I see some people do and some dont, probably be best if you had one on the bottom. I've had mine on for about 2 to 3 years on lots of trails and miles and I haven't any issues. Sent from my SM-G960U using Tapatalk
Not a problem man, the bilstein's i got didnt come with sleeves, I went to the hardware store and got a sleeve that fit perfectly for the top bushing I just had to cut it down ever so slightly then for the bottom one I just put it on at the time with no bushing as mine fit the stud perfectly. I didn't have the right tools at the time to make the bushing bigger and put in a sleeve for the bottom. So I just have a steel bushing for the top and none at the bottom currently. Also I did extend my brake lines with SS braided lines that are 2 inches longer front and rear. Sent from my SM-G960U using Tapatalk
Had a fun quick snow trip up in the mountains with my buddies. Aired down to 15psi and finally was able to test the new coils by flexing on a mound. They worked great, with the additional lift in the rear I dont hit my rear fender flares anymore so that's a plus. Downside is that I'll need longer shocks as I did pick up the wheel off the ground but was expected. Sent from my SM-G960U using Tapatalk
Not mine but thought I had to share Junkyard woes Sent from my SM-G960U using Tapatalk
Yup what@PathyDude17 said, OME HD (settled) and 1 inch spacer and thanks man! Sent from my SM-G960U using Tapatalk
Thanks man! Sent from my SM-G960U using Tapatalk
I love your rig lol Sent from my SM-G960U using Tapatalk
Huuuuuggggggeeeee difference hahaha Sent from my SM-G960U using Tapatalk
Before and after from OME MD to LR NRC 9449's with "32" inch tires and no spare tire in the rear so a little lighter in the rear. Also my driveway is not level Sent from my SM-G960U using Tapatalk
Here's a before and after, it's a little raked but it'll help with my load capacity for my road trip coming up. Also my driveway is not level Sent from my SM-G960U using Tapatalk
So after a quick test drive last night over various roads and a really rutty and bumpy road the springs feel a lot better than the OME's in terms of ride quality. Yes they are stiffer but not spine compressing and they handle the ruts really well. I felt that my OME's even though they were old and had lots of miles they felt like they "floated" over ruts and bumps. The new springs feel like they keep the axle on the ground at all times. Also I noticed that my body roll was a lot less too. Next step is to go up in the hills and test the flex capability of the springs and to see if I need to reinstall my bumpstops. Sent from my SM-G960U using Tapatalk
Alright installed the LR 9449's on the rig. Tires: 265/70r17 Suspension (before): OME MD coils with 1 inch spacer *also I have trimmed my fender flares about half an inch so take that into account Before measurements rear: both sides at 36.5 inches After measurements rear: both sides 38.25 inches 1.75 inch difference with fresh install I'll post before and after pics of the truck tomorrow but here's a comparison of the LR 9449 coils and OME MD coils with just the coil, 1 inch spacer and 2 inch spacer. Sent from my SM-G960U using Tapatalk
Alright so the LR 9449's were a success. Tires are 265/70r17 Before measurements were 36.5 inches from ground to fender with OME MD coils and 1 inch spacer (I did trim my fender flares about half an inch so I'll take that into account) After measurements are 38.25 inches from ground to fender with LR 9449's so a difference of 1.75 inches. Also too these are freshly installed with no break in as well as I don't have my spare tire on underneath the vehicle. So approximately for people with stock flares it would be 36 before and 37.75 after. I'll post what the rig looks like tomorrow when I have day light. Sent from my SM-G960U using Tapatalk
Well I cant wait to pop them in, I'll probably be expecting a 2 inch rake then Sent from my SM-G960U using Tapatalk
Yeah that's the plan, if I add the 1 inch spacers then I would definitely need to drop my PH bar down with a bracket. I'm just adding these coils for a 2 week long road trip I'm taking and need the extra load capacity so I don't sag with all the gear in the back Sent from my SM-G960U using Tapatalk
Not necessarily, probably more like 2.5 to 3 maybe Sent from my SM-G960U using Tapatalk
Got my new coils today straight from England, these things got here fast! They shipped yesterday and got here this morning. These are the LR 9449 coils, I'll post before and after measurements although I'm not sure if I'll be able to install these today but probably tomorrow Sent from my SM-G960U using Tapatalk
If I'm not mistaken I believe there are two types of spoilers on how they mounted. When I was at a junkyard I found a spoiler on a '01 which I was gonna take till I found out that the spoiler seemed to be bolted to the hatch and the bolts had to accessed underneath the door panel which also meant I had to drill my hatch. Then I heard other spoilers attach via the hatch hinges which would be much simpler obviously but hopefully someone can show pictures or have insight on how they mount, that was just from my experience on what I saw on the earlier face lifted R50's.
