101
Everything posted by mjotrainbrain
They do generally cost more than that, but not unreasonable. Of the orders I've done so far, I'd say $1.75 is a fair estimate of the average per LED. Comes with neat-o stickers too, for those horsepower gains. I would suggest red, I'm planning to swap one of my map lights to red (one still white for when I REALLY want to see). From what I've read, red doesn't hurt your night vision, hence why many headlamps and flashlights have a red light mode. I have pics of either my QX4 or 4Runner from the outside at night with LED's somewhere, but it'll be easier to just go take a new one than to find those, as well as some from the inside to give you an idea of how much you can see. It's a drastic improvement. I hope I see similar results with the bulbs in my climate controls, as the orange bulbs that come stock from Toyota really suck... The map and light bulbs I used were actually by another company now that I think of it, I'll try to track down who that is exactly via my Amazon history. I haven't used superbrightleds for anything significant yet, but for what I have used them for I've been pleased.
I've had excellent luck with superbrightleds.com LED's.
Long Travel Suspension Under An R50
mjotrainbrain replied to AllTerrainR50's topic in Solid Axle Swaps, Hardcore Custom Fab
Nothing commercially available, and I don't think I've ever seen it done before. Definitely going to need to be custom unfortunately.- 3 replies
- 2
- long travel suspension
- suspension
(and 1 more)
Tagged with:
Buyer's guide and/or things to look for or avoid?
mjotrainbrain replied to pndubisk's topic in 96-2004 R50 Pathfinders
Stock wheels will require spacers to clear tires larger than 31", due to clearance with the lower spring retainer on the struts. -
Another awesome and useful writeup. Definitely doing this!
That will be the hard part for sure.
Awesome to hear! Now don't go messing it up again.
No, the sfcreations spacers don't account for angle as you noted, and at past 2 inches or so that angle becomes far too great to let the camber be correctable, but I'm not sure that you could even make the strut bolt to the spindle.
The offroad club I'm in uses them. They're cheap and easy, and lots of people have them. That being said, other forms of radio communication would be fantastic to transition to, but that's not going to happen overnight, so yes CB's are still relevant for offroading and will be for a long time. When I have mine on when driving around I very rarely hear anyone talk, I usually just turn it off since I never heard anything. I can put up pictures of my setup later.
In-Channel Window Deflector Vent Visors
mjotrainbrain replied to AlabamaDan's topic in General Forums
Looks great! I loved the OEM ones on my Infiniti, but I agree about preferring not to put things on the paint. When I get some for my current vehicle I'm definitely going with in-channel ones, this little writeup is useful! -
I wish I had it screenshotted still, if you message TowndawgR50 he'll have the answers. That diagram is wrong if I remember correctly.
Steel (16") Vs Stock Rims (17") - Pro and cons of Steel rims on a R50
mjotrainbrain replied to Blueinfan's topic in How-To's
Interesting. I've never heard of that. Lots of guys on here run steel wheels. -
I had 15" steel rims on my '02 and the only issue I had was the center bore was 6mm too big on the wheels so I had to get some hubcentric rings to fill the gap (hub on the truck is 100mm, hub on the wheels I used was 106mm) which stopped some slight steering wheel vibration I was experiencing. He's probably thinking of the fact that a lot of Toyota's are lug-centric which can be a PITA when it comes to balancing, and some cheap-o steelies may not have the lug holes drilled perfectly enough or something. He didn't specify what these "issues" with the steel rims are? -
Well, at least looks good from the outside! Hopefully you can get this whole situation behind you soon.
2003 Nissan Pathfinder R50 Snorkel
mjotrainbrain replied to ReallyNotJordan's topic in 96-2004 R50 Pathfinders
Well, certainly looks good from a distance! -
Yup, on the R50 iirc none of the breathers go anywhere safe stock, although front diff may be ok, can't remember... definitely need to at least extent rear. Also should look into protecting some vital electronics. -
You're right not to be concerned. It's blown out of proportion a lot unfortunately. Basically manual hubs should only be unlocked when in 2wd. ANY other mode is 4x4 in some form or another, and therefore REQUIRES the hubs to be locked. Good luck with whichever hubs you get! PS. I recommend putting a binder clip labeled "HUBS" on the 4x4 switch so that you can't forget to lock them (it took me some getting used to) and so anybody who borrows the vehicle doesn't put it into 4x4 without locking the hubs since they won't know any better...or better yet, just lock the hubs yourself before you lend the vehicle to someone else.
98 QX4 Cruise Control Problems
mjotrainbrain replied to AlabamaDan's topic in 96-2004 R50 Pathfinders
Does it have the ICC (Intelligent Cruise Control)? No idea what year it became available, but my 2002 had it and the cruise stopped working due to the sensor failing. -
R50's are getting cheap - advice
mjotrainbrain replied to Inyourface1650's topic in 96-2004 R50 Pathfinders
Check for rust thoroughly. Especially front strut towers, hard to see behind the strut but that's where you need to inspect. -
1997 Pathfinder SE 4WD Modding Advice and Help
mjotrainbrain replied to tjreif's topic in 96-2004 R50 Pathfinders
Not without spacers, no. The issue is when you go larger than 31" the tire contacts the strut. You have to move the tire/wheel outward to give the clearance necessary for larger tires. After that you can cut to your heart's desire. -
Front sway bar Rubbing front CV
mjotrainbrain replied to Mattmill91's topic in 96-2004 R50 Pathfinders
Yup, looks like the sway bar end link snapped off so it's not even connected to the sway bar anymore. Fix that and you won't be having this problem anymore! It's possible that you have another issue that's caused the sway bar end link to break, but I'd put my money on just a random occurrence. -
I am unbelievably jealous of how rust-free your Pathfinder is! Pair that with this 4x4 conversion and you'll be enjoying it for many years to come.
mjotrainbrain's Build Thread
mjotrainbrain replied to mjotrainbrain's topic in 96-2004 R50 Pathfinders
I figured I should leave a trail to my current vehicle for anybody who's interested, here's the link to the build thread for my 4Runner: http://www.toyota-4runner.org/4th-gen-t4rs/258887-mjotrainbrains-build-thread.html It needs to be caught up as I've done the timing belt and some other stuff since the last update, and once I get a little rust sorted out it'll be time for the actually interesting stuff. If you want more of a day-to-day update you can of course check out my Instagram @mjotrainbrain and if you prefer a video format you can check out my YouTube channel mjotrainbrain616, but no promises of regular posting there. -
Feel free to send me a message if you want a walk through on how to link in a photo, it needs a long explanation to be thorough, it's easy once you know how but definitely still slow. Pics will be fantastic once you get em figured out.
