Charlie_Brown
Everything posted by Charlie_Brown
  1. Decided to show around here finally, threw some fluid in the master cylinder so I can get around to do laundry. Pulled a few people out with it. Parts are In so time to get busy after work.
  2. Good to know, I'll remember that when looking into a replacement parts in the future. Got stereo working and since I've never had it work before today was the day I realized I only have 2 speakers. I dont plan on going crazy with a sound system at this point but having 4 speakers is something I'd like especially since I have 2 extras laying around (nothing special). Thing is I have 4 speaker wires so I'm curious to where those are leading to. Not the passenger doors I know that much. Gathered more bits and parts for upcoming projects like adding D rings to the sides in the back to tie down an ice chest and what not
  3. Stealership is called stealership for a reason, we all know why and have our stories. I might call them and get a price for OEM to see if it's worth it but odds are I'll just get an aftermarket. Like I said it's just a hydraulic cylinder. How bad can you mess it up? Lol
  4. They are super cheap and something I've been considering doing. As for how well the aftermarket ones are built I'd be interested if you adamzam had any suggestions for the better brands or if your opinion is they all suck and for what reasons. I'd prefer not to buy a slave I can get for I think k ifs 12 dollars max (could be remembering wrong obviously) on RA for 35$ from stealership. I mean it's just a cylinder after all, not a lot to go wrong if at least one company is using good parts. While waiting for parts tore apart the dash to check out the guess job wiring P/O did for the stereo. Wasnt as messed up as I had thought it was originally. The deck is ruined (and refuses to turn off no matter what you do aside from cut power wire from it completely) but I have a new one I got for free anyways. Amp either isnt wired correctly or is ruined as well. New deck wouldnt play through amp, only played when I bypassed it on a seperate speaker. Gonna have to check more wiring and hopefully not have to get a new amp or tear apart doors to check speakers. I mean come on though, all 4 speakers being completely gone along with the deck itself? That would be beyond shocking. Upcoming projects I'm announcing to get myself in gear more or less to hold myself to, build a fold down table on the tire carrier for camping and jerry can holder (for possible Alaska trip in the summer). Get that damn temperature guage to work and realign/level the truck. Realistically not a lot to do if I were more motivated and closer to the majority of my tools.
  5. Cylinder on the clutch went out. I'm thinking it's the master since I can see where something has leaked around the firewall of it. Carpet dry though. Checked slave and seemed fine but who knows. Once master is swapped we will see for sure. Bummer
  6. Drove the 92 to the city and got it up to 100+ mph surprisingly without having to floor it. Speedo maxed out on the double lanes. Thought I'd only be able to do that on a downhill..still didnt make it to pick and pull in time lol
  7. Wd21 woth a 2wd 4wd r50 steering setup and moog parts. I have zerks on my UCAs, upper and lower bj, tie rod ends, centerlink idlers arm side and a few other places I cant recall off hand. All are aftermarket parts.
  8. Regressed all the zerks on the front end for steering and suspension. Passenger upper ball joint boot is torn. I guess it's not extremely surprising since the zerk stripped out and never worked quite correctly after but still annoying. Greased it anyways. Tightened more random bolts. Just kinda waiting around for some more snow
  9. That's the plan. Gonna go under the truck with a pressure washer and some heavy degreaser and take all the gunk and grime off the underbelly to expose nice paint (and probably a fair amount of rust most likely). I'm tired of the underside being dirty and with this oil leak just another reason to do so. If I was ready to bedline the truck I'd use some oven cleaner under it. Side note exhaust is rattling itself apart again. Time to go tighten bolts in the damn rain (&^%*ing hate working on this truck in winter)
  10. Took it up to Tahoe for Thanksgiving, it had seafoam in the oil so maybe just because it was warm and thinner due to the sea foam it was leaking oil faster than normal but still annoyong. Changed the oil out this morning and looked around at the pan. Cant really see well enough around the diff to see anything coming down from there. Seems like it's coming from the back by the sump but cant be sure. Put some cardboard under it so see where the drips are coming from exactly. Just one more reason to get the SAS underway even faster -apologies for any spelling errors or other autocorrects making sentences wonky
  11. The problem with it is it's too damn long so you cant bend it a bit to twist it like the vg30 which makes it just that damn much harder. Unless you drop the diff (on a wd21 st least) and pound it through that side I'm convinced the only thing you can do is beat the crap out of it with a flat bar and pry it up. Heating doesnt seem to change anything and sticking it back in freezing the tube and lubing it doesnt really change much either. A flat dipstick would be a preferable swap in my opinion. I like them better than the wire and weight but either work
  12. Swapped vg33 into the truck and used the vg30 oil pan since the 33 wouldnt clear the diff and I neglected to swap the tube out then so had to do it now. Wont regester the correct oil otherwise. Apologies for all my spelling issues and confusing sentences I post on these damn things. Phone cant keep up with my typing I guess. Makes me look like a damn child I know.
  13. As I figured it's just pressed in. Harder than a mother duck to get out but if your trying to replace yours keep walking the base in with a flat bar or flat screw driver till you dig enough to get under and start popping it up. Dont even waste your time trying to walk it like it did, even when the thing starts to come up it still wont budge. Just pry it up only. As a side note aftermarket headers makes the jobs FAR easier.
  14. Ripped the vg33 dipstick tube out and replaced it with the vg30 one finally. Pain in the damn ass, lots of hammering with screw drivers to pop it up ever so slightly since the 33 tube is so damn long you cant break the seal by twisting it. Ran sea foam through the engine to create a bit of smoke. Not as much as I would have thought though that is not at all a bad thing. Threw some in the oil and gonna shove the last can and a half in the tank. Web surfing for good deals on Craig's for parts to rebuild the 44 and 60 how I want them. Everything is so damn $$$$.
  15. On a side note to the original question, not positive if there is a write up however replacing injectors is easy. Take out the fuel pump fuse from the dash, turn the truck over and let it run till it does. Take off your gas cap and leave it off to decompress whatever else is left in the lines. Take off the intake manifold held down by like 5 or 6 Allen bolts (along with a lot of hoses, honestly this is the worst part). From here you can access all the injectors, they have a small c clip around the plug ins you need to take off (If I remember correctly that or it's just a clip) then just slip the connections off. If I'm remembering right there are 2 Phillip's screws holding down a plate for each injector you take off and that should be it. Then you just twist and walk the puppies out. Careful not to get any dust or dirt In the ports as you change them and leave the new injectors in the box until you are about to put in that one. I'd recommend going one by one just to reduce any chance of grime. Bolt everything back together and by on your way. If I've forgotten anything or left anything out my apologies however the process is very simple and straight forward.
  16. Okay so I know the dipstick tube has a mount bracket in the center of it connecting it to the block with a 10mm bolt however does the bottom have a bolt as well holding it in or is it just pressed in only? Removing the inspection plate is proving to be a serious pain for me due to lack of clearance for wrenches. Trying to wrestle this thing out here soon but it's hard especially since I cant even twist the base since it's so long and too many bends.
  17. If you have a leak/crack in your fuel tank and are leaking fuel out on the road or trail you can use a bar of soap and scrub it on working it in the crack to stop it temporarily. Cant say how long it will hold up but should be good for a few hours or so give or take
  18. Went shopping for 3/8 steel and struck out. Gotta call around tomorrow. Was raining cats and dogs all day so no work done but was able to go mudding. Give it a few days when I'm under the truck making the damn skid plate and I'll regret ever doing that lol
  19. Went wheeling and stumbled on a nice hard track, steep and big rocks off camber. Running on my 31s I wasn't sure if I was going to be able to make it but the old girl crawled right up it with minor wheel spin and not much complaint. Heard a very odd noise come out from the truck which I want able to track down getting out if the truck. No leaks aside from a bit of water that seemingly came out of the overflow tube. Whine stopped suddenly and never came back through the rest of the trail and driving through town. My best thought is power steering since my custom line is quite finicky (modified a few parts to fit against the frame with a vg33 swap). Planning to look under the truck tomorrow and double check everything but no leaks, oils fine and water is fine with no over heats. Two projects coming up this week, number 1 is to make a skid plate for the oil pan so I can stop stressing while crawling over larger rocks. Number 2 is to make a fold down table on the tire carrier so I can grill while on a trip this next coming Thursday. One week to do both.
  20. The truck has been getting louder these last two days to where it was obvious something is wrong with the exhaust. Today started the truck up and the thing sounded like a v8. Take a look under and the exhaust unbolted itself from the cat and rest of the exhaust so I'm running straight headers lol. One of the craziest things I've seen, either I've been running without bolts or the two bolts worked themselves loose and fell (I've heard stuff fall si most likely culprit). Got some new bolts for it with lock washers and what not so going to bolt it up tomorrow. Went to the wreckers and scored an owners manual, mud guard and dip stick tube. Planning to put it all in tomorrow, hoping that the damn tube doesn't give me a headache to get out again since I'm not dropping the pan. Lastly I noticed my rear bumper on the passenger corner is pushed in from backing into something while night wheeling. Not a big deal just thought it was interesting. Makes, making my tube bumper more of an importance.
  21. Made a metal plate out of an old washing machine for my switches since the plastic cover broke and I wasn't going to plastic weld it again just to have it break again. All drilled and riveted now. Went to pick and pull and scored a service manual from one of the trucks and pulled a few things off I wanted from it. Didnt get everything I wanted but got what was there. Went night wheeling again and backed into something. Didnt do Any damage but I really want a led back up light for the woods.
  22. Added ground wire to the aux lights and was going to change the switches since one was broken but I got the wrong type of switches like an idiot so now waiting for the correct ones to come in.
  23. Looking forward to seeing some updates here soon and actually seeing this truck just in general. Awesome build!
  24. One thing about the 78-79 dana 60s (from what the internet tells me) they are 67 to 69" making it 8.5" longer than a nissan If I'm remembering correctly.
