Charlie_Brown
Everything posted by Charlie_Brown
  1. Same, that's what stopped me from the swap
  2. Ratchet set Towels Zip ties Scew drivers assorted Needle nose pliers Fuses Straps, shackles, d rings Jumper cables Rachet straps and bunkie cords Spare belts Jb weld I think that's it
  3. Welp, nobody tired to stop me and I'm too lazy to scout a better spot so I went ahead and tore out the headliner so I could mount the inverter and run the power lines. Made a bracket and mounted that to the seam of the truck then drilled holes through the headliner for the bolts to come through. Ran 10awg wire since it was all I had at the time and I'm not using this inverter for anything real so it would have been sufficient but I ended up botching out and buying some 8awg and going to run that instead for peace of mind and possible expansion. Wires were easy to run and super clean. Drilled a hole and mounted the switch but need to hook it up. Now with the new wire and come grommets and conduit I can finish it tomorrow. It's actually a pretty good spot, out of the way of everything and it doesnt interfear woth looking in the rear view mirror or anything so overall I'm really pleased with it. Before I stick the headliner back I'm I'm going to clean and reglue it so it stops folding out. Now time to start sodering and crimping.
  4. Last time I took it on a trail I managed to finish off the ball joints and somehow ripped off my bump stops on UCAs. Not sure how that happened honestly.
  5. Easy acess while sleeping in the back or driving also major plus is it is out of the way. Just wouldnt ne able to stuff all 4 33s in the back anymore but I'm not the biggest fan of that anyways. Cubby? Not sure which cubby your talking about, I'm driving a wd21. Seemed like a nice spot for it though for those reasons along plus running the wire would theoretically be super easy. Personally I've not looked over every angle yet so if anyone has any good suggestions I'm open to it.
  6. Been doing things here and there when I can. Got it aligned finally, had to have the guy get at it 3 times but its whatever. I'm just gonna buy the 3 jigs here at some point and do them myself from now on. Began mocking up the air compressor today, bent a breather a bit so it will fit on the firewall. Now I need to make a harness. (yay...) Drove it to Yosemite to see how it is running, everything is fine but I'm gonna pull the thermostat this weekend and put some ATV around it so it doesnt leak which I think it might be. Was a bit low on water so only real reason why it would be since it is the only thing that's been messed with recently. Oh speaking of which I replaced that since it was bad. Making a jerry can holder. Almost done but going to finish it with my drill press rather than dicking around with a hand drill so that's held me up this weekend. Gotta lot to do this coming weekend. Going to run an inverter and hopefully figure out how I'm going to mount it to the headliner and make a harness for it, make the harness for the compressor and mount it, make back plates for the switches to me stamped at a later date, finish the jerry can holder and mount it to the tire carrier and mount the D rings in the cargo area along with clean it all out. Wish I could have worked on the carrier table, working away from home and having to devote a lot of time to my girlfriend when I am home on weekends is making it very hard to get a damn thing done especially with all the random house improvements I have been doing. Too much to do. Think I might ask one of my buddies if they are free to help me out and do some of the real simple crap. Just need a full 2 days or so of non stop go at it and I could get it all done myself but that isnt going to happen. I'll let you know what I get done
  7. I'm no expert on alignment but I believe it is positive camber i.e shims would make it worse. It's just kinda odd to me that only one side is 9ff while the other is straight when I have them sitting level (measuring from ground to bottom steering bracket and lca spindle bolt). It's almost like I have to have the truck sitting uneven with drivers side higher so I get negative camber on passenger side and am able to shim it out. That just seems wrong to me however.
  8. Let me be more specific here too, it's always just been drivers tire that was sticking out. Passenger side is fine caster wise
  9. I have a set of superlift control arms (that or rough country cant remember but whatever they are the same) and no matter who it's taken to I cant seem to get this truck aligned ever again now. The problem being there is too much caster where the top of the tire sticks outward (think reverse drift cars you see riding around on streets). I know the frame isnt bent because before having these on it was aligned perfectly and the truck just sat in a driveway for an engine. Anyone know what I might be able to try or recommend the dude that is trying to align it now to try? Or hell what did I do wrong I dont even know anymore. Just need this thing aligned for the rest of the year and afterwards I'm fast tracking SAS, tired of dealing with all the bs.
  10. Leveled out the truck, passenger tire turning right while drivers is straight. Cant say I'm terribly suprised. Camber is bad but I was just above stick height so not suprised st all, didnt want to have any lift on it since when your getting an allignment workers here seem to suddenly not know what the fskc they are doing and charge you 80$ for it pulling to the left and tell you your frame is bent when the &^%*ing truck had been perfectly aligned months prior and just sat in a driveway getting a new engine. Still pretty &^%*ing salty about that big &^%*ing O tires. Made the base of the older to hold my gas cans. Wanted to get it all done but the metal is American steel and hard as hell to drill through. Gonna finish it using drill press this weekend. Also had the new tires swapped on it and put the aluminum rims back on. Gotta order some spare parts to carry on the truck. If I'm gonna be driving to Alaska dont want to be stuck on the side of the road for something stupid like a belt coming off.
  11. Got the passenger side upper and lower balljoints torqued down and idler arm along with everything that needed to be rethreaded, bearing regressed and all back together. Respooled the winch and tied the tire carrier that got rammed in the snow and bent to a tree and bent it back straight. Now on to getting an allignment again after releveling the truck, make a gas can holder to the back of the tire gate and table finally that should have been done forever ago. I've only got 7 weekends at most so should be enough time if people let me work on it.
  12. Finally got some time to work on the truck for a change. Took apart the passenger side to do the upper and lower balljpints and idler arm since everything has play in it. Got both balljpints seperate and replaced idler arm but didnt have all my tools to take apart the disk from cv to get lower balljoint out so that's about as far as I got. Three hours goes by really quick. Next weekend going camping but hopefully I can make another three hours for the truck to finish up the passenger side and just have the drivers side to do.
  13. Picked up an air compressor for the truck for cheap. Too busy working on a v6 stratus to do anything about the truck.
  14. Ball joints are gone already. fskc Moog ball joints, passenger upper boot ripped almost immediately and wouldnt accept grease very well, the others are okay but have slop. It isnt that out of the ordinary considering the truck is lifted so your going to eat them faster but I feel like the boot not being pressed on made it go even faster unless I grease them weekly. Idler arm also has some play, it's the stock one from 92 so it's not really that suprising either. Stopped me from getting the new tires on and an allignment.
  15. 2wd service truck got stuck on the sheet of ice in from of the driveway and didnt want to back up without sliding further down the hill to the burm. Had to use the truck to strap and pull it into the driveway but unfortunately girlfriend is from San Diego and doesnt know snow of how to do this stuff and rammed into the back of me. Only damage between the trucks was my tire carrier got bent in pretty good. Still opens and closes so just cosmetic but makes making this table for it a bit harder. Gotta straighten the bar somehow once it stops snowing now. Heat and a bfg I guess
  16. Power steering belt decided it didnt like pushing the snow, jumped off and ripped itself. Swapped over 33s since the 31s were showing the wire belt and swapped a new p/s belt in autozone parking lot that was smaller and fits way nicer. Gotta love the sound super swampers make driving around as a daily. Waiting on the new set of 31s yo put back on the truck and redo the allignment.
  17. Got some nice parts from pick and pull. Even found a rear dome light cover (though it was too far degraded to really consider taking) and (only 1) brake light armor for the wd21. Picked up some switches for the defroster and the dash lights. Couldn't get one for the rear wiper but it's what it is. Also got some side heater vent covers which is pretty awesome along with my center heater vent assembly so I can put that back together finally.
  18. Replaced the temp sender and sensor, once the sensor got tight it broke off annoyingly. Easy out #2 works, thank God a had one otherwise I would have to take it all apart and tear it out.
  19. There is a big mountain range going though this state that I live on called the sierras lol. It can get fairly cold here, not as cold as some places but cold none the less lol
  20. I'm still waiting for mine to die for good. It doesnt want to power the led dome lights for anything longer than 10 minutes without dying but she still started in the cold when the locks and doors were frozen shut (annoying)
  21. Bled the clutch. Only took about 3 hours -_- ducking annoying but works now and everything is golden. Gonna draw up some plans for the tire table.
  22. Nah I have loose d rings that swivel up and down. The wd21 has the same kind of d ring on the floor of the cargo area. Though if I had some eye bolts I would have probably went that route instead.
  23. I've dipped them in flex seal so when they are not being used the banging and rattling around is less. Same idea as the rubber grommets (though much thicker than my flex seal coating) people put on their D rings on their bumpers. I can post a write up and some pictures though honestly I'd be suprised if anyone would want to copy my plans since they will be fairly crude and done with some scrap metal I have laying around. Got the slave and master cylinder installed before leaving to work. Once I get back on Friday going to add fluid, bleed and tighten as necessary
  24. Anyone else have the problem between work, weather and the old lady you cant get a damn thing done on your truck? Trying to get things started and finished within an hour these days. Master and slave cylinder are pulled off and new ones ready to go in. Gotta wait for tomorrow morning to wake up earlier just to finish the damn job that should be done tonight. Been dipping d rings in flex seal that I plan to mount in the cargo area along the side walls to tie down ice chest and camping @!*%. Traced out tire carrier on cardboard to finally make my damn table. All of this is on back burner, next weekend is the old lady's birthday -_- this is why summer is better, good weather and longer days to work
