mickmutante
Everything posted by mickmutante
  1. Maybe this pdf can help you... I found it usefull installing a power anthena switch... 👍 https://www.installdr.com/installdocs/nissan/PDF/647017.pdf
  2. Some dealers from ebay (mostly asian dealers) ship international 👍
  3. Check out the MAF... Maybe it is damaged or dirty... http://easyautodiagnostics.com/nissan/3.0L-3.3L-3.5L/maf-sensor-test-1
  4. Change the rear and front wiper blades... The rear blade was the original Nissan blade... 😬
  5. Nevermind... i found the camber specs at the factory service manual... SU section page SU-14 http://www.nicoclub.com/FSM/Pathfinder/2000_Pathfinder/su.pdf
  6. One more question... Which is the camber angle for a 1" or 2" lifted truck? Should i go for 0 degres? As i mention earlier i use the pathy at the city... Sometimes some light offroad...
  7. I have some questions... I know the font camber will be afected, so I bought a set (2 bolts) of Ingalls 14mm camber bolts for the front wheels... What about the rear wheels... Should I buy another set? Which is the "correct" angle for front and rear wheels with the lifting I am planing to do (1" or 2" on the front, 1.5" on the back)? BTW I am using 265/70/R16... Thanks.
  8. I tried to reset the ECU with the 1st and 2nd method posted on NicoClub Forum... But the service engine light was only on, it never blinked... So I supose that it did not work out.... I disconnected the battery terminals as Remus92 said... I don 't know if it works.... And I found i other forums that you can reset the air mixture ratio... With this method... http://nissanhelp.com/diy/pathfinder/projects/nissan_pathfinder_clear_self_learning.php Has some done this?
  9. No error codes for now... Just the "pending diagnostic" message.... Should I reset the ECU codes with one of these methods? http://forums.nicoclub.com/how-to-reset-ecu-clear-dtc-codes-t445684.html
  10. I finally have the Nissan O2 sensor... It is a Bosh sensor... Anyway... I will install the sensor next week, but yesterday I did some tests (voltage and continuity) on the two front sensors and they seems to be fine, I erased the error code (P0150) and take the pathy for a ride.... Then I re-scan to verify if the code still, but this time there was no error code, but there is a message that says that there is O2 sensor pending diagnostic... My question is.... If I change the O2 sensor, will this message disapear..? Or did I make a mistake erasing the trouble code before installing the new sensor?... Thanks.
  11. I found that the radiator was a little loose... And i found a brokn part in the passenger side on the bottom... I glue it with some espoxi resin and carbon fiber... I think it went well....
  12. I have been reading about lifting options for my 2000 Pathy... For now I have budget for front and rear coil spacers only... I want to do just 1" of lift with the set that cntryboy_88 was selling ( http://www.nissanpathfinders.net/forum/topic/41244-fluerys-spacers/?do=findComment&comment=769299 )... But I still having some doubts with the CV axle.... Does 1" of lifting damage the CV joints.. or boots..? I am not planning to install free hubs on the front wheels.... What if I lift 1.5" on the rear and 1" on the front... Or should I go 1" on the front and rear.? What about handling... I have been using the truck on the city, some times light off road... I am not planing to do rock crawling for now... Thanks.
  13. I bought just bought the sensor from a local Nissan distributor... I would have it next week.... 👍
  14. Yesterday i did my first ECU scan on my 2000 Pathy 3.3l, and the app throw me the P0150 code... Reading the repair manual the code is for the Front O2 sensor Bank 2... And the overall funcion check is at EC-200 page... I found this online tutorial with almost the same steps to diagnose the O2 sensor.... http://troubleshootmyvehicle.com/nissan/3.3L/p0130-and-p0150-diagnostic-tests-1 For now I could do the 3rd test... I want to do the 4th test... to test the continuity between the sensor and the PCM... My question is... How easy or difficult is to access the PCM.? I will try to tdo the rest of the tests... Any advice on checking the O2 sensor? If the sensor is damaged, do I have to change the two front sensors or just change the damaged one? What brand do I have to buy? Thanks.
  15. Yesterday I received the iCar3 OBD2 wi-fi module, and install the DashCommand on my iPad... They work good on my tablet... This weekend i will work on th trouble codes... 👍
  16. I just installed the iOS full version of DashCommand... Looks good and works good with the iCar3.... Thanks a lot. 👍
  17. I bought a wi-fi Vgate iCar3 Obd2 few weeks ago, and today i finally received it... http://www.aliexpress.com/item/2015-Newest-Vgate-iCar3-Wifi-Mini-ELM327-Vgate-OBD2-ELM-327-WIFI-Car-Diagnostic-Interface-Support/32376945531.html I have an iPad and iPhone, so the idea is to use it iOs system. On the instruccions, the app to use is the Accurate (for iOs) but i cannot find it on the apple store... I downloaded iOBD2, but did not recognise the Vgate... So I downloaded EOBD-facile... I think it is the trial version... Because almost everything it is blocked... Wich app do you use iOs systems? Thanks.
  18. I found a leak on the coolant system... After tracking the leak I found that this hose was loose... Son I thighten the scews... And problem solved..
  19. After reading and comparing, I decided to buy the Vgate iCar3 OBD2... I will have it in a few weeks... http://www.aliexpress.com/item/2015-Newest-Vgate-iCar3-Wifi-Mini-ELM327-Vgate-OBD2-ELM-327-WIFI-Car-Diagnostic-Interface-Support/32376945531.html
  20. I want to read the codes from my iPad and iPhone, so i will go for the wifi module, I read that bluetooth module do not work with iOS system... Is there any difference between the iCar2 OBD2 modues and the iCar3? Or it is just chinesse marketing? The price is almost the same depending ontp the Amazon or Aliexpress seller....
  21. I saw this one on ebay.... http://www.ebay.com/itm/ELM327-WiFi-OBD2-OBDII-Car-Diagnostic-Scanner-Code-Reader-Tool-for-iOS-Android-E-/252163954407?hash=item3ab62496e7:g:k~AAAOSwwbdWQVX0 Does they domthe job? I think they are really cheap... Has someone try them? Thanks
  22. I have done some "easy" repairing... Change the power anthena, install an on off switch for the power anthena... Wash the pathy... Hahahahaha 👍, install the cabin filter....
  23. I live in Bogotá, Colombia, I do not know if in some auto parts stores they do that... I am sure my mechanic does do the scan... But from my house to the mechanic shop it takes me 2 hours in heavy city trafic... So i go there when it is really necesary to go....
