13
Everything posted by mickmutante
mickmutante replied to fleurys's topic in R50 FAQ's & Pinned Topics
Update... Year: 2000 3.3L LE Superlux Lift : front 1,5" Imal springs; rear 1,5" IronMan springs. Wheels : 16" Stock Tires : Firestone Destination A/T (265x70R16) Notes: No other mods, no rubbing... -
Changed the outer CV joints and boots...
I found this tire size calculator... Very usefull for comparing the size of tires 👍 https://www.tacomaworld.com/tirecalc
I found this tire size calculator... Very usefull for comparing the size of tires 👍 https://www.tacomaworld.com/tirecalc -
Headlight high beam flickering when low beam is on.
mickmutante replied to Tommi's topic in General Forums
Maybe some rust or dirt on contact points... Or a loose cable 👍 -
IronMan front springs where out of stock... So the front springs where changed by Imal's 1,5" lift...
StrongMan>>> IRONMAN..... Sorry...
A week ago I changed the standar front and rear coil springs for StrongMan (rear springs) and Imal (Local brand front springs). StrongMan are 1,5" lift... Imal suposed to be the same... But they are almost 3"... So this monday we are going to change the front springs for StrongMan 1,5" lift...
Today i as going out with the Pathy, turn it on, and put reverse gear... The truck did not move... It was stocked... Like it had the hand brake... Try again... And stocked... So i lift it and notice that the rear pilot side wheel was blocked... I removed the wheel, and then the drum brake... The shoes were like glued... I used sand paper to clean the shoes and drum... Reinstall the drum and wheel.... And voilà... Fixed for now...
This is the pork sandwich... With the "motor oven"... And friends... 👍... And Moka 🐶 https://instagram.com/p/BGA1fpDRv0S/
Welcome to the forum!
Yesterday at the "Embalse del Neusa"..... Using the heat of the motor as oven...
mjotrainbrain's Build Thread
mickmutante replied to mjotrainbrain's topic in 96-2004 R50 Pathfinders
These two videos can help you to understand 4wd 👍 -
Yes, i know that.. but didn't work out out with these... I do not know why... Maybe too "chinesse" filters.. hahahahahahhaa
I bought the filters form an chinesse ebay reseller... They were few milimiters bigger than the space available... So i have to sand the filters to make them fit...
Could not open the image... Forbiden sign....
I did a step by step tutorial months ago... It was for my 2000 R50, I hope it helps 👍 http://www.nissanpathfinders.net/forum/topic/41306-how-to-install-cabin-air-filter-for-r50/?hl=%2Bcabin+%2Bfilter
Changed the Philips fog light bulbs for Osram NightBrakers... They seem a little whiter and brighter...
After seaching some on the web for cheap... Really cheap fog lights to cut them and adapt the LED bulbs... I deceided not to buy them... They where out of the budget... I am planning to install Fleury's spacers, buy a hitch, and have to change CV joints or axles... So I bought Osram Night braker H3 bulbs.... I took those pictures today... The light and the cel camera doesn't help at all.... But the Osram bulbs are a little whiter and brighter than the Philips....
At my parents country house....
Going to Look at `96 This Evening...
mickmutante replied to DRAGON64's topic in 96-2004 R50 Pathfinders
Congratulations!! You will have lots of fun with the Pathfinder!! -
Here >>> http://www.nicoclub.com/FSM/Pathfinder/
I washed it.... 3 months without wash....
Wow! Nice ride! 🚙💨 More pictures!
Trying to find a great lift kit for my Pathfinder
mickmutante replied to leviwinterton's topic in General Forums
Leviwinterton, sorry for hijacking your topic.. 👍 Fleurys, I am buying a set of front and rear spacers from a NPORA member who bought the from you... The lift would be 1.5" on the rear and 1" or 1.5" on the front... My question is... Do I have to crank the torsion bars to.?
