133
Everything posted by TowndawgR50
OME HD springs gave me slightly more than 1.625" of lift and haven't sagged at all in almost ?6? years. Even before I ran a steel bumper I had no top out issues paired with a KYB strut. Never quite figured out why they list the springs at a little over half inch because that's never been the case for me. I suspect the Ironman springs will be similar but I cant say for sure since I've never been in a vehicle with them or know anyone personally. There are a few accounts of them on social media from folks who have done front and back and claim they work well with no issues. I'm definitely interested as they're local now and really good with customer service. I have their awning and have been looking at the water storage they have as well. Lots of reasonably priced items that give other brands like ARB a run for their money. Only downside is the obnoxious logo on our awning. Some may not like the bright green springs either but for the price and availability its not a bad option As for camber bolts- its not a bad idea to have some to bring it back into spec as you'll definitely see some positive camber but I cant recall if 1.5" of lift is enough to throw it out of whack. Definitely get an alignment after lifting.
Ironman America offers front and rear springs. Located outside of Portland, OR. Dont know anyone that has used them but the price is on par with OME and they are in stock as of 1/27/2021 https://ironman4x4america.com/categories/?_bc_fsnf=1&sort=pricedesc&Make=Nissan&Model=Pathfinder&Year=2001
Land Rover rear lift spring install
TowndawgR50 replied to Bax03SE's topic in 96-2004 R50 Pathfinders
I know this is pretty late to help but for future reference Ironman America offers both front and rear springs. They're USDM HQ is outside of Portland, OR. I've been curious about the performance. Price is on par with OME. They list them as in stock as of 1/27/2021 https://ironman4x4america.com/categories/?_bc_fsnf=1&sort=pricedesc&Make=Nissan&Model=Pathfinder&Year=2001 -
Front control arm bushing replacement
TowndawgR50 replied to okanagan's topic in 96-2004 R50 Pathfinders
Yup. Pretty unpleasant experience BUT the switch to poly ( I swapped all suspension bushings to poly) was worth the work in my opinion. The performance gain is a stark contrast to OEM rubber. If you just want a OEM replacement get the whole arm. I had access to a fully equipped machine shop and made some "quick" fixtures to enable me to use a hydraulic press but it was not worth it in the end. One cocked sideways and started to damage the lip so I had to burn the rubber out (also very unpleasant) and bore the bushing housing. I'd argue that the odd design was intentional to generate revenue for Nissan via parts sales. -
No thread. Just open the light, pull the lens and take it down to your local Tap Plastics. They can size it to the existing piece you have and cut it right there on the spot. If you prefer to do it yourself just find a high quality polycarbonate in your choice of color and cut to size. Just make sure to reseal it or you'll have water intrusion.
I opened the light, removed the old clear lens and had new amber lenses cut to match. Coatings and tints just dont create correct hue and richness of color. I tried both
A little before and after. Cleaned up the rig from last weekends trail run with @RainGoat
Absolutely. The brilliant white that it was before reflects off everything, including my hood. Makes it somewhat uselss unless there is perfect conditions. It would reflect off rain, snow, dust signs etc. With the switch to amber there is very little of that and the light penetrates much further.
Nope. Just the older international style of Nissan emblem.
Trail run w @RainGoat
CV shaft variations prone to binding
TowndawgR50 replied to hawairish's topic in 96-2004 R50 Pathfinders
My 2001 LE CV Brand/PN: OReilly's Import Direct/NI8185 Markings: "KAI 025" on the outer cup band. Has a smooth round outer cup Strut Brand/PN: KYB-335032 & KYB-335033 Spacers: SFD w 4.75" strut spacers + OME HD coils Binding: 0 currently, had 2" spacers on top of the OME HD when I first lifted the truck before installing my SFD and broke 2 CV axles but never observed issues at full droop though there was likely some Pines to Spines 2003 LE "Gambler" CV Brand/PN: uknown Markings: none Strut Brand/PN: unkown Spacers: Pines to Spines 4" SFD Binding: 0 I currently have 3 sets of CV's to look at- My 2001 which has new units from ORielly's, a used set of what @02_Pathy thought were OEM and the set on the Gambler, which look identical to the assumed OEM set. The biggest difference I can tell right away is the entirely smooth and round outer cup on the OReilly part whereas the "OEM" units have a step in the casting. Assuming the 190K 2003 Gambler has never had a CV replaced and @02_Pathy really did replace OEM units I think this may be an identifying trait? Also worth noting- @02_Pathy installed a brand of CV I've never heard of and has had no issues since, although they have the same part number as the new OReilly units in my 2001 and could just be a re-branded part. He gave me the "OEM" units in their boxes -
PathyDude's R50 Projects (03 SE 4x4)
TowndawgR50 replied to PathyDude17's topic in 96-2004 R50 Pathfinders
That was both odd and a huge bummer because we were using @hawairish truck to tour the state parks and ruins. Heard the noise after a relatively flat and smooth FS road around Sedona. Found the swaybar snapped clean and was dangling. There was a vastly different and unstable feeling at freeway speeds in turns. Upon leaving Sedona we hit 17 which is a couple hours from PHX and mostly downhill if I remember correctly. The initial lean isn't the concerning part, its the opposing "sway" the springs have which causes a back and forth motion compounded by driver input to correct it. Kinda like speed wobbles on a skateboard, except slower. I'm glad you have replaced it. I know a lot of folks like to take the rear sway bar off for supposed increase in rear axle articulation but that just isn't the case with these rigs. I have retained my sway bar as has @hawairish and I can flex as much as folks without it, if not more due to my extended rear trailing arms. For something that's used strictly on the trails there wouldn't be an issue but for anything that has to drive to the trails, let alone serves as a daily/only vehicle its a huge gamble and could have disastrous results. #GetYourSwayOn -
What?! No link to that video?! I'd love to get my hands on your QD32. Share the video!
2000 Pathfinder body and parts diagram?
TowndawgR50 replied to MTGunner's topic in 96-2004 R50 Pathfinders
Any Nissan FSM ( Factory service manual) can be found here https://www.nicoclub.com/nissan-service-manuals -
Not my rig but I was lucky enough to pilot this beast through AZ recently. HUGE thanks to @hawairish and his family for hosting us and letting the wifey and I use his vehicle to tour the Sonoran desert and the Colorado plateau. His rig is the most well sorted R50 I've seen. Everything is so well tuned and thought out. From the numerous mechanical upgrades and trick incognito pneumatic setup to the camping/fridge organizer in the back. It left me super inspired with a laundry list of things to improve on my own truck.
Sounds like the differential pinion. Are you lifted at all? Increased angles on the pinion will cause this. Do you also have any on/off acceleration related clunks or mechanical engagement type noises?
Sorry to hear this! The past 6 months has been rough for R50 owners. At least its just the bumper and some minor body damage. I don't have one handy but I know there are a few donors in the yards around us. Tacoma has 2 of the same body style, Lynnwood has a couple and so does Arlington. There is a yard near @zakzackzachary in the peninsula that supposedly has a few as well. Not sure on the colors but you should ar least be able to find a bumper support.
Took a quick run with the dogs yesterday to play in the snow
Thanks!
I wouldn't tow with a rear differential lunch box. They're great for a dedicated trail rig but under load they lock the rear axle up, which would be most of the time with a trailer.
Lol, was just going to say and @hawairish beat me to it. I do have a complete axle swap that Im not going to use. I cant use the lunchbox setup for my rig as I need to tow a trailer.
There are no lunchbox locker options for the rear axles on R50's without switching from 33 spline to the somewhat hard to find 31 spline axle shafts out of an early Supercharged Frontier. @hawairish covered the details in another thread but its a pretty involved job if you can find the axle shafts
Thats pretty close to a few of us for sure. I'll definitely try and tie you into the next gathering.
