320
What's there to be pissed about? The point of hubs is to prevent the front drivetrain from creating load via the front wheels. The driveshaft spinning from residual drag from the t-case? The ATX uses clutches that don't fully disengage...it seems expected to me and is probably negligible overall. Keeping the driveshaft removed seems asinine to me because it's not the problem. Your boots are splitting because your AC springs are maxing out the suspension and causing the boots to always be stretched. This is also bad for the CV because of a significantly higher amount of oscillations than if it were flatter. Guys that have less/no lift or an SFD will always see less boot wear because their boots aren't constantly stretching out. The problem is the AC springs and nothing else.
Constant or Variable Rate Springs
hawairish replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
The part number appears right, but that's not the right spring and it's not going to work. R50 springs don't have pigtails, front or rear. -
You guys are killing me. The notch for the prop rod is on the top edge, about 40% over from the left. It’s present on EVERY cover. The cutouts are for the other tire carrier. If you don’t have the rear mounted tire carrier, don’t buy this cover with cutouts. Buy the one without cutouts.
Still not seeing what you’re talking about. All the bumper covers have notches for the tire hoist rod...the undermount spare tire carrier. The cut outs you’re talking about are for trucks that had the rear spare tire carrier. You don’t need the cover with the cutouts.
Got any examples/links? I'd be surprised if any lacked a cutout for the rod, and scanning ebay and RockAuto, I'm not seeing any that do. They come with and without holes for the rear-mounted tire carrier, though.
@Rockclymr Seen any other info about them? Nothing at the website, and only saw a pic of gears, but no mention about them. Waiting on a reply from them.
No sweat. It's a good topic to bring up and clarify, especially here. Every modification (or even repair, to some degree) is opportunity/risk to either improve or worsen the vehicle's capabilities, and in nearly every scenario—SFD or otherwise—upgrading one part usually means some other part is inherently "downgraded"...i.e., there's always a new weak link. An SFD is like any other lift in that it raises the center of gravity of the vehicle, which increases rollover risks. The fact that it moves the subframe away from the chassis also means some degree of flex is introduced, especially laterally in this case. If the install is done correctly, the truck can perform safely, but it's never without other risks. Something to also clarify, which was discussed in another thread and PM, is the introduction of driveline vibration and/or noise. Lowering the subframe does change the angle of the front driveshaft, but to date, we've not heard of any complaints related to that. However, the new angle can amplify vibrations if the bushings on the front axle support brackets are fatigued. For most of us who run manual hubs, this can be mitigated. In most cases, it's not a problem. As for the rear driveshaft, keep in mind the SFD has no impact on the rear suspension. If you exceed a certain amount of rear lift (let's say 5"), the driveshaft will be at a higher operating angle and may cause noise. On my truck, I run 6" of rear lift (9448s + 2" spacers) and I have an occasional buzz when I feather on or off the throttle due to a brief load-loss between the driveshaft and pinion at the u-joint. When load is applied between the two (99% of the time), I don't have any noise or vibration. But again, this is not a result of being SFD'd...it's a result of too much rear lift. Notably, we include a PHB Drop Bracket in our kits because it's presumed that if you need an SFD, you'll have an appreciable amount of rear lift that would benefit from a bracket (of course, this is something we can delete from the kit for those who already have a PHB bracket).
- 53 replies
- 5
- pines to spines
- p2s
(and 1 more)
Tagged with:
I've been running a SFD on my truck in some shape or form for over 6 yrs, and I've wheeled it hard. Plenty of guys have had their own homebrew or even Krypton Fab kits for longer I'm sure. But, I'm not sure what long term assessment will help answer your question, though. SFDs have been around for well over a decade, and in a form that we've felt is inferior due to use of simple 4"x2" tube with high-radius edges. I'm not aware of any failure with a missing link installed. The failure I'm aware of was on a buddy's truck and it was without a missing link. I installed the SFD on it in 2015, and the truck was in excellent shape; SoCal, rust-free truck. The failure occurred in 2017. We (my buddy and I) believe the failure was directly due to a hard curb bump on the passenger tire, which caused the sheet metal layers on the chassis to flex a little or possibly a compromise of the weld on the subframe. Over time, it fatigued until failure. The missing link in this instance would have absolutely resisted that force initially and would have likely caused the LCA to buckle instead. Regardless, the ML is deemed required, and anyone running an ML would also greatly benefit from a skid plate, which also helps square up the frame further. To some extent, I'd say a mid-skid is required if running a missing link to ensure the link itself does not snag anything while wheeling. These are general things that become more and more important to have to best utilize the truck.
- 53 replies
- 4
- pines to spines
- p2s
(and 1 more)
Tagged with:
So after one day of this thread being started, we've had a great amount of interest in kits! We're trying to respond to everyone as quickly as possible. As a heads up, we should mention that we're going to try to fulfill requests for kits in batches. Right now, we're basically down to a partial kit from our original batch of 8 kits, and we're in touch with the guys who we can help in the near term. As for the next batch, we're looking into new material costs, kit interest by size, and our schedules to see what we can pull off in short order. Since we plan to have a bit more variety in kits, this should also allow us to keep a few other items in stock or sell components separately, since there's also been a good amount of interest in that. I also want to request you post up any questions you have about the kit here, so we can share answers with the community. We've already gotten a few really good questions in PM's...there's a lot to know about SFDs, that's for sure, and historically, this information has been scattered around for the past decade. We hope to consolidate all that information here. In the meantime, let me expand on a few of the required items/purchases that TowndawgR50 mentioned in the initial post. These are the parts that most guys may already have, or have access to (via other posts around the forum), that we've ultimately decided to not include with the kit. In most cases, we can help with source or fabricate the parts, but the parts just haven't been deemed "kitable" for one reason or another. Also, we've got an instruction guide that'll go into much more depth than here. If you need further clarification, let us know. Longer Brake Lines: The SFD requires longer front brake lines, simply because of the nature of the kit. Custom braided lines can be sourced from various retailers, but 2008-2017 Rogue brake lines (OEM or aftermarket) can also be used. I run Rogue lines on my truck, and TowndawgR50 runs custom braided. Same is true for the rear brake lines, though this is SFD-agnostic. 98-04 Frontier 4wd and 00-04 Xterra 4wd rear lines are a suitable replacement (also what I run). Power Steering Hardline Support: There's a high-pressure hard line that runs between the power steering pump and rack that has a mounting point on the crossmember. The hardline is actually a hardline that has a heavy duty hose crimped to it, and there's a factory bracket near the union of the two line types. When the SFD is installed, that bracket must be detached from the crossmember to allow for slack on the line when the subframe is dropped. We've chosen to not include a universal bracket for this because relocation of the line has been rather variable on all our installs. The length of the bracket doesn't correspond to the height of the SFD because the steering rack has to be rotated a few degrees, and the line may need to be hand-bent a tiny amount to either allow for slack or clear the bolts on the rack bracket so they can be accessed for high-torque tightening. In the end, the final relative position of the OE bracket can be 2"-4" from the crossmember, and may also move forward relative to the cross member another inch or so. Additionally, the racks between early and late model R50s were different, as were the lines, positions, and even the bracket itself. Ultimately, no single bracket would work in every situation, so it's best that the installer make a simple bracket once the installation is complete and the resting position is determined. The bracket can be as simple as a vise-bent strip of aluminum or other similar strapping with a pair of holes. No matter the approach, this line should be secured, as vibration in the line may cause stress at the banjo fitting. Extended Sway Bar Links: This applies to the rear suspension only. OE-length front sway bar links are fine, since the sway bar positions are relative to the subframe. We can provide extended rear sway bar links, but they are not included with the kit since they're based on the amount of rear lift (which isn't a factor for SFD installs). Missing Link: Most people know about these and have one installed in some shape or form. For those not familiar, we're calling it a structural device that reduces flexing on the subframe by linking the lower control arm rear mounting points. This was not a factory item, but this community has long agreed that it should've been one, if for nothing more than to stiffen up the front or mount skid plates to. However, we have deemed the ML as a required item that must be either purchased or fabricated because the nature of the install increases leverage on the chassis where the rear extensions of the subframe are mounted. And yes, we have seen a failure on an SFD-equipped truck that did not have a missing link installed. Notably, we don't have a specific ML product, but it's something we can fabricate. Skid Plates: These can't be reused because the mounting positions will have changed. I also want add notes on the following items: Existing Strut Spacers: most guys are already running static strut spacers, which means the OE strut mount has been modified to accommodate longer bolts. Our strut spacers are designed to use the OE studs on the mounts, which means that it may be necessary to disassemble the strut to remove the bolts. We are able to provide a set of bolts and nuts to replace those for a small fee. Alternatively, if the OE studs were retained, they can probably be reinstalled if the OE mount was not further modified (i.e., drilled, welded). Otherwise, new mounts may be purchased from Nissan dealers. Existing spacers should not be stacked with our strut spacers. Camber Adjustment: Our strut spacer do feature a slotted body that allows for some amount of camber adjustment. However, these are primarily used for gross adjustment only; it's highly unlikely that an alignment shop will touch these for service work. The use of camber bolts is highly recommended, and may be required to dial-in alignment. The guys in our initial group have not had any issues getting a shop to align their trucks with a single set of bolts (I want to say one of the trucks didn't use camber bolts at all). Our trucks use 14mm bolts. As stated above, we've got installation instructions, and all of the above points (and more) are covered in it more detail. We're considering breaking out some the topics into smaller sections (it's a long read as-is) before posting links to PDFs and such. But for now, we'll trickle out that information here so that it's a bit more public.
- 53 replies
- 8
- pines to spines
- p2s
(and 1 more)
Tagged with:
Hawairish and TowndawgR50 are teaming up!
hawairish replied to hawairish's topic in 96-2004 R50 Pathfinders
Yikes. We've not replied here for a while. We still need to get a dedicated SFD thread going, too! Despite the delay, we've actually stayed busy with various side projects and other personal priorities. We've been very passive about the SFD sales, but perhaps also deliberately to ensure the equipped trucks in the field continue to yield satisfactory results. Last fall, I spent a few days wheeling trails in Sedona with @Rockit, who's got one of our initial kits, and the results were great. He's put plenty of miles on his truck "commuting" between CA and AZ to visit periodically. We've sold additional kits from our initial batch, too. In fact, @Ravens794 is looking to install his this weekend (teaser: the orange powder coat looks great!). @jlduthie has unfortunately been waiting for the border to open to grab his kit and for the weather to warm up to get it installed. And we're still waiting to help @RainGoat to get his installed (lol). That said, we're excited to have gotten those out and are looking forward to the installs this year. Jake and I are in discussion for the next batch of kits, including component improvements/redesigns and production quantities. We've also had some interest lately for just the strut spacers, so we may offer that this year. We also just finished our first revision of proper installation instructions; if I'm being honest, it's the authoritative document on SFD installs...in small part because no one has ever compiled them that we're aware of... but mainly because of the level of detail we put into it. A true brain dump from the several installations we've done. It'll go a long way towards demystifying the process, as well as providing comprehensive information in preparation to the installs. It's the perfect companion for these kits. Anyway, despite the hiatus here, we're still around and working on things. With 2021 having a much more positive outlook than that 2020 bull@!*%, hopefully we'll see more progress. Thanks for the interest! At this point, I think we're beyond our test phase, but hopefully we'll have some options and more updates soon.- 155 replies
- 9
- sfd
- trailing arms
(and 3 more)
Tagged with:
It's a lot of work involving rewiring and modifying the dash, as this is a very specific R50 configuration. Nothing can be just swapped around, and every time I see someone attempt to do it, I cringe at the results. Sift around the NICO forums for a few threads: https://forums.nicoclub.com/pathfinder-forum-qx4-forum.html This one in particular has been around a while: https://forums.nicoclub.com/update-removed-navigation-and-rewired-automatic-climate-control-t483201.html
This topic has reminded me that my knock-off fob case is due for replacement. It's such a knock-off that it says "Calsonis Kansel" instead of the actual OEM company Calsonic Kansei.
The fob can't be used to open the rear glass hatch. The keyless entry system doesn't support it. Both of my fobs are non-OE 3-button, but both circuit chips have 4 buttons. The hidden 4th button on mine sets off the panic mode.
Nissan Patrol overhead switch panel
Great suggestions in there, especially cutting the extension cable. The ribbon cable on that sort of application also helps, since it can be flat or rolled up to wrap around existing wires...and being power wires for PC application like what you provided, they'll do well handling 12V and a bit more current. And definitely make wiring diagrams! -
By my estimate, most applications should be doable in 8 wires (12V, illumination, and 6 signal leads) while using a ground in the roof (I presume there's a good one on the sunroof motor). If you don't plan to have the switches handling the load, you can get away with a smaller gauge wire and a relay module. With an array of modules, that wire could then become one or two multi-conductor cables (i.e., a Cat6 cable can handle the voltage, but only a small current...but it allows the use of other RJ45 connection means, which might help things). But, I don't think routing wires up there is too problematic. Not having a rat's nest above the panel is the real challenge. It would be terrible if removing the console meant disconnecting two dozen slide connectors. I use pinned harnesses for this sort of stuff. The do sell Carling switch harnesses, but they look really bulky. -
No problem, Gerry! Please keep us posted on this project, it sounds great! Oh, and we love pics here at NPORA...post some up when you can. Again, having looked into an EV conversion recently myself (on a far simpler Nissan platform...practically without any electronics), I was definitely intrigued by the idea, so I absolutely want to see (and learn and contribute) more. A particular Ford Ranger done by EV West several years ago struck me as the standard I'd want to achieve. I'm planning to rebuild the engine and transmission later this year, so you've still got time to convince me (I do have shiny new headers in a box, and an eyeball on a turbocharger kit, btw...). Sounds like you've had a great career, but sorry to hear about the accident. Better to have some mobility than none, I'll say, so I'm glad you're able to make the most of it and hopefully there's still room for improvement. This project is one helluva way to prove what you're still capable of. As for the conversion, I was definitely seeing a declining cost for equipment, especially for salvaged OEM batteries. For sure, an array of standard car batteries isn't any cheaper today than it was a decade ago. And pretty funny to hear you've got two of the BMW i3 batteries already...it feels like those are almost brand new cars still! Display looks pretty slick, too. (BTW, for anyone looking, remove the "." from the URL.) About the R51 transfer case...just to be sure, does yours have the "Auto" mode on the dial? I knew the R51 to have the ATX14B All-Mode case (some R50s and all QX4s have the ATX14A), but I did not realize that the FSM also specs the TX15B as being an option (this was the only option on the Frontier and Xterra at the time). The R50 uses the TX10A case, which is a lever-driven Part-Time 4wd unit, while this TX15B unit is an actuator-driven relative that lacks an Auto mode on the dial switch (that is, 2H/4H/4L vs. 2H/Auto/4H/4L). More importantly, the TX cases lack the clutch-plate system—and consequently, a lot of complexity—that's in the ATX cases. Presuming you have the ATX, I feel like it'd be worth exploring the TX...spitballing here, but probably easy to find, I'd expect it to be a direct replacement, share similar (same?) wiring harnesses, same output flanges, etc. I'd probably still utilize the actuator system if I could (it read like there's a position sensor in it, too), if nothing more than to save the trouble of cutting into the transmission hump to install a lever and linkage, but perhaps the TX10A (also found on pre-MY05 Frontiers, Xterras, Pathfinders, and Hardbodies) would be a suitable donor for linkage, lever, and even shifter boots/bezels. Food for thought. Good call on getting the mechanical side of things sorted first, though. Also, I decided to do an actual search to see if others have tried the Quaife...and sure enough they have, so I'm certain we're on the right path. I prefer to do my own research on stuff like this (in this case, I would've never had a reason to bother looking), but I'm always certain I'm not the first to reach such conclusions. This was the first result: https://www.clubfrontier.org/threads/quaife-qdf11l-installed-in-my-c200k-rear-axle.350923/. The author used a QDF11L, which supports the carrier break theory as his 2015 Frontier S 2.5L would have a gear ratio of either 4.083 (49:12) or 4.363 (48:11). It at least confirms that the overall carrier series dimensions are spot on, so now it's just a matter of confirming L4.
This is amazing, by the way. It has a name. This unequivocally sums up my interaction...and it bled over into another post, too. It was entertaining for a while, but "arguing with a fool only proves that there are two."
Hey Gerry, Ooooooohhh, that "all-electric"! I totally misinterpreted that. We've had a 98 Frontier in the family with manual windows, locks, and mirrors and every day for 22+ years I've wanted it to be the other other "all electric" (power windows, etc.). I was actually researching EV options for that truck a few months ago, too. Seemed neat, but the costs seem out of my league. I can only afford to reach across the seat to roll down the window. Anyway... So now, about the Quaife...I have a modified recommendation: I think the QDF10L is the correct model for your application, not the QDF13L. When I previously dug into this, it was only cursory searching just to shut that guy up (which it didn't, apparently). Digging a little deeper, I see Quaife has 4 possible replacements for the 350Z, depending on the transmission and the diff type it came came with: Auto/Open: QDF10L Manual/Open: QDF11L Manual/VLSD: QDF13L Auto/VLSD: QDF18L The Quaife website has dimensional spec sheets on each model (except the 18L, which just linked to the 10L spec sheet). The 10L has a 0.4"/10.2mm difference on the "L4" bearing-to-crown-surface measurement vs. the 11L/13L models, which suggests a "carrier break" between gear ratios. The 2003 350Z FSM shows that the MT has 3.538 (46:13) gears, while the AT has 3.357 (47:14). That extra pinion tooth (13 vs. 14) is enough to require pushing the ring gear over that extra amount to accommodate the larger pinion head. The 2005 R51 FSM shows the 4WD ratio as also being 3.357, and sure enough, the ring and pinion set (38100-2C360 -> 38100-0F36A) is the same as used in 2003-09 350Z and 2005-12 R51 (and same years D40 Frontier and 2009-20 370Z). So, my money's on the QDF10L. My confidence is pretty high just based on the part number cross refs alone, but with your carrier out and the specs online, that should confirm just about everything. I wouldn't even be surprised if someone else has done this, but I've not searched around for it. Your front diff is a smaller R180A model. Nissan did use R180A's as front diffs in older W/D21 Pathfinders/Hardbodies, and also as rear diffs in older Z cars (Subaru even used R180s), but it's a longshot they're similar. My Google-Fu suggests the car diffs were 8-bolt ring gears...not sure about the trucks, but I'll guess there weren't LSD options. ARB offers two lockers (RD180 and RD181, depending on carrier break) and shows the R180A as being a 10-bolt ring gear with 27-spline shafts at 1.09"/27.8mm. This "CD52P" LSD from Mother Russia might be just the ticket: https://www.ebay.com/itm/123629507939 At this point, I'd say running dual LSDs on that R51 would be pretty slick in itself...but since you're pushing the envelope by going EV...oh man... Speaking very broadly here since I've not worked on an R51 and haven't scoured the FSM (yet?): the removal of the transmission alone will very likely be problematic. The Transmission Control Module (TCM) provides input signals to practically every system on the truck. Even if you keep the transfer case, the transfer control unit (TCU) uses TCM data. I imagine much of this can be bypassed to some degree with some re-wiring (after all, it's just 12v solenoids doing the actual work, with some brains in between to keep anyone from engaging 4L at freeway speeds), so ideally the switch can be wired to provide basic signalling. To that extent, I use an All-Mode switch from R50/QX4 models to run my air compressor and air lockers...so I'd reasonably expect the R51/D40/N40 switch to be repurposable to signal the transfer case to be in 2H/4H/4L. But, it's a broad assumption having not looked into it. The brake/traction systems also rely on TCM data. On the plus side, if the transfer case is similar to the R50 versions (specifically those with All-Mode, including all QX4) then I believe the vehicle speed sensor (VSS) is on the transfer case and not the transmission. There may be another revolution sensor that might need to be simulated, but you really have to hope that the TCM-to-ECM (Engine Control Module) is not deeply impacted as well. The ECM in itself will be another problem. Do you plan to use the gauge cluster, or will you have some other interface/display showing EV-specific data? Of course, everything really all depends on what features/functions/system from the truck you want/need to keep. My best recommendation there is to list out all those items, download all the FSM chapters for the truck, and review all the system descriptions. The FSMs do a great job of describing function and indicating which systems/sensors are used and how. The troubleshooting/diagnostic sections will also provide voltage/resistance data for sensors. This way, you might be able to gauge which inputs can be simulated by switch and/or resistor to preserve a function, or otherwise trick a control module.
Just to make sure we have the main goal in mind here, I've interpreted "bypass[ing] the electronic AWD feature" as meaning you're looking to bypass whatever software-driven traction system you've got (ABS, VDC, TCS, ABLS, etc.) on the truck with a mechanical LSD. If so, my quick response would be that if you can find a suitable LSD, bypassing any system wouldn't be necessary: the system would just be supplemental to the device's functions. That is, the system would only kick in after it determined that a LSD (if it existed) was allowing enough slip to satisfy detection logic via sensors. Otherwise, if you do mean to bypass AWD, you may need to expand on what function you're referring to. The All-Mode system on the truck already has the means to bypass the mode simply by turning the dial to 2WD, but that option seems out of context to the questions. Either way, I'd just focus on the LSD part for now, if that's what you're really after. Admittedly, I don't know much about R51, but I can infer enough just from FSM data (https://www.nicoclub.com/nissan-service-manuals) and part numbers. Follow along... The 2005 FSM indicates you've got an R200 rear final drive. A parts cross-reference indicates that the side gears in your differential (38423-0C000 -> 38423-0C00A) are also used in 2003-2008 350Z cars and 2005-2010 Frontiers, Xterras, and Pathfinders. That means the splining between those vehicles are the same. The differential carrier (38421-0C000) for those trucks were all the same, and since the Frontier and Xterra have C200 rear axles, and yours has an R200 rear, it means those differentials are the same. (R200/C200 compatibility was also true on pre-MY05 trucks/SUVs/cars, but MY05+ R200/C200 are different from pre-MY05 versions.) From prior research just the other week, I can also confirm that the C200 open carrier from a 2.5L D40 Frontier is the same as a 350Z, and they too shared the same side gear. All the above vehicles use the same carrier bearings. I presume more parts to be identical. The end result is that, in theory, all the differentials from 2003-2008 350Z and 2005-2010 Frontiers, Xterras, and Pathfinders with R200 rear diffs (G35, R51) or C200 rear diffs (D40, N40) are all interchangeable. If that's true, a Quaife QDF13L LSD for 2003-08 350Z/G35 with VLSD should work in the truck. My full technical assessment is available here: https://www.clubfrontier.org/threads/rear-axel-swap.368234/post-3903321, but the abstract that's relevant here is: If you decide to read into that post further, please enjoy my bashing of some idiot. There's also some technical "talk" about what Nissan calls a system versus what said-idiot calls a device, just to clear up the differences in traction systems and devices.
I've been exchanging emails with Kenay and he's been very helpful. Here's the trim pics from his website (https://kenaykustoms.com.au/) so that we have some consolidated info here: Order in the pic above: W, K, G As mentioned previously, he is planning to update the site to allow for shipping to US, price will be around $70 AUD shipped (about $54 USD as of today). I may actually pick up the W trim since I light gray might be a nice contrast. But, I can wait out @PathyGig12's review...keep us posted. -
Typo on my part (now corrected)...I ordered the "K" trim, not the "W". Also, I ordered two of them. @TowndawgR50 has the other one now and can weigh in on things. I also reached out to Kenay Kustoms and got a reply from the man himself, Kenay. An interesting notable was that the panel also fits an older Subaru Forester console. But he did share some advice about the color trims and thinks the "W" might be a better look. I'm checking if he's okay with me posting up some of the trim color pics here to keep the colors convo in context. He also mentioned changes to the website to allow for shipping to the US soon. (Duke's Camping also did a great job on the ebay transaction, despite ebay complicating things; they sorted everything out very quickly.) -
@R50JR sent me an ebay link the other week for a Patrol switch panel and convinced me that it'd fit. I did some additional comparisons and agreed that it would. I had some concerns about how well the trim colors would match (there was a "K" gray, "W" light gray, and "G" tan, as far as I could tell), since it was clear the trim color codes were not the same here (my all-black interior trim is "G") and all the photos I could find seemed too tough to tell the exact tone. After some deliberation, I ordered the last pair of "W" "K" panels the seller had. After waiting a few days, they arrived. Product looked great. The color was a slightly brownish-gray. (My Frontier has a "K" gray trim, and it's not even remotely close). In hindsight, the light gray "W" might have been good contrast. But overall, I dig it. Fitment is good. Material quality is really good. Getting the console down from the roof and detaching the wiring harnesses from the backside of the sunglasses tray was the toughest part. Things may get a little more complicated once wires are up there. The company that makes them is Kenay Kustoms out of AUS. Unfortunately, they do not ship direct to the US, but I plan to reach out to them to confirm fitment based on the pics below. They also made color-matching blanks, except they were out of stock of them. The black ones were reasonably priced, ordered through the same ebay seller (dukes_4x4_and_camping) that sold the panels. Anyway, some pics below. Not sure what all I'll put in them yet, but it'll be way more useful than the worthless the sunglasses holder that doesn't fit any sunglasses I've ever owned. It does block the climate and compass readouts a little, but a slight head dip resolves that easily. It's not something I stare at regularly anyway. From this perspective, the color match is perfect: And it's too bad there aren't any cool Nissan switches to put here, but they would fit reasonably well:
@03TroutFinder My bet would be a bent LCA. Same symptoms/cause as a buddy’s truck. Check the area of the arm where it leads into the rear stem mount.
DIY winch bumper 'builder' brackets
But lemme think on it. I’m a few weeks from moving forward on that project and it’s a possibility. -
Thanks! The Detroit locker is currently sold as a complete full-carrier replacement (p/n 187SL167A), but I think it was also previously sold as a carrier-internals kit. The AC link you provided would be that kit pre-installed in an LSD carrier. They also sell just the internals: https://www.4x4parts.com/i-18915813-detroit-locker.html Since the older H233B 4-pinion open carriers were similar in style to all the LSD carriers, it suggests that this Detroit would've fit into both carriers. I've not done a close comparison between the 4-pinion open and LSD carriers to confirm that's true, but I might be able to. If the above is true, either option should work if you've got a 90 WD21. Note, too, that this was a 31-spline option only. Sites like this wrongly suggest it fits 33-spline applications: https://www.justdifferentials.com/Nissan-H233B-Detroit-Locker-p/det187sl-167a.htm
- 31 replies
- h233b
- differential
(and 3 more)
Tagged with:
