SpecialWarr
Everything posted by SpecialWarr
  1. Ah, I spent about 2 hours driving around Montreal collecting small hardware parts to finish off the slide pin rebuild in the rear disc. I found that I was missing the anti-rattle clips and the rubber boots were torn. Both found and to be installed tomorrow at lunch! sent from under Ernest the Pathfinder
  2. Since the cruise and headlight switch are in the same stalk and that the wires are routed funny around the column I would suspect that they were routed in a different way or maybe that a wire was pinched on re-installation. Since just a #2 phillips will get all of the panels off I suggest you take a look and see if anything is amiss under there. A pinched wire is obvious, maybe a light tug on the ignition wires to ensure that they are well attached? Other than that I cannot help... maybe someone else can?? Sent from my SGH-T999V using Tapatalk
  3. Don't bother trying to weld aluminum without the correct sheilding gas. It won't work as the elements in the aluminum will instantaneously combine with the nitrogen and oxygen in the air and create pores in the heated material. The pores are not themselves atached to each other. Sent from my SGH-T999V using Tapatalk
  4. Hahaha... ask Fleurys, adamzan and Pav what they think about that! Sent from my SGH-T999V using Tapatalk
  5. Put it in 4low and pulled three cars out of the ditch on the way home at three different spots in what could only be called a snowstorm or blizzard. So far we are at 17cm by the boot measurement... Sent from my SGH-T999V using Tapatalk
  6. 42psi is okay. IIRC the FSM states that the regulator should maintain a constant 43... but 42 should be fine. Sent from my SGH-T999V using Tapatalk
  7. The wires run through the sender top to the pump inside. Sent from my SGH-T999V using Tapatalk
  8. I believe that is a whole sender assembly. The pump and internal hoses and clamps are not a part of the assembly from what I've read here and seen. Parts guys still have a bit of a time trying to figure out what sender goes with what pump! Take a look at aaanissanparts.com for FSM pictures. Sent from my SGH-T999V using Tapatalk
  9. Today I re-installedmy manual hubs after a dinkle-puss pissed off with four of the six bolts that held the driver's side hub on. I took about two hours of phone work anddriving around last night to no avail and ended up taking a whole new set of bolts from work. Sent from my SGH-T999V using Tapatalk
  10. I am so jealous that you have access to a 20 somthin' year old truck that looks like that...
  11. Thanks guys, I didn't really give the pin a chance Friday but i showed up late aaaand everthing else went downhill from there. I'll be getting a triangular file and PB Blaster at Canadian Tire later today and take another run at the pin. Sent from my SGH-T999V using Tapatalk
  12. Beat on the driver's side rear cailper for 35 minutes with heat and wd40. Caliper is stuck to the inside and not even the little 4lb hammer I have can move the thing....sooo pulled the old pads off of the right side and stuffed one in the left and put in three new pads. And once again I hate salt more than anything else on planet earth right now.... Quebec....dammit. Sent from my SGH-T999V using Tapatalk
  13. adamzan: did you get these done on your truck? I have a left rear caliper with a sticky glide pin that's eaten the whole pad and I'm going to have to dive in this weekend to the rear brakes. Any tips you could share?
  14. Drove it to work, small slide through the parking lot to my spot and decided that I now have a loose ground somewhere that'll have to be repaired this weekend. Sent from my SGH-T999V using Tapatalk
  15. My bad was assuming that the timing marks were 3 degrees each.... they are, as I have been told, 5 degrees each. And now my fuel consumption has gone down about 5 percent. Yay for NPORA and the gentle-folk on here. Word to the Precise 1. Adamzan and Don my homie at the dealership!! Thanks guys! Sent from my SGH-T999V using Tapatalk
  16. Hahhhh....so that my truck is running 22 degrees is probably not a good thing then.... methinks I'll be changing that tonight more towards the 15 degree end of the spectrum.... plus or minus 2 degrees.... Thanks for the info adamzan!
  17. Question: Just for kicks last night I went out and bought a timing light (wanted to get one for some time now) and checked the timing on the truck. There are seven marks on the pulley and each mark is about 3 degrees; is that correct?
  18. just thinking about how much work is invloved in pulling an inner cv..
    1. Nefarious
      Nefarious
      only takes a couple hours to swap out the cv, not a big deal if you go right at it
  19. Sweet! Thanks for the information..... I didn't see that ajustable shock while I was down there but there is a switch behind the handbrake. LSD could be fun during the spring. I currently have some cheap-ass tires in a 265-75-15 on the truck but they are on stocck steelies, not alloy rims.... but check on everything else. Sunroof, power windows, door locks, mirrors, Grant Challenger steering wheel and the dual trip odometers... Though that 4 speaker system is now down to one speaker only. I would love to figure out how to bypass the amp and try out the other speakers but that will be for when it gets warmer and there isn't an oil leak, grease coming out of places like the front transfer case or inner cv joint, leaky injectors and funky running engine.... All on the list of things to fix.
  20. Yea, rice-ing the interior has got to make it difficult to drive too! LOL!! Sent from my SGH-T999V using Tapatalk
  21. A couple of doughnuts in the snowy parking lot and discovered that I have grease slinging out of something in the front. Time for more work on the truck. Sent from my SGH-T999V using Tapatalk
  22. I hear that one and I found it was the exhaust just about an inch after it hops over the rear axle. Mine is rattling on the shock upper body tube. It's damn near impossible to see there. Sent from my SGH-T999V using Tapatalk
  23. I installed a Grant steering wheel; the Classic Series Challenger (because it remindes me of Vanishing Point). Super easy mod, and done because the original was too far away from me to be comfortable and covered half the dash. I have not yet figured out how to get the self-cancelling turn singals back to working but I am thinking about it. The original steering wheel had been chemically abused and the surface is no longer attached to the steel ring. And it was disgusting to look at. (Fiancee's comment!!) Sent from my SGH-T999V using Tapatalk
  24. If I'm only getting 70ish kms for the first quarter tank during the winter and half city half highway driving are we calling that bad? Sent from my SGH-T999V using Tapatalk
