Everything posted by djeffrey
Has anyone seen this? Flyer States a higher articulation plunging CV axle. Ok increasing from ~28 degrees to ~40degrees. They have a part number for the WD21, D21, Frontier, Xterra etc. I would think this would be a great upgrade and allow for some better long travel options? Click download flyer to see the part numbers/ vehicle compatibility. The flyer is too large to attach. https://napacvaxles.com/extended-cv-axles/
This is awesome! I'm buying a set now! This is something I needed but didn't want to bother with another set of sun rotten ones. Thank you for making this happen!!!
No I did not. Sent from my Moto Z (2) using Tapatalk
Awesome!!! You should be able to copy and paste the link here, it may not play on the page but at least we can navigate to the video. Sent from my Moto Z (2) using Tapatalk
So how are you gonna attatch the ALH to the Nissan trans? Is there someone that makes an adapter plate? Sent from my Moto Z (2) using Tapatalk
I agree, I have a 2001 jetta with 340,000 miles, I like the engine a lot. Seems that with a tune, tubo and injectors you will be well over the HP and torque of our pathfinders even with a VG33. What is your plan for a transmission?
What TDI engine are you hoping to swap in? The one that came in the diesel pathys or are you thinking of using a VW ALH 1.9 or somthing?
According to my 1992 service manual, the VG30E 4x4 came with 4.625 in manny tranny, and a 4.375 in the slush box tranny. Rear diff is a H233B, front is a R200A. The manual also mentions gear ratios for the KA24E, Front Diff is a R180A and with the rear being a C200. This model used a 4.111 gear. Hope this helps, that is about all I know.
I am going to order a set hopefully also, I messaged the seller he gave above and asked about the rears, he mentioned he does not sell them but he has had people simply cut them shorter to fit.
Just making sure, you hooked up the EGR tube to the new headers. It sounds like you did but it isn't clear. I don't think your O2 sensor would make a difference in EGR function. Unless it is now too close to the Heads and it is picking up a false reading. Which I am not sure is even possible. It is all the same air no matter where you pick it up.
E85 in the 95 Turbo, let's see what happens.
djeffrey replied to snowboard419's topic in 90-95 WD21 Pathfinders
Awesome that's good to hear. I wouldn't want to over boost my truck, I just want to keep the reliability, increase mpg a tad on my 200mile highway drive I do often, and bring the power up for towing and wheeling,. I wouldn't think I need to put near 15psi down if I want to maintain reliability on a stock vg33 bottom end. I was just thinking about a remote turbo yesterday, I'm a bit worried about submerging it on water crossings and stuff. my brother and I were looking yesterday and think the passenger side might be a nice place to put everything, I can relocate the battery to the back, then I don't worry about the brake/clutch master, getting around the front diff/drive shaft. Just need to figure out a wrap around tube from driver to passenger and where to mount an intercooler since I have the ac condensor and winch bumper to contend with. Sent from my Moto Z (2) using Tapatalk -
Thanks for continuing to manage the website and improve on it! I am very happy to have this resource around. Thank you so much for all the work you guys put into it!
- 17 replies
- 1
- forum upgrade
- server move
(and 1 more)
Tagged with:
Snowboard. do you think your injectors are large enough to go in a 3.3 with megasquirt and a turbo? I am having a hard time finding compatible injectors. I am glad to know that you subaru injectors fit and I can simply rewire the harness to make them work. I am just worried they may be too small if you are topped out on the duty cycle. (Although I may never run E85) So maybe that makes them large enough for me. -
yeah that is a good point. I am worried it will eat up some fuel mileage having a S/C for normal highway driving. I wonder if I can make the supercharger work with all of the 3.0 accessories and pulleys, I used a Mr,510 adapter so I wouldn't have to use the 3.3 accessories. I definitly feel like a S/C would be easier than having to reroute exhaust and finding a spot for the turbo to sit. -
did you also get that other hole plugged? I am sure you did, but if not, I ended up just welding a cheap socket into the hole. found one that fit, welded it in and filled the 3/8" drive hole. Sucks about the exhaust leak!! ive had mine work its way lose and blew out a gasket on the drivers side. changing it wasn't to bad.
I bought the headers about 3 years ago, and also bought a second collector last year because I bent mine on a rock. They both came flanged. just slid it onto the two header pieces and bolted it up. I remember it taking a bit of bending or prying to get it to line up right, just due to it being aftermarket and stuff on my pathfinder being bent or what ever. but still went together easy.
What do you mean modified to fit? My pacesetters seemed to fit well. A few topics down we spoke about headers, check that out for some information on them http://www.nissanpathfinders.net/forum/topic/44143-headers-time-to-bite-the-bullet/
That's awesome info thank you! I will definitely have to find a way to keep my AC. I may be a bit of a sissy, but in the California desert I would rather have AC even if it meant no turbo! but I am sure I will figure something out. -
That is great to hear! So I won't be doing anything with the old ECU, since I have a manual trans. Does your AC work separately as well? or will that rely on the computer? What do you do for a CEL, does mega squirt do anything? I cant imagine you really need anything besides a knock sensor, oil pressure, water temp, but I could be wrong. I feel like the CEL is probably not necessary anymore. Thanks for posting the gauge pod link! I am stoked I can get a paint matched gauge pod! -
I have a question, I know I can PM you but keeping it on the forum allows other people to learn as well. I am about to start my research and purchasing to upgrade my fuel injectors, use megasquirt, and probably at the same time or later build the turbo kit. Question is, I know the mega squirt is managing the engine instead of the stock ECU, and If I understand right, the stock ECU is staying in to manage the rest of the car, is that correct? Are you still able to maintain the stock guages? Or do the guages become dead and you had to install aftermarket hardware? Also, were you able to find an A-pillar guage mount for your boost, O2 sensor, etc that fit well in the pathy? Thanks for taking the time to answer my questions! -
That is awesome! Are you feeling a significant difference? I wonder what your fuel mileage would do under normal driving conditions with your new tune and setup -
That is really cool to hear! I am really excited to start my MS build and tuning, it will be a new experience for me so I am excited. -
That's awesome! Are you making changes to your tune as you change the fuel around to utilize it? Sent from my Moto Z (2) using Tapatalk -
Awesome thanks! I will be looking into fixing that! Good luck with the ABS light!!
If you haven't downloaded your FSMs, better do it soon...
djeffrey replied to hawairish's topic in General Forums
I found the 1994 manual on the link above. If anyone has any older manuals let me know! Thanks for the link D_Bomb!!!!
