Quaintbucket
Everything posted by Quaintbucket
  1. Alkorahil - He is more than happy to help you out rockauto amazon.com Lordco (if you have the discount) I agree that it sounds like a valve cover gasket leak. If it's the 99.5+ then it might be your oil seal. I also agree on the timing belt+water pump if it hasn't been done. Might as well do a full tune up too.
  2. Saw your post about the washers so I kept it in mind when I went to pick them my package at the postal office (really happy it came earlier than Oct 2nd!) last night. Installed it so no pretty pictures today because it's piss pouring outside. Sooo much easier to install and uninstall because it's just four bolts. The bolts and washers are actually pretty heavy duty. I definitely can see what you mean by surface area but because the washers are beefier than expected, I don't think there's anything you need to worry about. I'm really happy with the skidplate! Just don't know what to do with the stuff I removed now. Maybe I'll throw it up on craigslist for $5 and then junk it at the end of the week. e: I do have nice photos of it out of package but it's on my other camera.
  3. if it makes photos like bushnut's picture of his shy r50, i think that's a successful photo thread
  4. Michelin LTX sounds like it would fit you. Sent from my iPhone using Tapatalk
  5. Looking better and better every time! I see you decided to put your jerry can on the roof. Sent from my iPhone using Tapatalk
  6. Nice write up! Thank you for sharing and being detailed. Sent from my iPhone using Tapatalk
  7. Aw, crappy luck. At least you know this now instead of later where it's more crucial.
  8. Ok, you're killing me. What kind of wheels are those because I want them.
  9. My bad, I keep forgetting they were lucky enough to get timing chains. dammit.
  10. Definitely go for the MM if you're not doing anything crazy. It's MM 435 if i recall correctly. I will probably end up getting the warn because I do some boulder/rock crawling for my hunting expedition. Hell, there's a path at Mike's Lake that's all rocks and all boulders. I'm not comfortable taking that one till I lift my Pathfinder.
  11. Nice find. I'd do a full tune up on it. Spark plugs, rotor, cap, wire, air filter, and fuel filter. You shouldn't need to do a timing belt change for another 50,000 miles. Your transmission SHOULD be fine. Does it feel weird? Shift hard? Stalls? If it doesn't, then you're OK. The squeaking that you're hearing might be your bushing for the trailing arms. It should be OK considering the number of miles but I guess age would have a big impact on it. And yeah, the LE typically don't have tow hitches. It's usually an add-on for owners. I don't have one on my 97 and am planning on adding one. Do you got 4x4? I'm jealous, you got a sweet almost new vehicle for a steal.
  12. I really like your rims. I just gotta say that again.
  13. Smoke system and be ready to replace the two parts that Rob suggested. Sent from my iPhone using Tapatalk
  14. Already enroute! Hopefully I will be home when it arrives! Doubtful but the idea of the post office holding a large skid plate size package is pretty funny. Sent from my iPhone using Tapatalk
  15. Left as in passenger side? Sent from my iPhone using Tapatalk
  16. Knock sensor will not kill your engine. All it does it adjust the timing ever so slightly to compensate for any change in the engine. The fuel system or your EGR is the likely culprit. I would look at your EGR to make sure it's working properly on start up and not sticking up (which kills your engine).
  17. Glad to hear you kept your Pathfinder and hope you feel it was still the right call for you. As for the tires, you are absolutely right to refuse the tires especially if it was damaged like that. I'm not sure what your dealership mean by that there's not many tires out there that fit your Pathfinder unless they're saying, "This is all we have in stock." There are many more options available for you depending on your usage. I am assuming you're not doing any offroading but will be using this as your regular commuting vehicle. I agree with Karmann that if you check your tire serial number, you can find out the age of it and make the appropriate decision. As for Japanese/American parts, never had a problem with aftermarket replacement parts.
  18. That's helpful to know because I was thinking the same thing as Slartibartfast. Just recently switched from 10w30 to 5w30 as well. Sent from my iPhone using Tapatalk
  19. Would bug me just the same. I didn't like how it was hitting the handle for the rear glass whenever I rarely use it. Sent from my iPhone using Tapatalk
  20. Nice. Let me know how it works out for you. Sent from my iPhone using Tapatalk
  21. Replaced rear window wiper blade with a 11" one. Previous owner out a 13" and it was driving me nuts. Happy now! Sent from my iPhone using Tapatalk
