AzZo
Everything posted by AzZo
  1. How is the rear bumper? Is it very rusted out?
  2. Also I was able to go to my local library and take out a chilton's manual on my 95 nissan pathy for like two week's.And there is no computor under the driver's seat,it's under the passenger seat.The box for the alarm system is under the driver's seat at least it should be.There is a thread on forum some where that I found most useful on setting the keyless entry and alarm.Good luck and keep us posted.
  3. Sure thing sorry it took so long to get back.I used an mutimeter set for circuit testing thats the one that looks like a horseshoe and it does not matter which probe goes on injector plugs either one will work.Good is around 11 or 12 approx.Now to remove you want to use something like pb blaster or similar to loosen injector up loosen screws and you should be able to wiggle it out replace the o rings use a little gas to coat the end of injector and it should go right back in the reverse order.A mechanic gave me that tip he just takes a cup of fuel and dipps the end of the injector in it and viola it popps in easy. Be careful not to force it and mess up the o-ring it has to seat properly or it will leak gas.Sometimes you have to give it a slight twist.You should be able to feel it if it goes in right you know what I mean.Good luck and happy motoring.
  4. I had the exact same issue a couple of months ago.I mean Exact I took a multimeter and checked the ohm readings on my injectors they were all the same but one the number five cyl. was like 35 when the others were between 11 or 12 had a bad injector or one that was ready to go out that is why I believe it would run rough then go back to normal.I replaced with a good injector thanks to a great NPORA friend.And I have had no more trouble since.Have driven around 5000 miles since IOWA to WISCONSIN and back.The only draw back is to check the injectors on fuel rail under plenum you have to remove the plenum.I got lucky and had bad inj. on passenger side was able to replace with little to no trouble at all.Good luck and hope this helps I went through many hours of tests to arrive at this conclusion from checking coil to dist to fuses to cpu ect,ect,ect.......................
  5. That's so right.I alway's say if it works don't mess with it.If it aint broke dont fix it.RIGHT ON B.
  6. Not that hard ony thing I did not like is mine had phillips screw's and you don't want to strip those.If you can replace with allen head screws or just bolts and it will make life better next time you have to remove covers.Good luck if you decide to tackle this project.Remember nothing ventured nothing gained.
  7. Nice,Tungsten definitley looking forward to the write up.I am planning to do an electric fan set up and was concerned about only one thing.The controller, many brands out there but dakota look's like a good one.thank's.
  8. The guy at my local junk yard took one look at the clips I showed him and said no charge.
  9. Sorry to hear.Hopefully next weekend's a little less eventfull.
  10. Yea,$3.55 here in IOWA to, was $3.49 on AUGUST 3rd. Sixy-two dollar fill up for me also.But my brother out in CALIFORNIA say's he's been paying $4.00 so I guess we can be thankful were not getting charged that highway robbery yet that is.Keep on truckin ahardb0dy.
  11. AzZo
    Rear door latch.
    YES, Ha,ha,LOL this is true, alway's one thing or another. But that's what make's life interesting.Never bored with my pathfinder.Thank's for your help and input ahardb0dy. Stay cool.
  12. AzZo
    Rear door latch.
    Fixed!! the plastic adjustment screw is on a metal rod which is threaded on the bottom end.There was no nut on the end I don't know if it supposed to have one or not,maybe the original fell off and got lost? Who know's I found one in my tool box that fit and that hold's the plastic adjustment set screw in place so it can't move.Now my hatch open's and close's with key and power lock's to.Excellent!!!!!!!!
  13. AzZo
    Rear door latch.
    Affirmative my friend.
  14. AzZo
    Rear door latch.
    Man thanks for the diagram it shows exactly what I was talking about.Will take your advice and have someone turn key while I look at it.Thanks again!
  15. AzZo
    Rear door latch.
    yes but if I open rear window and reach inside I can turn little plastic adjustment screw and then it will lock or unlock.Me thinks the adjustment screw must turn on it's own and therefore go out of adjustment.Just a theory.
  16. AzZo
    Rear door latch.
    Thats exactly what I am saying no power locks and when I put key in it just opens the glass not hatch. I can hear the power locks actuating but they dont lock or unlock the hatch. Can that little plastic adjuster screw be the cause could it be moving on it's own.And going out of adjustment?
  17. AzZo
    Rear door latch.
    Thanks will check that out and let you know.
  18. AzZo
    Rear door latch.
    Well that did not work brackets fine. Seriously nobodys ever encountered this problem? I guess it's just my tough luck.Strange day's Indeed.I think a white witch owned my pathfinder previously.YES definitly.But could not turn down that cobalt green pearl paint.I'm IRISH.She must have put a spell on me.Ha,Ha.....
  19. I dont know a lot of those companys will tell you anything just to make a buck years ago it was putting magnets on fuel lines.Anybody remember that one? Ha,Ha,The best fuel miliage is to have engine breathe better headers help a good exhust system tuned up good oxygen sensors in good working order.I'd start there first but remember pathy's aren't known for great gas milage I only get around 15 to 20 mpg if I'm lucky.
  20. AzZo
    Rear door latch.
    Sorry should have specified rear hatch door will check bracket to see if it is engaging the rod. Am I the only one with this type of problem? Any other feed back would be helpful.thanks
  21. Hey am I the only one with rear door latch problem's? Mine won't lock sometimes,then will lock and I cant get it open unless I open rear window reach in and turn little plastic screw adjuster.I took back panel off just so I could access it.Is adjuster moving on it's own so it goes out of adjustment? Is this common problem? My pathfinder running well just trying to work out some small bug's like this one.
  22. Alkorahil,is the man he really knows his stuff.Yea when I can I want to replace my front and rear stock bumpers.James rich has the right Idea.But I like the ARB look.
