AzZo
Everything posted by AzZo
Worked on some body spots that are starting to show sign's of rust sanded and primed waiting for stock green paint from get this a company in new orlean's,LA. You know what they say RUST NEVER SLEEPS.
Man,Balln that is one sweet 94. wellcome to the club.Good Luck and enjoy.ps tires are fantastic! jack
Has anyone relocated ARB bumper after 3" BL?
AzZo replied to trexterra's topic in Solid Axle Swaps, Hardcore Custom Fab
Yep you should definitley give it away here's my address....just kidding,LOL! -
Big shout out and thank's to all you great member's who gave me the best advice on this problem.It is now fixed yes fixed! And it ony cost get this $ 5.99 at ye old autozone parts shop.It turned out to be the tail - light / stop -light bulb socket a cheap fix for sure.To bad I spent days checking leads and ground wires but had to be sure and like I said I'm no electrisian can't spell either.Ha,Ha. The cause was back quarter panel rusted pretty bad,IOWA winters, road salts etc....And small hole allowing moisture and mud and junk up into tail-light compartment and corroded the socket it did not look that bad to me at first but then what do I know right. I am so a newbie to pathfinders but thank's to you all I am learning FAST!! THANKS AGAIN>IOWA<JACK......
PETE, I am a newbie and you are so right I have received nothing but great help from old timers and new guys alike the camaraderie is awesome and could'nt have found a better site.I just picked up a 1995 pathfinder xe in may.Glad to hear from you if you can don't get rid of your pathy.I have a feeling you would miss it. Am I right,I have grown really found of mine.anyway over and out.jack....
Going to check all wiring leads in morning grounds and continuity.Wish me luck.An electrician I'm not. will let you all know what I find out.If I can't fix it will send to Mechanic OUCH!!! Gotta be able to drive at night right.OVER AND OUT.
Right side was coroded pretty good.Maybe it's the bulb fixture it'self.Has anybody ever run into this before?
Corner lights are working and dash light comes on too.
yea .fuses all good dash fuses and under hood fuses.checked the switch on steering colum to its good to go.I hope it's not fusible links.
NO bulbs are good.I replaced with new ones, now have running lights but when I step on brake pedal the right brake light goes off. Just the right brake light.weird huh remember both running lights are working left sides fine.
Headlights come on but no tail lights.turn signals work fine so do hazards and brake lights.Fuses all check out okay.Perplexing? Any suggestions would be a great help. Can turn a wrench well but electrical is not a strong point.Thanks.
Any accident you can walk away from is a good one.Your pathfinder can be fixed. Good luck with repair's.
true auto zone or napa I had good luck at napa they had mounts and hangers in stock autozone and oreilly's wanted to back order and who has time to wait when your pathy sounds like a go-cart. Ha,Ha.
2 inches outside diameter on stock pathfinder. inside diameter is 1 7/8 inches hope this helps I just finished mine.good luck.
Thanks again Tungsten you never let me down I am picking one up tomorrow.
Don't have access to welder just yet but have loose exhaust pipe where it connect's to muffler. Inside diameter of stock pipe is 1-7/8 outside is 2 inches so do I use a 2 inch clamp? Will that clamp hard enough to hold till I can weld it solid.
Do the work spend the time buy the 94. bent frames are not cherry,nor apples or oranges.And switching out frame's well you better have lot's of time.
THATS GREAT THOUGH 69 BUICK MY FIRST CAR WAS A 1959 STUDEBAKER I PAID $35.00 DOLLARS FOR AT JUNK YARD AND DROVE IT TILL THE WHEELS FELL OFF. HA HA CANT DO THAT ANYMORE.
sorry to hear but hey they did'nt stop making pathfinders when they made yours.Right, you will find another or it's equivalent.
yea I know my way around Ignacio, Red boy pizza! Ive shopped at the safeway there to. But alas met a gal from a small town in IOWA. Had a little girl and moved here. Its a change but I agree with you lifes as hectic as you make it.Hey you don't even pay for your gasoline out here until youve pumped it. Right ! When I first went up to pay first the guy looked at me like I was crazy.mayberry rfd.HA,ha!! Thanks PRECISE1
Legal .smeagal it's all a state of mind if it works do it.I lived in california for years donated two cars because they could not pass smog.But here in midwest I swear i have seen people pouring smoke out of their tailpipes right in front of police and nothing comes of it.
old welders trick is to remove tank empty all gas and fill with water weld away no danger at all.drain water dry out and your back in bussiness. man getting it off though is another matter I broke 3 bolts out of six had to drill out and use easy outs.replaced with all new bolts.
I agree weather permitting I live in Iowa and winters can be rough. My 95 pathfinder has got 140,000 miles on the original timing belt. Crossing my fingers and knocking on wood.Plan to replace ASAP just got pathy In May 2012.
Some love for Colorado right now amidst the fires...
AzZo replied to Boosted's topic in General Forums
Yea, hope the best for all of Colorado one of the worst years for fire Ive seen in a long time. good luck and god bless + -
Precise1, Just checking back, you said to remind you I just need one fuel injector with blue dot on the back of it.Can pay you some thing not a lot things a little tight these days Damm recession and can send you large envelope to mail it if you've still got one.Let me know one way or the other.Much thanks.jack
