AzZo
Everything posted by AzZo
Any accident you can walk away from is a good one.Your pathfinder can be fixed. Good luck with repair's.
Welcome,welcome,I love the z series datsuns 240,260,and 280,I had a 280z orange with black racing stripes. 6 inches off the ground it would bottom out in drive ways but man could it hug the turns.
You said it brother.Thanks
true auto zone or napa I had good luck at napa they had mounts and hangers in stock autozone and oreilly's wanted to back order and who has time to wait when your pathy sounds like a go-cart. Ha,Ha.
2 inches outside diameter on stock pathfinder. inside diameter is 1 7/8 inches hope this helps I just finished mine.good luck.
WELCOME,MARK WE HAVE A FEW MEMBERS IN PITTSBURG AREA I HAVE BEEN THROUGH THERE A FEW TIMES.BUT NOW RESIDE IN EASTERN IOWA.
Thanks again Tungsten you never let me down I am picking one up tomorrow.
Big welcome ! NPORA is Fantastic. You will enjoy being a member.
Don't have access to welder just yet but have loose exhaust pipe where it connect's to muffler. Inside diameter of stock pipe is 1-7/8 outside is 2 inches so do I use a 2 inch clamp? Will that clamp hard enough to hold till I can weld it solid.
I cant ban kingman cause beer is great and god is good and doughboy is crazy for starting this game.
Do the work spend the time buy the 94. bent frames are not cherry,nor apples or oranges.And switching out frame's well you better have lot's of time.
A HAPPY AND SAFE FOURTH OF JULY TO ALL MEMBERS. DRIVE SAFE AND REMEMBER THE JOURNEY IS HALF THE FUN OF ARRIVING AT THE DESTINATION INTACT.
OPPS ON SECOND THOUGHT I THINK I WILL SAND OFF THE RUST AND PRIMER AND PAINT IT AND REINSTALL.THANKS REDPATH 88
THATS GREAT THOUGH 69 BUICK MY FIRST CAR WAS A 1959 STUDEBAKER I PAID $35.00 DOLLARS FOR AT JUNK YARD AND DROVE IT TILL THE WHEELS FELL OFF. HA HA CANT DO THAT ANYMORE.
sorry to hear but hey they did'nt stop making pathfinders when they made yours.Right, you will find another or it's equivalent.
yea I know my way around Ignacio, Red boy pizza! Ive shopped at the safeway there to. But alas met a gal from a small town in IOWA. Had a little girl and moved here. Its a change but I agree with you lifes as hectic as you make it.Hey you don't even pay for your gasoline out here until youve pumped it. Right ! When I first went up to pay first the guy looked at me like I was crazy.mayberry rfd.HA,ha!! Thanks PRECISE1
Legal .smeagal it's all a state of mind if it works do it.I lived in california for years donated two cars because they could not pass smog.But here in midwest I swear i have seen people pouring smoke out of their tailpipes right in front of police and nothing comes of it.
old welders trick is to remove tank empty all gas and fill with water weld away no danger at all.drain water dry out and your back in bussiness. man getting it off though is another matter I broke 3 bolts out of six had to drill out and use easy outs.replaced with all new bolts.
I agree weather permitting I live in Iowa and winters can be rough. My 95 pathfinder has got 140,000 miles on the original timing belt. Crossing my fingers and knocking on wood.Plan to replace ASAP just got pathy In May 2012.
Some love for Colorado right now amidst the fires...
AzZo replied to Boosted's topic in General Forums
Yea, hope the best for all of Colorado one of the worst years for fire Ive seen in a long time. good luck and god bless + -
Precise1, Just checking back, you said to remind you I just need one fuel injector with blue dot on the back of it.Can pay you some thing not a lot things a little tight these days Damm recession and can send you large envelope to mail it if you've still got one.Let me know one way or the other.Much thanks.jack
Thank's I was wondering what the heck that plastic pipe was for as it seemed to sit there doing nothing I thought it was for better air flow but that it was missing a piece.Ha,Ha,learn something new everyday. I plan to lose it tomorrow. Thanks again! You guys are great.
thanks again trogdor636.you have been a great help from day one of this.Seriously BIG THANK'S.
well i own a 1995 xe and believe it or not i jacked up rear end and spun wheel they both turned so thats a big yes I have a limited slip differential,Then the crappy 2 ton floor jack I was useing bent under the weight. I know two tons is 2000lbs and the pathy is at least 3500lbs. but all i had at the time and i had to know.no harm no foul and i know better than to be underneath a vehicle with out jack stands.
Well, here's the latest on my little problem. Quick update got a code 51 checked fuel injectors ohm's all at 12 except for number FIVE cylinder it read at 35 ohm's checked wiring harness to injector's all good then took out passenger seat and checked ecu circuts to injectors all read good continuity .checked fusible links everything seem's to be pointing at a bad injector #5 CYL. It's gotta be on the way out.I took a mirror and flashlight and the color on the back of injector is blue.So I will be replacing with same color as I have heard that it makes a big difference.Going to check local junk yard first as I am not made of money.They have one 1992 pathfinder so I am hopeing no one's got to the injectors yet and that they are blue coded.Can you believe that 3 junk yards in area and only one pathy and a couple of nissan trucks.Big shout out to all who joined in on this topic got a lot of positive feed back and excelent ideas.on what to do.precise1 thanks again wow 3 pathfinders I am impressed.I may pick up another just for the extra part's HA,HA!!
