4
Everything posted by patqx4
Sure, no harm in trying it out. You should be able to download the free version and use it with your WiFi adapter.
Interesting, I'm not at all familiar with iOS, so your post prompted some Google sleuthing. It looks like iPhone has BT pairing issues, so WiFi is the preferred choice on that platform. Not so with android, and from what I've read, pairing to multiple BT devices shouldn't pose a problem? I do use hands free calling, so I'll wait and see on that one. About the transmission pid, not sure tbh, I thought there might be one because I've seen torque screenshots (on different vehicles) showing transmission temp guage. If we don't have one, bummer. I found this thread last night, Dan.f posted a link to the same adapter, so thanks for confirming that, rebelord. Amazon won't ship that item to Canada for some reason, so I found it on eBay instead.
Thanks man, I've been using a similar setup with OBDwiz+laptop for years, it works well for pulling codes. I would like to have torque instead for a couple reasons, first being that I always have my phone with me, and never my laptop unless I'm home, so there's the convenience. The second reason is viewing live data. The main thing s I'd like to be able to keep an eye on are engine coolant temp and trans temp. I remember towncivilian talking about using it with his 01, but he hasn't been active for a long time, or I would ask him...
Does anybody in R50 land run torque for android via Bluetooth obd2 adapter? I need a recommendation for an adapter. I tried a cheap ELM327 clone adapter from eBay, no dice. I just want it to work now and am looking for any known working adapter with torque + R50.
Got it, I have everything except the hardware now. If all goes to plan I'll have it together this weekend.
So if I'm understanding you correctly, you tightened down the nylon nut inside the body spacer? Was it difficult to get a socket in there? Edit: I'm an idiot, disregard that. I had to think way too hard about that to visualize what you meant.
I feel you novapath, we need protection from rocks on these rigs. You running skids?
A special tool for rear lower control arm? 2000 pathy 4wd
patqx4 replied to kane's topic in 96-2004 R50 Pathfinders
If you have access to an impact gun that's what will work best, hold the wrench in one hand and the impact gun with the other. -
Biggest tires on 2000 Pathy SE with 2"AC lift.
patqx4 replied to tdurb1327's topic in 96-2004 R50 Pathfinders
Sounds sketchy, but maybe I'm wrong. Got any pics of this? -
Park in well lit areas. Lock your doors. Most importantly, don't leave anything of value what so ever in sight. If you have valuable wheels and/or tires, use lug locks. Just use common sense, and remember that if someone wants your truck badly enough, nothing will stop them from taking it.
285/75/16 is 11.22" wide, I think op wants to run stock wheels. I would not go that wide on 7" wheels. -
Lund Moon visor and 4 door pathfinder flares available
patqx4 replied to ahardb0dy's topic in General Forums
I'm interested in the flares if they're off a facelift r50 -
Nice truck man, good call getting a rust free one. Keep it undercoated! I plan to do the same thing when mine gives up the ghost and import a pathy/qx4 from the southwest.
Right on, beautiful photos!
- 2 replies
- 1
- WD21
- Pathfinder
(and 6 more)
Tagged with:
Whoa! Those guys are nuts, they go so deep their trucks start floating away... Takes some big balls to do that
Welcome! Always nice to see another qx4
I went through a river that had water over the top of the tires, only issue was water got into the front diff.
Cool pictures, what was the trail carnage suffered?
Well, crap! I guess I should have asked you first.. itchy trigger finger. Oh well it's on its way now, the ES bump stops are actually 2.5" wide, so .5" less than stock, and 3/8" hole. They have a smaller 2" diameter set that looks the same as well. I'll update this thread once they're installed and tested.
Thanks for that info, you don't happen to also remember the socket size of the stock bolt do you? My local Nissan dealer wants $108 per bumpstop... Yeah, no thanks. I've looked around and can't find an oe aftermarket replacement, so I got the Energy Suspension 9-9143R. They look like they will squish more than the OEM one so I went with the BB02, if it turns out to be too much, I'll switch to the BB01.
Oh man, that's perfect! So the hole in the spacer is the right size for the stock bolt? I think I'm going to get the BB01 1" flavor of these. Thanks hawairish
Stupidly, I didn't replace my missing rear axle bump stops, and with 32's and no sway bar I overflexed and popped a flare. This got me wondering if there are any bigger bump stops that will fit our trucks. Obviously stock ones will be better than none but I vaguely remember seeing somewhere on here where someone had bigger or extended length stops.
I wish mine were as rusty as yours! I popped a rear flare under flex and saw this
Cool pics nova, what did you end up doing for stronger trailing arms? I know you were having issues with bending them. I bent one yesterday, definitely need something stronger.
