33
Everything posted by theexbrit
I originally had 2x12" fans in an aluminum shroud that only covered 2/3rds of the rad & I always had over heating problems on long, slow hills. I have since fitted a Taurus 2 speed fan, a Dakota Digital controller & an OEM shroud, nary a heat problem now!!
:laugh: Or sounds like a foot fungus cure........
I'm leaning towards the BA's but I read somewhere that they just repackage other folks stuff.
I need to replace my control arms & I've been reading different reviews as to the best make, I know it's all subjective but basically is it Moog, Beck Arnley or Mevotech?
The final word on lifting the R50 at a low Cost
theexbrit replied to fleurys's topic in 96-2004 R50 Pathfinders
Stink Bug is not my favorite look! How does yours drive without the rear sway bar? I keep contemplating removing mine. I have the 5100 Bilsteins I think, I recently got extended, steel braided brake lines in preperation for if/when I get a SFD. I also have a new master cylinder, I'll probably fit the brake stuff next week. -
How's that Lokka feel? I heard it can get pretty gnarley when it bangs on & off, leads to some funky steering..... Apparently this TJM will fit our R50's, good price too...... http://www.summitracing.com/parts/tjm-168pl04/overview/year/1996/make/nissan/model/pathfinder
I'm wondering if the rear brake line & shocks (Bilstein) would be extended too much if I put 1.5" spacers on top of the AC 2" rear lift? -
Thank you Einstein, you lost me at "26.5%" :laugh: :laugh: Seriously though, I think you're correct with the 2.25" if you go with dual out. I was thinking of dual out so that the pulses didn't have to merge but I think I'll follow your advice & talk to my local muffler shop.
I'm leaning more towards precise's scenario, on a stock motor you don't want to go too big. I'm thinking stock 2" up to the muffler then 2 in & 2 out (why have the different exhaust pulses hitting) then 2.5" to the tail pipes. The only other thing that might help would be newer cats that have better flow, but they're around $300 a pop so until I get a cel & codes (420 & 430 I believe) I'll leave them alone. The old girl is running pretty good, acceleration is good, etc, so I don't want to change things too much.
Just read that article, pretty interesting. Here's a great article about the Backpressure Myth, it's a long read but worth it......... "Destroying a myth. Some say that "an engine needs backpressure to work correctly." Is this true? No. It would be more correct to say, "a perfectly stock engine that cannot adjust its fuel delivery needs backpressure to work correctly." This idea is a myth. As with all myths, however, there is a hint of fact with this one. Particularly, some people equate backpressure with torque, and others fear that too little backpressure will lead to valve burning. The first reason why people say "backpressure is good" is because they believe that increased backpressure by itself will increase torque, particularly with a stock exhaust manifold. Granted, some stock manifolds act somewhat like performance headers at low RPM, but these manifolds will exhibit poor performance at higher RPM. This, however does not automatically lead to the conclusion that backpressure produces more torque. The increase in torque is not due to backpressure, but to the effects of changes in fuel/air mixture, which will be described in more detail below. The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure. The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well. Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating. Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust because of the way that backpressure caused air to flow backwards through the carburetor after the air already got loaded down with fuel, and caused the air to receive a second load of fuel. While a bad design, it was nonetheless used in a lot of vehicles. Once these vehicles received performance mods that reduced backpressure, they no longer had that double-loading effect, and then tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque. Modern BMWs don't have to worry about the effects described above, because the DME (car's computer) that controls the engine will detect that the engine is burning leaner than before, and will adjust fuel injection to compensate. So, in effect, reducing backpressure really does two good things: The engine can use work otherwise spent pushing exhaust gas out the tailpipe to propel the car forward, and the engine breathes better. Of course, the DME's ability to adjust fuel injection is limited by the physical parameters of the injection system (such as injector maximum flow rate and fuel system pressure), but with exhaust backpressure reduction, these limits won't be reached. Exhaust Backpressure Study Replacing the stock production exhaust system with a low-restriction, free-flow one is usually one of the first modifications made to any vehicle in the name of performance. We all know they're louder, but how much performance do they really add? We've all seen supposed dyno tests, usually run by the exhaust manufacturer's themselves on their own dyno, indicating vast power gains, and psychologically, we always equate a healthy exhaust rumble with increased power in the seat of the pants, but how much power are we really gaining? To find out, we're running a simple backpressure study, and our results will be posted here as they come. Admittedly this study is not totally scientific as there are many uncontrolled variables, but it should be sufficient to provide a rough estimate. It is generally accepted by automotive engineers that for every inch of Hg of backpressure (that's Mercury - inches of Hg is a unit for measuring pressure) approximately 1-2 HP is lost depending on the displacement and efficiency of the engine, the combustion chamber design, etc. Our sources indicated that in the case of the L67 3800SC, 1HP per inch of Hg is reasonable. 1 inch Hg backpressure = 1 HP lost For reference, we have the following conversions factors: 1 ATM = 14.7 PSI = 76 cm of Hg = 29.921 inches of Hg = 1.013 bar Our test vehicle is a '97 Buick Regal GS with 3800SC engine transversely mounted. It's exhaust system consists of a cast iron exhaust manifold on the left side of the engine which connects into a tuned tubular header on the right side, both banks connected to a single downpipe into a catalyst. The output of the catalyst runs into a resonator and then into a single muffler; all pipes are 2.25 inch. The exhaust system is very similar in the Pontiac GTP, the differences being that the GTP splits into 2 mufflers after the resonator. Our sources indicate that the GTP system results in approximately 3 in Hg less backpressure than the Regal, hence there is 3 less horsepower loss. To measure system backpressure, a sample tube was mounted before the catalyst into the downtube A flexible hose is run from the sample tube and attached to a pressure gauge inside the car for monitoring. We first ran the test with the complete full factory exhaust, and next dropped the entire system from the catalyst back. The final test was run with the muffler removed. Only the catalyst, resonator, and the majority of 2.25 tubing up to the muffler remained. Next we took a look at the restrictive U bend that houses the post O2 sensor. It's function is to protect the O2 sensor from damage by positioning it straight up. This restrictive U bend is completely removed, and replaced with a straight 3" piece. (Note this 3" piece is not the actual replacement pipe - it's just a scrap piece for the photo.) This U bent tube is replaced by this straight 3" pipe. The O2 sensor is mounted to the side - less protected, but it'll be OK unless you go off-roading as we recently did! Results & Conclusions We ran three tests, observing three runs with each configuration and averaging the three. Peak backpressure occurred near the engine RPM redline of 5700-6000 rpm, at a max boost of approximately 7-8 psi. We took all our readings at WOT immediately before the 1-2 shift. Although we performed our tests on a Buick Regal GS, we predict a GTP will have similar results, taking into account the 3 in Hg difference. We realize our tests are not totally scientific, and they were not meant to be. Our goal is to obtain a ballpark estimate which, as the saying goes, is "good enough for government work." [before you government employees start flaming us - one of our associates worked for the US Army Corps of Engineers for several years, so we know how it is. 8^) ] 1. Full factory exhaust system of catalyst, resonator & muffler: 28-30 in Hg = 28-30HP lost [system is whisper quiet] 2. Only catalyst in place, no resonator or muffler after the cat: 13-14 in Hg = 13-14HP lost, thus approximately 14-17 HP gained over stock full exhaust [system is unbearably loud and shakes the entire car, conversation is impossible] 3. No muffler, just resonator, catalyst & tubing 20 in Hg = 20HP lost, thus approximately 10HP gained over stock full exhaust [system is bearable, but has some bad resonances and drones at particular RPMs.] 4. "U" pipe replaced with straight 3" pipe Testing to be determined. The catalyst was never removed as we were only interested in achieving an optimal cat-back system. We can see from our results that the muffler is costing approximately 10HP loss while the resonator accounts for a 6HP drop, with everything from catalyst to the engine costing 14-15HP. Therefore, it's evident that at best, a free-flow system will gain perhaps 10HP - and that's for a noisy system, while one which controls irritating resonances and drones better would probably gain less than that. Therefore, a 5-7HP gain from a cat-back exhaust system is probably in the ballpark for achievable gains. Will removing the catalyst help? Definitely, but that's illegal for street use and probably more importantly to some folks out there, it sets an OBDII Malf code. Replacing the factory catalyst with a high-flow unit will not result in a significant increase either, as those "high-flow" units outflow a production unit by a couple of inches of Hg at best. In fact, our sources indicate that the catalyst on these cars are actually one of the least restrictive available. With a FWD platform, we're stuck with uneven header lengths due to the transverse mounted engine, limiting one's ability to truly optimize the header design. Therefore, it is probably more fruitful and definitely more cost effective to examine the situation after the catalyst. The difficulty in designing an effective exhaust system is in minimizing backpressure while achieving a desirable exhaust tone with minimal resonances and drones. It has been suggested that replacing both the resonator and muffler with a single large staight-thru muffler (with dual outlets for the GTP) may be the best solution. Headers are one of the easiest bolt-on accessories you can use to improve an engine's performance. The goal of headers is to make it easier for the engine to push exhaust gases out of the cylinders. When you look at the four-stroke cycle in How Car Engines Work, you can see that the engine produces all of its power during the power stroke. The gasoline in the cylinder burns and expands during this stroke, generating power. The other three strokes are necessary evils required to make the power stroke possible. If these three strokes consume power, they are a drain on the engine. During the exhaust stroke, a good way for an engine to lose power is through back pressure. The exhaust valve opens at the beginning of the exhaust stroke, and then the piston pushes the exhaust gases out of the cylinder. If there is any amount of resistance that the piston has to push against to force the exhaust gases out, power is wasted. Using two exhaust valves rather than one improves the flow by making the hole that the exhaust gases travel through larger. In a normal engine, once the exhaust gases exit the cylinder they end up in the exhaust manifold. In a four-cylinder or eight-cylinder engine, there are four cylinders using the same manifold. From the manifold, the exhaust gases flow into one pipe toward the catalytic converter and the *muffler. It turns out that the manifold can be an important source of back pressure because exhaust gases from one cylinder build up pressure in the manifold that affects the next cylinder that uses the manifold. The idea behind an exhaust header is to eliminate the manifold's back pressure. Instead of a common manifold that all of the cylinders share, each cylinder gets its own exhaust pipe. These pipes come together in a larger pipe called the collector. The individual pipes are cut and bent so that each one is the same length as the others. By making them the same length, it guarantees that each cylinder's exhaust gases arrive in the collector spaced out equally so there is no back pressure generated by the cylinders sharing the collector. Headers are one of the easiest bolt-on accessories you can use to improve an engine's performance. The goal of headers is to make it easier for the engine to push exhaust gases out of the cylinders. When you look at the four-stroke cycle in How Car Engines Work, you can see that the engine produces all of its power during the power stroke. The gasoline in the cylinder burns and expands during this stroke, generating power. The other three strokes are necessary evils required to make the power stroke possible. If these three strokes consume power, they are a drain on the engine. During the exhaust stroke, a good way for an engine to lose power is through back pressure. The exhaust valve opens at the beginning of the exhaust stroke, and then the piston pushes the exhaust gases out of the cylinder. If there is any amount of resistance that the piston has to push against to force the exhaust gases out, power is wasted. Using two exhaust valves rather than one improves the flow by making the hole that the exhaust gases travel through larger. You can increase backpressure easily by sticking a potato into your exhaust pipe. Potatoes are not known to be a power booster in most cars."
Need to replace front stabilizer bushings
theexbrit replied to Darek's topic in 96-2004 R50 Pathfinders
That is indeed the sway bar link, Darek. I have done mine, it's an easy job but you need a good long hex wrench to hold the ball joint while you tighten the nut. These will make a clunking sound if they are failing or loose (as 1 of mine was). I would just replace them anyway, they're cheap enough (about $20 here in the US). -
I ripped the stupid tubular resonator thingy off the last 2 feet of the tailpipe so it's just straight pipe from the muffler box to the end of the tail pipe. It gives it a little more of a throaty sound, not much but a little. It doesn't seem to have affected performance any, I think it was just added by Nissan to remove any highway "drone" noise for the mall cruizer crowd.
:laugh: No, we're good. The answer appears to be that you could add another 1" or so by using a spacer. The angles etc, should be the same as before the sfd, just the body will be 4" higher so you could add the same amount of spacer lift as you could when it was stock.
I'm not too concerned about noise, I'm more interested in hearing about engine performance. Higher top\end with Flowmaster/Magnaflow, loss of low end torque, etc...
Sooooo, I've been reading up on mufflers & I'm interested to get input from you guys. Taking into consideration back pressure (for low end torque), what would you guys say is a good pipe size (I read it's only supposed to be 25-30 % over stock or you'll lose too much low end power) & muffler combo for the VG33?
Ok, ok, so I didn't search very hard, but I did search! :laugh: Thanks for that link B.
I searched but couldn't find a definitive answer, the question is..... Can you use a front strut spacer with the Krypton Fabs sfd?
Yeah, good luck bro. Let us know how it goes.
Duratracs got a sidewall puncture today :-( Good thing is, it's covered under the insurance! :-)
Heading to my garage to replace all 4 oxygen sensors & heater control panel/unit.
Long "Expedition" style trails
:laugh: :laugh: I "gunned" my lug nuts on a while back & forgot to torque them after. Out on the trail I heard this weird knocking sound, so walking round the car checking things I noticed my 2 front wheels were hanging off I lost a lug nut, so added a spare, tightened them up & all was good to go.
Not trying to hijack the thread, but this seems like a good place for this article on exhausts............. "There is a common misconception that engines need backpressure in order to run properly, generate low end torque, etc. That is simply untrue. Backpressure is a bad thing. Always. Take a look at a top fuel dragster...how much backpressure do you think those zoomie headers make? Very little, and those engines produce 6500 hp. So, what is backpressure? Any fluid flowing through a pipe experiences drag on the walls of the pipe. This depends on a number of factors, including the diameter of the pipe, the smoothness of the inside of the pipe, the viscosity of the fluid, and the velocity of the fluid. This drag results in a pressure drop through the pipe. In order for the fluid to flow at all, the pressure on one end of the pipe must be higher than at the other. In an exhaust system, that pressure drop is what we refer to as backpressure. It's pretty obvious that the engine has to produce this pressure differential, so the less power it has to spend making pressure to push the exhaust out, the more power it can send to the wheels. Given that exhaust pipes are pretty smooth, and that we can't change the viscosity (thickness) of the waste gas being forced through the pipes, we are left with basically 2 parameters we can have any control over: The pipe diameter and the gas velocity. Unfortunately, the pipe diameter controls the gas velocity since the volume of gas is prescribed by the engine. So, we really only have one thing we can change. So, bigger pipes allow less pressure drop for a given volume of gas because the velocity is lower. The pressure drop (backpressure increase) is proportional the gas velocity squared, so if I double the gas velocity (by reducing the cross sectional area of the exhaust pipe by half) then I quadruple the pressure drop. Well, there's an easy solution for that: Just make the exhaust pipe bigger. Bigger pipe, lower gas velocity, less pressure drop, so less backpressure. Wow, that was easy. After all, this is the way it's done for basically any type of commercial plumbing system. Need less pressure drop on a chilled water pipe or a natural gas line? Just make the pipe bigger. But wait, there's a problem....Having a huge exhaust pipe has killed my low end torque!!! What's different? Oh, there's no backpressure!! Therefore backpressure makes torque! Wrong. An exhaust system is different than just about any other plumbing situation. How? Because the flow is pulsed, and this turns out to be a big deal. Every time a pulse of exhaust gas runs through the pipe, a strange thing happens: it as it passes, it has a little area of vacuum behind it. Just like a NASCAR stocker running around the track, the pulse generates a little bit of a vacuum behind it. In NASCAR, a driver can take advantage of another driver's vacuum by getting right behind him and driving in it. The wind resistance is drastically reduced. This is called drafting. Well, how big the vacuum behind each pules is depends on the gas velocity. The higher the velocity, the bigger the vacuum the pulse has behind it. Now, this means that I can "draft" the next pulse, just like in NASCAR. In NASCAR, it's called drafting, in an exhaust system, it's called scavenging. You've probably seen this term used when talking about headers, but the same concept applies in the pipe. I get the maximum scavenging effect if the gas velocity is high, so the pipe needs to be small. By maximizing the scavenging effect, I help to pull pulses out of the combustion chamber, which means the engine doesn't have to work as hard to do that. This has the most effect when there's a bunch of time between pulses...in other words, at low rpm. As the revs rise, the pulsed flow becomes more and more like constant flow, and the scavenging effect is diminished. So, at low rpm I need a small pipe to maximize scavenging, and at high rpm I need a big pipe to minimize pressure drop. My exhaust pipe can only be one size, so it's a compromise. For a given engine, one pipe diameter will make the most overall power (i.e., have the largest area under the curve on a dyno chart). So, the loss of torque has nothing to do with backpressure, and everything to do with gas velocity. So you need exhaust components that are not restricive (manifolds/headers, mufflers) and that are sized correctly for your application. To further dispel the "backpressure is necessary" theory, try this if you want. If you have access to a vehicle with open headers, make a block off plate that will bolt to the collector. This plate should have only a 1" hole in it for the exhaust to flow through. That will give you PLENTY of backpressure, and zero scavenging. Then you can report back on how much low end power it has. The one exception to sizing an exhaust is for turbo cars. Since the turbo is in the exhaust stream, the gas flow spinning the impeller tends to come out of the turbo with the pulses greatly diminished. In this case, you can get away with running a larger pipe than on an equivalent HP N/A engine because you can't take as much advantage of the scavenging effect." Courtesy; J Branne, DSMTuners.com
Kyle is correct, It's just on 2". I went out & measured it.
