tdauria
Everything posted by tdauria
  1. @bubbley thats a really good idea. Rare earth magnets out of a hard drive or something would probably work really well. I'm making a trip back upstate to my apartment for school in the next week or so, and they have a kickass pick n pull up there. If you want i could see if any of the pathys there have the part still. Is it just the little clip type thing you need?
  2. Congrats! Just made it this tuesday as well http://instagram.com/p/Z4DX-jkwEo/
  3. Sadly, I have no answers to your questions but depending on how bad the crack is and how desperate you get, you MIGHT be able to get a result using this technique with beer cans and jb weld (if this crack is on the outside surface)... http://jalopnik.com/5949291/how-to-fix-your-exhaust-with-an-empty-beer-can
  4. I'm so happy someone's finally doing this. As a computer engineering student and eager-to-learn car fanatic this is seriously the perfect combination of my interests. Best of luck and keep us updated!
  5. Look for your 3-digit paint code on the plaque on your firewall or possibly in the door jamb. I know on my 95 it was on the firewall, not sure if it was on the door jamb as well. (It will probably be DJ2 or FL1) Duplicolor sells tons of factory paint color matched rattle cans, but if they don't have your color you can check local paint or automotive stores. I had a shop nearby mix up the paint and put it in a spray can for about $30. I would assume an automotive paint or body shop could mix up the paint for use in an air or electric powered gun, but I have no idea how much that would run you. Don't forget the clearcoat! Duplicolor generic clearcoat spray cans worked well enough for my touch-up areas.
  6. That should jump to a point in the video where you can see what seem to be factory rear fog lights in the bumper of a WD21!
  7. I would say more like golden And thanks Leo94, that video of the HB dying is now going to be my first response when my jeeper friends try to bash the pathy again! Those Heeps start to overheat if you so much as look at them the wrong way
  8. Fairly certain we don't have a sensor for the seat belt, the light just goes on for a second or two when the ignition is switched to on, like it's trying to say "You should totally use the seat belt, but I couldn't care less if you actually do"
  9. @unccpathfinder i have the same thing in my 95, no idea what the heck its for
  10. I remember seeing this one a few years ago They took it out of the frozen lake on Dirty Jobs... poor pathy (the episode is free to stream if you have amazon prime)
  11. I know this thread is pretty old and dead but as far as I can tell it contains the most/most valuable info on the apparently hellish task of adding a tire carrier. So, I called AC and they no longer carry the mounting brackets as of 4/25/13. I got the easily removed bracket from the inside of a JY truck along with the strike plate and latch and all those goodies. I'm slowly getting a picture in my head of the install process based on these posts and a few others. Can anyone point out exactly which other parts i'm going to have to get? If I'm not mistaken the one bracket I got out was 57284.
  12. I hope to get a couple of these done over spring break as well, the best of luck to you! Also maybe it was just because ive never worked with snaprings before, but i ended up screwing around with the damn thing for maybe a half hour before i got it out. I used snap ring pliers i picked up at lowes, possibly the problem was with the tool (?). Nevertheless persistence is key! Had to slice the gearshift boot too since i got frustrated with the tcase shifter knob, its STUCK on there... Maybe try messing around with it in advance so it isn't an issue when youre ready to start workin'
  13. I also have the BFG All Terrain T/A KO 31x10.5" R15. Figured it was worth mentioning they feel a bit stiff for me when on crappy asphalt. Never really had much of a problem with traction in rain/snow/dirt/sand/light mud though so i guess they do what they're meant to.
  14. First thing i thought of was Nissan's "Super Silver" i believe it cost an extra $3k on the R35 GTR, not sure if it still does. slightly ridiculous IMO
  15. If you still haven't found a solution for this, maybe even some light sanding on the plastic lens of the leds could help diffuse the light a little better
  16. 0 gauge? what kind of setup are you running in there?
  17. Thanks! Did a bunch of searching around and pondering since i have limited tools, space (college apartment), but mostly it's freakin' cold and the less time fussing around under the hood the better at the moment lol Quick tip: You can see I put male-female connectors on the pigtails of the socket... This way it's much easier to swap out the sockets (could only find crappy plastic ones), switch to IPF's or E-code housings Also added a dab of dielectric grease to keep the connections healthy and put a little piece of gorilla tape over each to insulate
  18. it's not much but this is what mine looks like. I used 3-conductor, 12ga underground feeder wire from lowe's. Insulation is nice and thick and the install comes out really clean. http://i132.photobucket.com/albums/q6/iTHINKiHAVE_add/NPORA/99C2DBDC-D4C3-47B3-96D6-86F163E2B331-1510-0000003E2A793BED_zps856dfe5b.jpg
  19. Heres the best pic i could grab of mine with my phone http://i132.photobucket.com/albums/q6/iTHINKiHAVE_add/NPORA/c1573d9460ce31bf0b8ca383382282f2_zpsaf0a9a34.jpg Hopefully this isnt poor placement...please inform me if it is but i havent had any problems with the wire here i just took note of where the wire would go through the firewall, pulled it out a bit and wrapped it in a few layers of electrical tape to kind of seal any gaps
  20. I ran mine through the firewall somewhere near the glove box, pulled up some of the carpet on the passenger side in the front and I believe I tried to follow the harness that was there a bit. It got tight by the passenger seatbelt anchor, but other than that everything went pretty easily and I didn't have too much of an idea as to what i was doing... Just don't forget to run the RCA cables the first time like i did! I mounted the mono amp on the back of the rear seat, driver's side. I'd be glad to help if you run into any trouble with pics if i can. '95 XE
  21. Yeeeah i guess for a little while there i was a less bright version of the people running around with HIDs and no projectors -which happens to be one of my biggest pet peeves- Haha ok well if those are the necessary measures for getting in there I'll deal until i get E-Codes or something. Thanks for the info!
  22. I've actually been to the place they make that monstaliner and from what i could tell they definitely try to keep overhead costs down and their products seem to be of very good quality. I used their chassis saver (similar to por-15) on my frame and its holding up really well from what i can tell, and my friend used red monstaliner on the floorpan of his jeep about a year ago and that stuff is really intact as well. Don't know of anyone that's done it on the outside though. let us know if/what you end up doing!
  23. Well I do now, lol note that due to the arrangement of the picture some wires are not to scale. The three wires going to the passenger side headlight are about 2-3 feet long, the driver's side are about 5. (My relays have two 87 pins each.) modified image from Daniel Stern Lighting, for educational purposes only.
  24. Ah i meant cleaning the inside, i can make out a tiiny bit of moisture and dust woulnt think enough to make a difference And on the lights theyre actually excellent bulbs, tiny bit of blue coating only at the very end ive read it is one of the best options for 9004s along with the NightHawks As for the different lengths, the weird part is that side has a much SHORTER set of wires as its close to the battery. 12ga everywhere including the inline fuse and pigtails on the socket and grounds directly to negative on the battery
  25. So i just switched from the stupid 9007 bulbs and made a new relay harness (came out really good actually might post about it haha) Switching back to legal & safe 9004s, philips vision plus. Ive noticed my passenger side always seems to throw a much less bright, less white light. This was the case with the 9007s and i figured it was just a bad ground from my old harness. The weird thing is that the problem persisted when i took out the relays and went back to the stock wiring. And now, even with a newly made harness and bulbs, that headlight seems to still be duller. I tested GE Nighthawk platinums and they did the same thing too. I do have those angry eye things spraypainted onto my glass lens, but would this cause it to look a little yellow? I'm considering taking them out and trying to clean the inside of the lenses, has anyone done this before? (They dont look like theres much of anything in there but i figured it coulnt hurt) Another thought was that maybe its just due to the different beam patterns of the right and left lenses... I'll see if i can get it to show up in a picture tomorrow. Any thoughts appreciated!
