Pav last won the day on June 17 2016
Pav had the most liked content!
About Pav
- Birthday 04/22/1975
Stock 1995 SE
36-40
Rarely Go Off-Road
1995
Gender
Canada
Country
Canada
12,493 profile views
Pav's Achievements
NPORA Fulltime Resident (4/5)
51
I have a NuStart that has not failed me yet and is widely available in Canada.
How did the adjustable suspension on the 93 SE work?
Pav replied to morgant's topic in 90-95 WD21 Pathfinders
They should still be available. I got mine at Nissan when I first got my truck and was having the LSD and other fluids done. I can't remember how much they were, I would have to check my invoice. I like to leave it in Sport mode for the firmer ride and better cornering. -
Full size spare rim smaller than the rest of my wheels
Pav replied to Backpacker's topic in 86.5-89 WD21 Pathfinders
If you can find steel rims from a first generation Xterra their rims were 15x7 and perfect for mounting a 31. I gave a set away to SpecialWarr so he can confirm. -
If I had a 2 door like yours I'd look for the OEM Targa band light bar. You might even be able to get it brand new by looking around. Its part number 999F3W7000. https://www.factorynissanparts.com/parts/1988/Nissan/Pathfinder/SE/index.cfm?siteid=214081 With the targa bar you could put on a much larger LED bar. There are a quite a few members here that have them and I think they look amazing.
What happened to Courtesy Nissan Dallas Parts Site?
Pav replied to colinnwn's topic in General Forums
I've always used Rob's (member here) expert service and they are also in Texas. He doesn't come on here much so best to just give him a call and put in your order and tell him you are a member. They have the diagrams I think you are searching for. https://www.factorynissanparts.com/ -
Yeah, I'm quite sure it was for an ignition/engine kill switch and has been disconnected based on its location and where it leads. I disconnected mine when the security key started to act up and I got tired or reaching under my steering column and fiddling around to find that button to start my '95 Maxima.
Looks to me like an over ride button for an engine kill switch. I have a button like that on my '95 Maxima that came with an engine kill installed by the Nissan dealer. Basically, if you don't have the special key to disarm the engine kill you can press that button and it will over ride the system and let you start the truck without the key.
Here is a diagram with some of the lengths in millimetres. (L=mm)
Welcome to the Club. Some of the things you mentioned you could likely find at a scrap yard (wiring harness). If you want brand new Nissan. Reach out to Rob (member here) at www.factorynissanparts.com. He knows what he's talking about when it comes to our trucks. Plus he is also in Texas and their shipping cost isn't bad. Cheers
Welcome to the Club. If you search on here you will see what your options are to fix the transmission problem. Fun thing about the WD21 is parts are cheap and plentiful especially in your state. I would just find a replacement and make sure you have an auxiliary transmission cooler on the new one and you should be good for many years to come. Cheers
If you want a manual...which I understand...its going be harder to find one. You might want to add Xterra(s) to your hunt to give you more options. If you are willing to travel a bit I have noticed there are more manual 2 door WD21's in Washington state for some reason. The red one...if you look at the driver's side rear window it is not tinted like it is supposed to be and was replaced with one from an XE. The other side has the original SE tinted window.
Since you are in California I would keep looking. You're in the land of milk and honey to find a well kept WD21. I remember a year ago there was a red '90 2 door for sale in San Diego for $1,400 that was in way better condition that someone had posted here. Both of those trucks seem to have some mystery behind them. The red 2 door was in some type of accident since the rear driver side window was replaced.
I would still just go out there and tap away along the entire frame. Make sure to check out the horizontal portions too. There are drain holes along the bottom that get clogged up over time. You can use a screwdriver to poke around and open them up. If there is a lot of debris in the frame you will likely have to use your hose and shoot water through it to loosen it up. Squirt some...well a lot of liquid dish washing detergent to help break up the junk inside. I find its easiest having the front elevated to let gravity help move the water through it. Adamzan's keen eye noticed that the rear of the frame has already been plated/patched so it would be good to see how the work was done and how its holding up. If you see that parts are crumbling off then by all means go check out some shops that will weld it up.
