Slartibartfast
  1. Oh, that sucks. Did you run the bolt in with the impact? Loctite? Or just an unlucky slip with the socket that rounded the head? Welding a nut or something to it would've been my go-to. Without a welder, cover anything you don't want abrasives in (plan to wipe stuff down afterwards) and go after it with the angle grinder. Just be careful not to mess up the sprocket. You might get away with cutting a slot in the bolt head and using a slotted screwdriver bit in the impact, if you have something like that. Otherwise just grind the head off the bolt until it's not holding the sprocket anymore. Once the pressure's off, remove the sprocket, slot what's left of the bolt with the grinder, and back it out with a screwdriver (using the sprocket to hold the cam). Go slow so you don't cook the cam seal, and/or pack a wet shop towel in behind the sprocket if you can. (Given the thermal mass of the sprocket, bolt, and cam, I'd be surprised if you changed much with the torch.) Then remove the bolt from the other side, work out the diameter/thread/length, and order two.
  2. The bolt in the middle is the only one holding the balancer to the crank. The little bolts hold the crank pulley to the balancer. Mark the orientation of the crank pulley to the balancer before removing it so you don't put it back together in a different orientation and lose your ignition timing marks! It's been a while but I think I removed all the bolts, got the pulley out of the way, and then bolted the duck's foot puller to the balancer.
  3. ^I think those fender extensions were part of the under-bumper trim strip bollocks I took off of mine. Clipped to the bottoms of the fenders and probably to the flares as well, I vaguely remember trimming the flares afterwards. I'll have to check my parts pile, I may have a set of fog light brackets. I don't remember if I sold them with the housings or not.
  4. Nice rig! I haven't done the bumper swap myself (both of mine came with the later style) but I know it's been done. From having mine apart, I know there's a steel mounting bracket behind the fog light that's not pictured. The fog light bracket goes behind the plastic insert (which look like you'll have to trim them to install fog lights), two fiddly plastic trim pieces go over the outside of the insert to hide the gap between the fog light and the insert, and machine-thread screws go through the holes in the trims and the insert into the fog light bracket to hold it all together. Probably sandwiches two of the bracket tabs on the bumper as well, looking at the picture (been a while since I had mine apart). You may need a couple plastic clips for the coarse-thread screws that hold the turn signal housing and insert to the bumper. Looks like the bumper brackets have the same part number, so your old ones should work with the new bumper if they're not messed up. Mine had a stamped sheet metal fascia piece that went under the bumper, some kind of narrow gap filler kinda deal. It got bent up and I couldn't be arsed to straighten it, so in the bin it went. It would probably conflict with your existing fascia anyway. Worth noting, the later bumpers aren't any more durable than what you had. Both times I've hit something (both low speed, one ditch and one deer), the bumper collapsed into the fender and bent it back far enough to push the flare against the tire. One of these days I'm going to get rid of the stock bumper and a better one, but as usual this is not that day.
  5. I know your pain! I hate working on brakes. The rear hydraulic circuit on mine gave me a runaround for months and I'm still not sure what was wrong with it, and the local shops were about as useful as yours. Vibration and grabbing makes me think the drums aren't concentric to the axles. Check that the drums fit snugly on the hubs (no slop between the drum and hub that would let the drum sit off-center--I'd check this with the drum backwards to take the pads out of the equation) and that the end of the axle where the drum mates up is clean and flat (no chunk of dirt or rust or something making a drum sit cockeyed). If you really wanted to rule out the drums, you could remove the pads and backing plates, mount the drums and wheels, and check the contact surface of the drums for runout with a dial indicator. This seems excessive, but so does most of what I tried when my brakes weren't working. I can't think of what else would be making the brakes vibrate, unless there's something very wrong with the ABS. I've heard of brakes grabbing if the leading and trailing shoes are mixed up, but not as a vibration, more as a "touch the brakes and they lock up" sort of deal.
  6. You can get backup cameras with a bracket that goes behind the license plate, so the camera is right above it (or right below it, depending on how you set it up). You'd still need a hole for the wiring, but you might be able to hide that behind the plate or something. When I added aux reverse lights to mine, and needed a trigger for the relay, I checked the EL section of the service manual and found where the harness from the trans position sensor comes up through the engine bay, and tapped into one of the wires there.
  7. I got passed by a Winnebago once. He didn't honk, though, so that was nice.
  8. Sounds like something was telling the computer to lock the torque converter when it was in reverse. It's supposed to unlock when you press the brakes, which would explain why it was fine when the brake lights were on. Good that it wasn't the computer, '87 has a different trans vs other years and that might've been a tricky unit to find a replacement for. Good to hear you got it in the end, though, and thanks for closing the loop!
  9. I doubt the mechanic would've disabled it elsewhere. Could be that the refrigerant charge has leaked down enough over time that the low-pressure switch won't let the compressor kick on. I don't know why that would stop the light in the button from coming on, though. Could be that's on the circuit controlled by the pressure switch, or you could be correct about an electrical fault elsewhere that just isn't telling the aircon to engage in the first place. I wouldn't expect a faulty relay to explain the light not coming on, but I don't know how Nissan wired it up. The service manual should have the wiring diagram (probably in HA, if not try EL), and some troubleshooting ideas as well. My first check would be shorting out the low pressure switch. If the compressor starts with that bypassed, that's a pretty good sign that the gas is low and needs to be refilled (and the leak fixed, if you can find it). If you've got no voltage across the low pressure switch, you've got an electrical fault elsewhere.
  10. I pulled out the evap box to figure out why my heater whistled and struggled to move air. The evap core was chock full of pine needles and mud that probably used to be pine needles, which explains a lot. With that in the bin, and a fistful of mouse nest removed from below the heater core, the system is stronger, quieter, and at least 70% less likely to give the gift of hantavirus. Cuong, do you hear the pump priming when you turn the key?
  11. I would start by pulling the belt and checking that the pulley spins without obvious play, noise, or tight spots. I would try cold-starting it with the belt completely off to see if the noise goes away. If it does, you're on the right track. If not, your princess is in another castle. If the bearings are fine, but something's still squealing, you might try a different brand of belt before taking the clutch apart. The service manual doesn't even show that there is a bearing. I assume it's pressed into the pulley, and would come off the compressor snout with it, then come out of the pulley with a press (or a hammer and a socket). If the bearing is roached, chances are it's an off-the-shelf part that you could look up by the numbers on the sides. Before tracking down the bearing, examine the clutch and pulley to make sure they're not worn out, too.
  12. Good to hear you got it! Intermittent failures can be a pain to track down.
  13. As usual I would start with the service manuals for the Z and the R50. They won't come right out and say "yeah, you can totally bolt a transfer case to a Z tranny and here's the part number for the adapter," and they don't call out the part number unless there's more than one option, but the gear ratios are in the SDS at the end of the MT section and the exploded diagrams might give you some idea of whether the 2WD tailshaft unbolts and shares a bolt pattern with the transfer case. I wouldn't be shocked if you needed a different output shaft for the trans to couple it to the transfer if it does bolt up. You might also compare the Z to the 2WD R50. If they're built similarly, you might be able to find a 2WD to 4WD R50 thread explaining what's needed, though given the rarity of manual VQ R50s, you still might not find one to meet your specific needs.
  14. Interesting. Does the actuator itself look like it comes apart? I opened one of the actuators in mine just to see what was inside and it came apart pretty easily, and wasn't all that complicated inside. I'd be curious to pop the actuator open and see if there's obvious dirt or wear on the contacts and pads that report what position the door is in. If the blend door has spent most of its life in or near the one position, all the wear on the internals will be in that one spot. A faulty sensor could be making it telling it it's more open or closed than it is, so the computer is trying to correct it based on faulty data. I would also want to check that the door isn't hung up on something that's preventing it from closing all the way (making the servo push, realize it's stalling out, back off, try again). I dunno, something to check if the new HVAC control head doesn't sort it out. I'm working on a neighbor's '66 C10, and two of the three climate control levers are busted off. He said he would just reach under the dash a few times a year and set it "for the season." Much easier to do on that truck!
  15. First thing to do is check the injectors and see if they are in fact out of spec again. If they seem okay, you could unplug the computer and check the resistance of the whole circuit to see if there's a wiring issue. EF&EC 120 of the '89 manual has a circuit diagram and list of checks that I assume is the same for '88, I can send you a link to the PDF if you want.
  16. My dad's Allroad has air ride. It's a cool feature. It leaks down overnight, and we haven't found the leak yet, but I'm sure whatever's losing air will be expensive to repair when it finishes dying. I've heard of 4x4s with air-ride, usually in similar terms. Neat party trick until it goes wrong. I won't call bagging an R51 impossible, but it wouldn't be easy, and any fuel savings you might see would absolutely not pay for the parts and the fabrication you'd need to make it work.
  17. That's unhelpful. You may be able to measure the air gap from the outside of the clutch. Set up a piece of flat stock across the clutch hub, measure the gap between that and the clutch disk, then press the disc against the pulley and measure the gap again, and the difference is your air gap. Or, if the clutch isn't recessed into the pulley enough that it's completely shrouded, you could press the disk, measure from the back of the pulley to the front of the clutch with calipers, then release the clutch and measure again. If measuring fractions of a millimeter while holding a clutch down doesn't work out, and it's not obviously dragging or sticking out half an inch past where it should be, I would just send it and see how it goes. If it engages and disengages and doesn't make horrible squealing noises, call it good. If not, adjust as necessary. I had to adjust the aircon clutch on my friend's S10 to get it to quit squealing (brand new compressor that came with the clutch installed, guess they didn't set the gap right) and it didn't take much additional gap to shut it up. Looking at the diagram, a piece of aluminum foil tape over the spacer might do the trick if you find yourself in a similar situation. The service manual suggests engaging and disengaging the clutch about thirty times to break it in.
  18. Wow! Yeah, no surprise that's making it unhappy. The auto climate in the WD21 has a hose off the back of the climate control head unit and a little fan drawing air constantly. The service manual says to check if it's working by holding a lit cigarette in front of the grille, which is next to the buttons and sliders. Speaking of smoking, the PO did, so I'll bet mine looks like yours inside! Something else to check the next time I've got the dash apart.
  19. I've heard that the VG30 heads will fit a VG33 block, but the coolant passages don't match up, so there's some screwing around you have to do to make them work. Easier (and almost certainly better) to use the right heads. I'd be concerned about what else was wrong with an engine with a blown head gasket or that was already stripped to a short block. Your VG30 intake will bolt to the VG33. Use the VG30 intake gasket set. The VG33 exhaust manifold studs are larger, so you'll have to enlarge the holes in your manifolds if you're re-using them. IIRC the oil pan and possibly the pickup tube need either swapping or modification to clear the front diff, depending on what your donor is. Rockclymr's correct on the sprockets. Make sure you get the round-tooth belt to match the round-tooth sprockets. The balancer is the biggest stumbling block to the VG33 swap. The VG33 crank snout is thicker, so your VG30 balancer won't fit. I've heard of people using the VG30 crank and oil pump in the VG33, so they can keep the stock balancer, but that's an awful lot of work just to use inferior parts. Boring out the VG30 balancer leaves it scary thin from what I've read. There was a one-year-only Canada-only factory balancer that would marry the VG33 crank to the VG30 pulleys, but naturally they're unobtanium now. Mr. 510 makes an aluminum ring that replaces the balancer and allows you to bolt the V-belt pulleys to the VG33 crank without modifying anything else. He reckons the engine is fine without the balancer. The other option is to forget about keeping the v-belts and run the engine just like it was in the donor, accessories and all. Xterra/Frontier VG33s have their accessories in the same places and are supposed to fit pretty well. R50 VG33s swapped stuff around, so they'll fight you more, but I think someone on here made it work anyway. I'm not sure whether the later aircon pump will take the WD21 lines, but the alt and the power steering should be pretty easy to set up. If you haven't seen it yet, Mr. 510's VG34 swap thread has a lot of good info for the VG33 swap, even if you're not boring yours out for bigger pistons like he did. He doesn't come around here much anymore but he's active on the NPORA Facebook page (as David Carroll).
  20. There is some variation in actual tire diameter vs what it says on the sidewall, and not just on worn tires. It's also possible the Australian market got a different (locally sourced?) tow bar with slightly different dimensions.
  21. I think DBW started in '03, but Nissan tends to change stuff over mid-year just to be that way. I would assume you're on the right track, and an auto trans engine from the same year with your old intake and the right pilot bearing would do the trick, but I don't know the VQ. Might be some good info here, though that's more between years than auto vs manual. The only other idea I've got is to check the service manual for your year and see how much in the EM section is marked as different for AT vs MT.
  22. Good to hear you got it! Sounds like it was pretty far off.
  23. My '95 didn't idle or shift any differently after I cleaned its throttle body. That was an entirely different computer and a different idle control setup, of course, but I'm still surprised cleaning the TB threw yours off that much. If the vac lines are correct, the throttle body gasket isn't trashed, and the FIC isn't stuck wide open for some reason, maybe someone adjusted yours out of spec to compensate for the dirty throttle body? If that's the case, then it sounds like you're on the right track towards sorting it out. The '97 service manual (I assume '99 is the same) shows a procedure to set the FIC on EC-27, and idle speed/timing/mixture adjustment starting on EC-29. The flashing OD light indicates a trouble code. If it does it again, and you happen to note which flicker is longer, you can decode that using the AT section of the manual. I assume anything that would trigger a code via the old blinky-lights OBD will also set an OBDII code, though, so if you've got an OBDII scanner, just use that. You may have already addressed what it was unhappy about. I very much doubt you messed up the throttle body that much with a Scotchbrite pad.
  24. It would be the PCV that's sending the evaporating kerosene into the intake, but yeah. Should be alright. The risk of doing a flush like this is that the schmoo that comes loose could end up somewhere it shouldn't be, potentially clogging an oil passage. Unless your engine's heavily sludged and your oil filter is bypassing, it should be fine. Years ago I did something similar with ATF, which I was told had more detergents in it than engine oil and would help clean things up. I thought the oil came out a little darker than usual, so it might've done something. EM-33 of the '95 manual says to check the lifter by pressing forcefully with your finger. If the lifter moves more than a millimeter, it's got air in it. This suggests that your lifters not moving when pressed does not indicate a problem. Their recommended fix for a lifter with air in it is to run the engine at 1000 rpm for ten minutes. If that doesn't do it, replace the lifters and then do the 1000 rpm for ten minutes again. The only inspection they show for the lifters is to make sure the outside isn't scuffed or scratched, the OD hasn't worn undersize, and the bore in the head that the lifter slides in hasn't worn oversize. The manual has specs for the lifter, head, and clearance between them.
