345
Yeah, if it hasn't been off in a while, you'll probably need a puller. I think I used a harmonic balancer puller on mine. You could probably cobble something together from nuts and bolts and a piece of square tubing that would do the job. Make sure you've got the nut threaded back on a few turns if you're gonna keep yanking it by hand, or you'll end up wearing the wheel as a hockey mask. Oh, and mark the wheel and shaft with a paint pen if you haven't so it's easier to line it all back up when you're done. My parts car is also a '95, so if the innards are truly borked, let me know and I'll see if I've got better ones.
I was able to get the horn working on my '95 just by cleaning up the contacts. If they're actually wore slap out, though, you may have to get creative. I don't think they're available on their own. What year is yours? I've got a round-dash column sitting in my parts car, and AFAIK the contacts are still good.
Good testing so far! You've tested everything about the injector except whether it's actually spraying fuel. It's electrically OK, and it's trying to work, but I suspect the actual spray nozzle at the tip is clogged up. If it was spraying, I would expect a wet plug (and exhaust that smelled like it was running pig rich, and possibly fuel in the oil as well). Unfortunately I can't think of a way to confirm this that doesn't involve taking the intake apart (or isn't stupid/more work than doing it properly). Might be worth checking for a vacuum leak before tearing it down. I think someone here had a leak from the gasket between the injector and the intake manifold after they'd had the intake apart. It wouldn't hurt to shoot some carb cleaner around there to check, but if you haven't been in there recently, I would be surprised if it had failed on its own. Did the old #4 spark plug look any different from the rest? Passing the compression test tells me the valves are closing. I guess if a valve wasn't opening, or if a port was blocked up with something, it could make compression but not run. But it would take a hell of a chunk of carbon to block up the intake port (unless the engine ate a rag or something), and from what I've read, the cam lobes in these are made from coffin nails and woodpecker lips. And, again, if it was spraying fuel, but not burning it, I would expect a wet plug. I would remove the injectors and check/clean them on the bench. Do your valve cover gaskets at the same time if you haven't--this will also give you a chance to confirm that the valvetrain is OK, though again I doubt that'll be the issue.
VG33 crankshaft timing sprocket stuck
Slartibartfast replied to kd2dhp's topic in 96-2004 R50 Pathfinders
I got lucky with mine, came right off, but I've read they like to rust solid. Looks like some folks manage to fit a jaw puller in there somehow, some drill/tap the sprocket to use a steering wheel puller, and some straight up destroy the old sprocket to get it off and replace it with a new one. I'd be temped to get some heat on it, but that's probably a bad idea with the oil pump right behind it. -
Cool to see it's still around! Man that's a lot of speakers.
Early 90’s OEM alloy wheel paint code (LEGO wheel)
Slartibartfast replied to 415Pathfinder's topic in 90-95 WD21 Pathfinders
I sprayed the caps a lot more than a year ago, and they still look okay. Agreed though that the two-part paint is better, especially for the actual wheels. -
The only time I've seen a dipstick tube play silly buggers with the reading was on the transmission, when I had just filled the transmission through that same tube, and the inside was still coated. Takes a while for the oil to run down so it's not wiping off on the stick and screwing up the reading. I don't know why there'd be oil up inside the dipstick tube otherwise, or why the dipstick would work differently on a modern VQ vs yours. I suspect the dealer's erring on the high side. If I was running 0W20 in a VQ, I might do the same. Doesn't sound like it's hurting anything. But I don't know crap about the R52.
'87 Pathfinder-Rear wiper won't turn off
Slartibartfast replied to Fbanks's topic in 86.5-89 WD21 Pathfinders
Hopefully the new alt doesn't give you an excuse to upgrade for a while! -
That looks pretty close. I think I used a generic "aluminum" spray paint on my center caps years ago, matched good enough for me (or looked better than the yellow plastic I was covering, anyway). -
97 R50 evap and gas lines
Slartibartfast replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
I don't see why not. -
El archivo en mi correo previo tiene todavía funciona. No lo tengo en Español, pero si tiene el sistema de refrigeración (Engine Lubrication & Cooling Systems). Mi Español no es bueno, espero que esto no sea una tontería.
Definitely sounds like your alt is dead. Whether it took the other stuff with it, I have no idea. The regulator is internal. I've never had one fail wide open, or heard of it--I've heard of it happening on an older American pickup, and blowing the bulbs in the dash, but, yeah, no idea what it would do on one of these. I guess if it lost a diode, it might've pumped pulsed DC or even AC into the system, which some components might not have appreciated. Not sure how that would've killed a fuse link, though. FWIW, the 90A alt from a SOHC Maxima bolts right up (just swap the pulley), and when I bought mine, it was actually cheaper than the stock 70A alt. (Yours may have a 60A alt, if it's original.) Same wiring, same belt. I should probably put a thicker charge wire on it one of these days, but so far I've had no trouble with it. The front wiper amp is the brown box hanging off the wiper motor. Low voltage might well explain it not changing speeds, but, yeah, not stopping sounds like a similar fault to your rear amp. I imagine their innards are very similar. Stands to reason whatever killed the rear one, killed the front one too, whether it was the alternator or not. Hopefully the alt was the problem, and a new one makes it stop generating gremlins! -
I imagine this is a job NY shops do a lot. But if you're comfortable bending and flaring lines, I imagine you could pull it off at home as well. Either way, good thinking getting on it before one of the brake lines lets go! -
Going back to junkyard, parts removal tips?
Slartibartfast replied to peejay's topic in 90-95 WD21 Pathfinders
Mice nested in the hood insulation in both of mine, so I just tore it out, with no regard for the push clips or the I-sure-hope-this-isn't-asbestos panels. I would be surprised if the clips came out in good enough shape to reuse--and I'm pretty sure they don't unscrew. I would just cut them rather than risk messing up the hood insulation panel trying to pull them out in one piece. I don't know the hole size offhand, but I'm sure there's a standard push clip that'll work in their place if the originals aren't available. Or, yeah, try it on your bad one first, see if they come out easier than I remember. Yep, just the four nuts holding the bearing to the axle tube, and then the axle should slide out. The service manual shows a slide hammer, but I didn't need it for mine. I would bring one just in case. If you're doing a drum to disk swap, the master cylinder is also different (different prop valve), and the drum rear end has a thrust block between the axle shafts that the disk does not, which I assume will need to come out. Might be easier to grab the whole axle if you're swapping. You do not need to pull out the interior or mess with the nut plates if you're just after the carrier. You only need to remove the bolts holding the hinges on. I would open the carrier, remove the rear-facing bolts, close and latch it, remove the side facing bolts, then unlatch and lift the carrier off the donor, so you're not trying to hold it up and turn bolts at the same time. -
R50 Transmission, what else?
Slartibartfast replied to jjmwilkinson's topic in 96-2004 R50 Pathfinders
What in the AI spam hell?- 13 replies
- rear main seal
- tranny
(and 4 more)
Tagged with:
Sounds like you've got plenty to keep you busy! Where are you seeing that P1140 means water in the fuel? I've never heard of a moisture sensor in a gasoline fuel system. Sounds more like both cam sensors (or their wiring) are out. Try shooting some silicone spray in the rear lock, and work it around. Crap gets in there and they get cranky. Wiggle it, flush it, wiggle it some more. Might get lucky. Or take the inside trim off and see if it's actually the lock that's bound up. My door locks worked a whole lot better after I lubed the linkage they're connected to.
I would keep your old transfer unless you know there's something wrong with it. The later transfer will work if needed, but you may need to swap the lockout plate and shift linkage to make it work right. There's a difference in chain design between early/late transfers, but I have not seen evidence that one is actually stronger than the other.
The ECU does not have a kill function, and the alarm only kills power to the starter, so if it's cranking, it's not that. I have run codes on mine with the engine running and never had an issue, so I doubt it's the position of the pot that's got it upset. IIRC there's just a slot cut in the end of the pot's shaft. So if that's snapped, then there's a chunk of metal knocking around inside the computer, which is not a good thing. If the other side is still there, and you can turn it with pliers, it may be good enough to work with, once you get the loose chunk out of there. If not, you may be able to track down a replacement for the pot itself by dimensions and resistance and solder it in. It may even be marked. Given the symptoms in your other thread, it sounds like you've got no/inadequate fuel pressure. Get that chunk of metal out of the computer before it shorts something, then chase the fuel system. Hopefully the new relay does it. If not, I would unplug the pump and put power to it directly (lawnmower battery or something), and see if that gets it running. If it does, chase the wiring. If it doesn't, chase the pump.
TBI Issues, please help!!!
Slartibartfast replied to Josh_Path2346's topic in 86.5-89 WD21 Pathfinders
Good, sounds like you know what you're working with. Too bad the computer has no idea what's up, but yeah, that's pretty typical for old EFI. There are a few designs on Youtube for homemade smoke machines. The cheapest I've seen was a hand-operated transfer pump with a gas station cigar stuck in the intake. The ones I've been looking at have a can or a jar with baby oil, a soldering iron, and a low-pressure air feed, which AFAIK is pretty close to how the proper ones work. Without a smoke machine, you can hold a length of hose to your ear and poke the other end around the running engine, and maybe home on the noise that way. You can also shoot carb cleaner at where you think the leak is and see if the idle picks up from the engine sucking in fuel, but I've never had much luck with that method. -
I haven't worked with the TBI, but I've read that they tend to run poorly when the air cleaner is off. I guess it smooths airflow over the MAF or something. Wouldn't explain the RPM dropping at the car wash, but if you're testing it with the air cleaner off, throw it on and see if it clears up any. Idling low at the car wash makes me suspect something got wet. If it was shaky, I'd be looking at ignition components (wires/cap/rotor). Otherwise, could be electrical. IMO your best bet at this point would be hooking it up to a smoke machine. That should find your vacuum leak pretty quick. Could be a rolled O ring, throttle shaft seals (the instructions you linked say not to dunk those in cleaner, not sure why not), something along those lines. I would also check that the brake booster, PCV, and EGR (if that's still around) are in good shape, in case it's not the throttle body that's acting up. I don't have a source for the '88 service manual, but on the off chance you haven't found it already, here's the '89. EF&EC section might help you track it down, or at least understand how the system is supposed to work, which might point you in the right direction. '87 had a different code table and some other weirdness, so if yours is closer to '87 than '89, and the codes you pull don't make sense (44 was "no malfunction" on the '87 ECU, replaced by 55 on later years), let me know and I'll dig out my paper copy of the '87. -
Looks like around '97-'03 for the Fronty, '99-'04 for the X. If it's got the 3.3, that's the one you're after. If it's got the supercharged 3.3, that one's supposed to be built a little tougher, but IIRC the torque converter and flexplate are different from the non-super'd ones, so make sure you get those with it. Again, it may be possible to make the 2WD variant work, but I'd expect it to turn into a bit of a science project.
Maybe? I imagine you'd have to open up both transmissions and swap over the output shaft, but I haven't had either unit apart myself. The usual replacement is a first-gen Xterra or Frontier trans. The design was revised a little and is supposed to be better/stronger than the original WD21 trans. No idea how either version compares to the 300ZX trans.
97 r50 no start security system
Slartibartfast replied to hunter1919's topic in 96-2004 R50 Pathfinders
If it's like the switch in my WD21, the hood switch is open (wires not joined) when the hood is shut, closed (wires joined) when open. I wired mine to an under-hood light when I deleted the alarm. -
For the door, this thread or this one might help you get it open. Looks like it might just need a little lube in the right spot. Get that sorted out, make sure the locks work, then see if the alarm's still upset. Might just be confused if it thinks the door's half closed or something, though I wouldn't expect that to explain the no-start. Unfortunately I don't think the security system on the R50s is removable. Built into the smart entry whatsit IIRC. -
Well that ain't good. I don't know which computers will work, sorry.
