NissanNismoZ
Everything posted by NissanNismoZ
  1. Yep..its practically leaking out as soon as i put it to it..also, when its installed on the truck it makes a purring noise anyway...ill probably just cap it since it doesnt do anything but steal my air power.
  2. Also, when its driving RIGHT i have brakes..when the EGR is acting up it idles so low i barely have brakes...
  3. So it's safe to remove? because i spray carb cleaner through it and you can see it 'radiating' through the inside of it..it also doesnt hold vacuum when applied?
  4. I had this SAME problem. The reason being is because you have to use the guts of your old one. A golden piece slides in the inside from behind, and a golden washer goes in front while a cap piece goes on the outside. Hope this helps! I
  5. Quite a lot actually.. Put on new tensioner and new belt for A/C Recharged A/C Put the skid plate back on after repainting. Installed new EGR valve (new to me, anyway.) Removed new EGR valve for cleaning. It's been a long day, but it's getting to where it needs to be, and the heat has been extreme lately so i thought i should go ahead and get the A/C going again...
  6. And i definitely appreciate it! So today i went to the junkyard..got a EGR valve off a 95 LE. Tada! Drives even BETTER than it has been! it still idles low as crap..but i dont know what to do about that. Anyway, it treated me good until around 30m driving..i stop and get a drink and get back in..and bleeeehhhhh. I instinctively get out, pump the EGR and tada! good as new. Why do i have such bad luck with these?! I stuck the EGR in a tiny bowl nearly full of carb cleaner (it covers the in and out ports) and im going to let it sit overnight. I will say this EGR actually moves up and down smoothly compared to my old one. I'm starting to question the EGR-BPT valve..what does it do and how does it affect the running? I've seen some pathy's without them..
  7. You know..I can't seem to replicate the problem.. no matter how I drive it it just won't do it again. I mean it shifts into every gear quickly.. I'm going to try letting the EGR sit over night in Carb cleaner tomorrow (have to borrow a friends HUGE channel locks to get that pipe off) and ill see if that fixes the EGR. But the TPS was NOT really adjusted. It seems like it needs it but I never could find the page in the FSM. Thanks TownCivilian for the very specific information. I currently don't own a torque wrench so ill wait before I do a pan drop. Thanks everyone! Ill try adjusting the TPS and seeing if that helps. All I did was change it out and put the new one in the screw 'marks' Also..what type of transmission fluid is best for these? Thanks! Circuitry.. UGH that's right! Can anyone tell me what that loom that's on the passenger side valve cover goes to that leads to the tranny?? I forgot to loom it back and it melted against the exhaust (in under 15 minutes of idling) it killed my Meter fuse and left the gauges dead with a very very faint battery light on the dash. I still haven't repaired it as I forgot all about it.
  8. Honestly I haven't maintained it.. yet. It was on the list of todo when I get a chance but never got around to it.. The E-AT light only blinks at startup then stays off unless I turn it on. I do remember the switch was on auto and when the truck had ZERO power the light came on and stayed on and it drove like I had the switch to on. I guess it thought I was towing something? This is with overdrive on (with the light not on on the dash) I don't know how to tell if its the torque converter or not..I just know its usually when I want it to downshift from the torque converter being locked.
  9. Ugh..if it isn't one thing, its another. I've noticed (I still have the huge power loss from the EGR being screwed up) I have to push it a little harder before hitting a hill..it unlocks the torque converter then ill push harder and it'll slip, ill let off some then it'll shift back into gear..I will say my reverse works great..so I don't think the tranny is shot...yet.. But what could this be..? I checked the fluid and its normal..and I noticed a few air bubbles on the stick .. I've put so much into the Pathy for the tranny to fail now..
  10. Of course this should be followed up with test results of both Short and long term.. All in all you really couldn't ask for a more descriptive write-up. Now we just need to know how well this is going to work and how long..
  11. Also..check to make sure your EGR valve is working properly and not sticking.. mine started doing this then it got to the point to where it wouldnt want to accelerate at all!
  12. Hmm..alright. Thanks guys! Ill probably go with the 3M if it isn't too expensive
  13. Not a problem! You really can't tell it! Will do, it'll probably be seafoamed as much as possible! Muahaha.
  14. Thanks! Have to say i'm loving how your Pathy has come along.. It looks mean!! I've ran Seafoam through it once..but that was a year ago..i'll probably run some through it again since the lower intake i put on it didnt look as clean as the one i had.. I can say that after all this i'm a pro at removing and re assembling the upper and lower intakes. Though im pretty sure i dont want to touch that territory again for a WHILE. I'll try that..Thanks!!
  15. It's amazing what a dirty EGR valve can do...
    1. Tungsten
      Tungsten
      It's amazing what no EGR valve can do. :) You should be fine if you run a BPT valve though.
    2. NissanNismoZ
      NissanNismoZ
      I would run no EGR if i could disable the code for it. what does the BPT valve do anyway?
    3. Tungsten
      Tungsten
      Reduces the EGR operation significantly. The engine doesn't suck in more than it needs for cleaner emissions.
  16. Wow..yeah I do mean the little butterfly plate. Mine is probably due for a cleaning, no doubt.. Oh trust me..if i were going to give up, i would have taken the offer to trade it to the 98 Frontier...but nah. I have too much time into pathy to just..trade it. I will say this morning i cleaned the EGR to the best of my ability and it definitely drives like it used to. I can actually pass people up hills, an d it has REAL throttle response! My guess is since my timing is so advanced (all the way) its causing it to be still a little sluggish, but honestly im scared to retard it back to where it was... Oh yeah, trust me. I'm a proud Pathy owner. Haha! That's true! And it's still better looking than any Jeep or Toyota while its running bad!
  17. Hmmm..not sure if you mean the throttle body or the intake Plenum..I once cleaned my throttle plate n all around it with Carb cleaner but that's about it..
  18. I mean seal wise..maybe one is leaking down past the Injector..though it is possible the injector is sticking open but usually you'd see a code. Maybe start by checking resistance on all injectors and see if you can find an odd one out?
  19. What about the sensor? Won't it throw a code? And what about the egr bpt beside it?
  20. Nope. Only sometimes now..but how can I do an egr delete? I don't know what ports to block off
  21. Well.. I couldn't clean it all the way as my big.wrench was forgotten at my friends house, but I removed the two bolts holding itnto the intake and sprayed the crap out of it with Carb cleaner and kept pumping the little speaker like thing on the bottom. Then I did the same for the vacuum port on top of it. Put it all back together and TADA! It now spins out in gravels and accelerates up my.hill.again! It still bogs some at WOT but I didn't get the chance to clean it thoroughly yet. But it DEFINITELY has 80% more bottom.end than it.did! ! Lets see how it.does when I finish it up tonight.
  22. How would I go about cleaning it? I'm not really sure how to go about it..
  23. So how is it the ecu knows the egr is messed up.when I see no.connector?
  24. Yes, yes you did but I mistook the egr for the egr-bpt..
