Everything posted by Nytrosfinder
looks like someone took an ARB bumper and the front grill assembly of an xterra- combined them- and painted it white and added some lights... I wouldnt do it... I would have to modify it and then rhino line it before i even considered putting it on my car!
2005-2009 Pathfinders, Xterras, and Frontiers reason: Crash zone sensor- Airbag activation Sensor http://www.autoblog.com/2009/01/07/nissan-...s-and-frontier/ 1997-2001 Pathfinders, Infinity Qx4 Reason: Insufficient coating on Fuel filler tube http://www.autoblog.com/2007/10/07/nissan-...-infiniti-qx4s/ Just so everyone knows!
HOLY SH*T! THAT THING MAKES A NISSAN PATROL LOOK LIKE CRAP!.... (ok maybe not) BUT ITS SURE CLOSE!
Making a mix CD for a friend but: Whatever you like- T.I. Blame it- Jamie FOxx Heartless- Kanye West as of right now
can we see some pictures? Use Phototbucket.com or some other site so we can see alot of them!
something to think about later on i suppose....
I had to put myself on the line...
Here is where Kingman got his line from:
No mullet... heck no! I am only 18 and still trying to find a girl... Mullet= Repelant!
yeah man!
I got a body lift on mine... no problems at all....The one problem i had was shifting down in to 4x4 Low... the floor gets in the way... so the previous owner (who installed the BL) cut a small portion of the floor out.... only like 3" though... not that big of a deal...
Now thats funny!
Nascar is the stuff... dont hate cause you have an interest in something lets call... not entertaining....
Not sure what tony Stuarts number is but if he is one you listed then he can suck on my left nut and then burn to death! I fricken hate that guy!
Are you watching it? Rain delay mess today!
For those of you who have done the Calmini Lift...
Nytrosfinder replied to Nytrosfinder's topic in 86.5-89 WD21 Pathfinders
Sounds like a plan! I am planning on doing that to mine as well... -
Just save your cash and lift it the right way... Plus you will have new fittings and everything up front when your done... -
I personally say... work from you header back... Header -> 1.78 to 2.5" adapter -> 6" straight pipe -> cat -> thrush turbo Muffler ->down pipe I have been planning to do that for a while...
If you can get some pictures loaded up... I will let you know if I can help you out....
If you do the whole kit then it will... I belive it's 3" or 3.5".... Not sure... -
you will probably spend as much for new ones from jeep as the ones are from calmini are give or take some -
Rusty body mount/Front bumper removal issues
Nytrosfinder replied to jitterymonkey's topic in The Garage
I would at least recommend getting a can of PB Blaster or PB'laster (whichever way it's written) So you don't break nuts and bolts... I say use a come-along and a tree don't use the power of your ride to pull it out cause you might rip something out! Then make sure when you have pulled it out... Make sure you pull it out about 1/4-1/2" out farther cause the elasticity of the metal will pull back and then it won't line up.... Got that tip from a chassis repair guy at a shop... -
I do not believe anyone has any info on this in terms of a source. I know cause I got the same problem. Bust bet is to either get some sheet metal and DIY. Or cut a panel from another car. Do you have a 2 door or a 4 door? I might be able to get rocker panels from you from my local yard. Cause here In the south there is very little salt so hardly any rust!
Calmini is gonna be better (I think) cause its a full kit and your replacing the parts that have gotten weak with time. Where is all your doing with Cranking the aged T-bars and swapping aged springs with aged springs.... Plus once you go get your car aligned they generally crank the T-bars down....
