Mookie
Everything posted by Mookie
  1. Yes, never, ever, ever, ever add that figure up.
  2. It's a money pit...it all adds up, and adds up and adds up. What you think it's going to cost, will end up triple or more. You need to do alot of research, or have some buddys that can help you out. You don't want to compromise saftey anywhere in a project like that. Ya gotta love your Pathy or it's better to find another vehicle with a solid axle or a 4runner that you can SAS because of the kits/parts readily available for them. However, the Calmini kit will be out soon so that's good news. It requires a ton of your time and is highly distracting to whatever else you are doing. Plus you're out of a vehicle if you don't have another one. Then you have to de-bug it...a litte more money spent here and there. But I'm extremely happy with mine. I'm glad I did it. I spent a year collecting parts, but I would probably spend more time to find better deals to save money. Taking your time is the key. I spent approx. 3K Cdn on parts alone. (what's that, about 1500.00 Us? Lol )I also swapped out the rear diff which adds to the cost, but still was cheaper to re-gear and get a locker for it than re-gearing and paying for Nissan Gears. Most of the parts were used. In fact anything I could get used, I got. Then if needed, I rebuilt the diffs with new bearings, seals, etc. Gears, carriers, new inner seals and install for the gears cost 1400.00cdn because I had them done with the diffs on the Pathy. Much, much cheaper to take the diffs in before hand to get set up. Would have been about 3/4 the cost. Drive shafts were also pricey items. Tires and wheels, used. Shocks, breaklines, drag link were all new. Steering box (Scout II Saginaw box), leaf springs front and rear were used. I only paid like 60.00 for the springs total. The bushings for them cost more than that! I payed to have it welded so add $$ on top of it. The coil Pathyn in the picture is probably around 4K in parts which includes the custom out sourced work. He had a pitman arm custom made while I used a Jeep pitman arm. My steering components were also cheaper as I used Chevy off the shelf components. That also includes new rims and tires. You can do it much cheaper, it just depends on what you want. If you can find diffs with the gearing you want, then that's a huge savings right there. Don't go high, and your driveshaft costs are cheaper. Cross members can be a pain to do too. I have one more I'm going to add. Leafs are easier to setup. Coils are very nice, but require more time to get things to fit because of the nature of the setup.
  3. S'cuse the multiple posts (to lazy today to organize and put in one post ) No video. But will have some hopefully this spring. (perhaps the tax return will be enough) Almost have to do a run specifically for pictures and video. Or at least have someone in the group dedicated to shoot vid and pics.
  4. Thanks for the link. Yes, that's on the to do list! Probably within the next few months or so. I love those EB's.
  5. Just finished another Sas'd Pathy. This one is using Ford Radius arms, and a Grand Waggy Dana44. Still some de-bugging, but the major part is done. We worked on it for the month of January (4 full days and 10 evenings). Now I can get back to working on mine again
  6. This is probably what it is. Another one of those "common Pathy problems" Rears it's ugly head when it gets colder. You won't notice it to much in the warmer weather. As Brian said, just tighten the hose clamps. If this isn't it, on the old forum, there is some threads about the sending unit.
  7. I did that with those cheapo blue bulbs. They only lasted a few months before they faded out and I'm back to white. :o LED's are the way to go. Look good.
  8. Yes, I wasn't in a very good mood after my first time changing out that 6th plug. It was alot easier when the 3" body lift was in. Now that I've removed it, looks like I'll be back to swearing again.
  9. When I was stock with 235's, I used to be able to get just over 400kms on a tank. Now, I don't even care as I'd just depress myself. The common range is usually around 16/18, but lots say 19/20 - give or take a few kms.
  10. These auto/overdrive Nissan Trannys aren't the best at overdrive I've noticed. When I was in stock form, I would get constant shifting in and out of overdrive on the highway on level ground with no headwinds. I could rarely use it. I've read that a few people experience that the Frontiers/Xterras overdrive won't work well until they are warmed up. Maybe the newer Pathys are the same? Jim has newer Pathy too, maybe he's noticed something.
  11. Good points. I helped replaced a passenger side cv shaft. The outter spline count was off by 1 spline. The parts store told us we were assembling it wrong when we called them to see if they had another listing. We brought in the old one and the one they sold us and had them count the splines. Ended up going elsewhere where they used a paper manual to cross reference. If it's not in the computer, then it must not exist!
  12. Mookie
    New Engine
    If you want to use your balancer, you can get a space direct from Nissan.
  13. Great write up! I guess if one had a spring compressor handy, it would probably help out eh? It looks like you don't need one for the install, just that it might make things easier?
  14. Yes, start with making sure your brake fluid is topped off. If it's coming on during corners, this seems to make sense. Let us know how it turns out.
