All Activity
- Yesterday
I have a 2001 3.5 4x4 MT. The rear motor mount/transmission mount are moving a ton and I think is the reason I have a clunk when I change gears. Part numbers that I found are: 113201W200 113754W000 I cannot find them anywhere, what aftermarket have you used that will work for me? Any part numbers? I also cannot use rock auto since I’m in AZ. Thanks for your help!
Crank and new main bearings in the big Z24 over the weekend, main bearing clearances and thrust all measured up great. Pistons, rings and new clutch turned up last night I just need to get the pistons pressed on and then I am ready to assemble. Can't wait to have my old girl going again! - Last week
Sunroof cover decided it was done
Yeah I concur. Gotta wait a bit for it to warm up some, no shop anymore. Will probably just rhino-line the entire thing at that point. But...I am also considering deleting the two rear side windows so might do that as well. While the forum was down this one dude kept posting things he was doing to his WD21 (I think he is sponsored by Rival Offroad maybe?) and did the same, put some flip up truck camper top type covers in there and had storage space accessible from the outside. Not sure why, but it crossed my mind. -
Front crankshaft seal installation
Well, tore it down and put it back together with a new pump. The "new" one I put in was leaking pretty bad, guess the seal was bad from the get go. All is well now. Thank you for all the input gents! -
Plenty of info on TD27s on the Aussie facebook groups, a lot of us are TD nuts, they will be able to give you all the measurements and info you might need. There is a group 'TD27 Torque' which will have plenty of help.
Please welcome adamzan as an NPORA Forum Moderator
FirstGenFreak replied to RedPath88's topic in NPORA Announcements
Superstar. Great to have the extra support. Huzzahhh! -
fleurys replied to RedPath88's topic in NPORA Announcements
yep ! that's a good guy ! happy that the forum is back online... facebook groups are just not my thing when you search things ! way to go adam -
That sounds more like sommething external to the motor. Do what @Slartibartfast said, if that isn't it, these trucks were kind of known for the harmonic balancer separating (it's a 2 piece press fit rubber thing IIRC). I would check that out as well. My parents 2000 R50 with the VG33E had this happen, twice. The first time, the dealer replaced a ton of parts before finding it. An easy way to check rod knock is to loosen all the plug wires at the distributor and then while the truck is running, remove one at a time and see if any make the knock go away or less pronounced. Good luck and keep us posted. For what it's worth, of all the Nissan vehicles I've had with the VG engine, I only ever had one with a rod knock and it was severely overheated several times/ran without coolant.
adamzan replied to RedPath88's topic in NPORA Announcements
Thanks! Glad to help out. -
He has been an NPORA member for nearly 20 years and a regular the whole time. Recently he worked with us in the background to get the forum back online, root out problematic DDoS sources and test for reliability. And now adamzan has agreed to join the Mod Team. Welcome adamzan!
I had a weird clatter turn out to be the front bearing in the alt giving out. Remove the accessory drive belts, run it, see if the noise goes away. If you do them one at a time you'll know which one is noisy. I would also give the water pump a spin, see if there's anything obviously wrong there. Given the front-end wreck, I'd also check that the fan shroud is held on properly, and the fan isn't making contact with it. Long shot, but worth checking. If it still makes the noise with all the belts off, might be worth pulling the timing covers to check the belt tension and the condition of the idler pulley. IIRC the keyway only locates the sprocket during assembly, and it's clamped in place by the crank bolt. So unless the crank bolt is loose, it shouldn't be able to rattle.
My '98 Pathfinder has recently started making an alarming sounding racket, from the lower end of the engine. As the title suggests, my thoughts go towards worst case scenario and say its a rod knock in its early stages. I've recorded a video of it, which is the worse the noise has been so far, and iirc the engine was at full operating temp. It's not quite as loud or deep as bad rod knock is, but that's why I say it could be in the early stages. It could be attributed to piston slap, but as far as I know, that sound would go away when it warms up, plus this sound has been happening for maybe 3 weeks now, as opposed to the 3 years that I've owned it. The youtube channel 'Auto can' has a series of videos diagnosing a vg33e knocking sound, and it turned out to be the keyways on the timing belt sprocket and crankshaft being very deformed, allowing the key to rattle around when running. I don't know if I'd rather have that than rod knock but it could be that as well considering how relatively quiet the noise is? One additional thought I had about this was that according to the maintenance records I have, the timing belt was done at 103k miles, and it now stands at 170k miles. Technically less than Nissan says to replace the belt, but not out of the possibility it needs replacing and could be contributing to the noise, right? I should also mention that I went on a quick drive before posting this, getting it to operating temp for around 15 minutes. Neither when it was idling cold nor after the drive did the noise come up, it sounded just as it did before the concern arose. I don't know what that means but probably good to know. This car was very nicely garage kept and maintained for most of it's life before I had it, and while sadly it did experience a decently big front end collision (that didn't immediately affect any mechanical components), I have been very on top of oil changes and other maintenance items, so it's very frustrating to see the engine potentially going to crap, especially so long before 200k miles.
Mine done the same and is fixable.
- Earlier
That same guy has the username "Nefarious" on here. He hasn't been on in a while but maybe PM him and it'll email him to remind that npora still exists lol.
Alternative Factory Nissan Rims for 97 Pathfinder
AR97Pathfinder replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
So i found these rims of an 03 Pathfinder SE: https://imgur.com/a/YkOPJK2 Door jam says 255/65/r16. Unfortunately, I'm getting 1 tire option when searching online. Is it safe and okay to install 255/70/r16 tires on these rims wihtout issue for my 1997 Pathfinder SE? Vehicle is on a 1 inch spacer lift. Thank you. -
It's still working great!
Thank you! I'll try to find a set of those. Most places I'm calling either don't have them or don't have the full set. So essentially any of those vehicles up to 2004? Also including the supercharged Frontiers? -
adamzan replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
Any first gen Pathfinder, hard body, Xterra, or frontier wheels will fit. Supercharged Xterras came with 17" wheels. Probably not hard to find a set of those. The 2nd gen Xterra/frontier like slart said have a different bolt pattern and won't fit. Many aftermarket Chevy wheels will also fit. Be careful with Toyota wheels, you'll likely need different lug nuts for those. -
Slartibartfast replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
Those look like a smaller lug pattern. Looks like the D40 Fronty went to 6 on 4.5" rather than 6 on 5.5". I would assume the D22 Fronty wheels would fit the lugs, but I don't know what they had as far as diameters and offsets and whatnot. -
Good evening everyone! I am looking for a set of rims for my 97 Pathfinder SE. It has the stock 15 inch rims, however, there are not too many options for tires and I'm looking for a set from either frontiers or later model Pathfinders. I know for sure that the 17 inch rims from the 2004 Pathfinders will fit, but will 16 inch Frontier rims fit without any issues? Do these rims have the same bore size as the factory 15 inch rims I have? I do have manual locking hubs on my Pathfinder. Are there any other options that will fit my vehicle? I have seen some 4Runner rims on these trucks too. Here is a link to the picture of the rims I am currently looking at. https://imgur.com/a/0rT48Tm Thank you
How-To: R50 Rear Disc Brake Conversion
Strato_54 replied to hawairish's topic in 96-2004 R50 Pathfinders
I’ll add to that. Bee running rear disc on my 97 for almost a year and they’re absolutely amazing -
Finally ordered the last of the engine parts today, time flies and I miss driving this thing more than I thought I would. I went camping over the Xmas break in my D22, it felt like such a betrayal after all these years! -
It wouldn't be too hard to delete the sunroof, weld some sheet metal in and finish it off with short strand fiberglass/body filter, then paint. My friend did it on his R32 Golf track car.
That id a good idea, I need paint as well.
