10
Everything posted by Terranovation
Optional Oem add-ons and upgrades
Terranovation replied to Cuong Nguyen's topic in 90-95 WD21 Pathfinders
I believe there were supports either side of the rear speakers that were for a rear cargo cover. It was a fibre board jobby covered in black felt that had a crease line with holes that lined up with those two bolts in the back of the rear seats so you could fold it up when storing stuff. I would say most people have likely removed them because they were a pain and have them stored away/thrown out/used on a camp fire lol. Would be a good diy project though. -
Maybe with age it slowly rotted and ripped away from wind, vibrations etc.
Terranovation replied to RedRider3141's topic in The Garage
At least you have an owners manual! I wouldn't mind having a copy of that. -
I found a yellow invoice in Japanese hidden under the center console. I can't understand it but looks like a leftover transmission ticket they put on the assembly line. Also found a white ticket well hidden inside the sun visor pocket. Also in Japanese, I found someone who knows the language and they said it was a parking card for a car park. -
Probably a twig or leaves in the fan squirrel cage
You might find money too -
Pulled the front seats out and scrubbed them with some washing liquid and warm water, then hit them with the pressure sprayer. So much brown crap came off hidden in the fabric from the last 25 years of use. While the seats were out I vacuumed the carpet where I found $2 hidden under a flap in the carpet! Let the seats dry off all day in the sun and bolted them back in. The seat bottoms are still wet amazingly so I threw a towel in there for now but it's nice to have dirt free and nice smelling seats. -
Over Done
Over Drive
I would say if the vehicle was built without a check engine light then it's ok to pass inspection. Sure if it's got a check engine light and the bulb is faulty then that's an issue. In the future are they gonna not pass our vehicles just because they don't have HID lights? If they did then that would be pretty stupid. At the least, all vehicles should have an operating park brake light, battery warning light and brake warning light. Those 3 are major warning lights that shouldn't be ignored.
Run Fast
Out Run (one of my favourite arcade games of the late 80s!)
Toss out
1995 Nissan Pathfinder 4wd never ending tapping noise.
Terranovation replied to Merzed62's topic in 90-95 WD21 Pathfinders
I would be really careful running diesel fuel in the oil. I was talking to a diesel mechanic and he said flushing a motor with diesel requires two people. After the engine is switched off, the properties in the diesel will cause 'run on' and the engine will not cut out and will redline if a second person doesn't block off the air intake with an old towel. It's a dangerous thing to do unless you know what you are doing. -
Peg board
New Guy Seeks Your Wisdom (Same Old!)
Terranovation replied to Fast_eddy's topic in 90-95 WD21 Pathfinders
The interior looks brand new still, no melted vents either, unless those are ebay ones! I got mine from ebay a few years back, all three for $50. -
I remembered I had some sheep wool buffing pads in the shed but don't have the disc that goes onto them so I decided to make my own. Had some quarter inch mdf board laying around so I measured the disc size so the pad will fit over it nicely. Cut the round shape for the disc, drilled a hole in the center for a flat head bolt to fit through, fit a washer on that with a nut tightened really well on the other side. Slip the buffing pad over the disc and it fits my drill. Can't wait to try it out. -
Have you seen the guts of an auto trans before? The atf keeps them pretty spotless inside. -
Bionic leg
Try running some ATF in the oil for the next oil change. Put a quart in with the old oil, run it on idle for 10 - 15 mins then drain. The atf should get rid of the lifter tap. -
It should have come with the car seat. If you don't have one go to a car accessories store and they should have them.
Pretty maid
No I wouldn't go removing the anchor point on the rear floor. If you store things in the back there's too much danger of things that can knock the strap loose. It's better attached to the rear of the seat so the strap is off the floor and out of the way of other objects. Photos tomorrow.
You have to unbolt the rear bolt on the back of the seat in the cargo area, then thread in the clip that connects the kid seat to there. To get the strap to fit snug you remove the head rest, then place the strap over pulling it tight then replace the head rest on top of the strap. I can put photos if you want.
