unccpathfinder Posted May 4, 2006 Share Posted May 4, 2006 I've always been kind of intreaged by the ground clearance the humvee's had around bragg and they run 4WIS and don't seem to get stuck a whole lot...the only problem i've seen with them is they aren't locked so they can sometimes get the wheel spin where its not desired which i think that can be fixed... i also know that the drivetrain is a lil crazy if i recall the way run is the driveshafts come in on the top side and drives a gear or on the acutal wheel or something to that effect so the transmission actually has 4 reverse gears and 1 forwards gear (if u referenced it to a normal tranny)...which i think this would pose the biggest problem but i think it could be worked around in a normal truck just not have as much ground clearance b/c the hogheads would be lower by about 6-9 ins so i was kind of wondering if any1 had tried to build an IRS for our trucks and if so would it be worth it and/or give you advantages over SAS i think that it'd be interesting Link to comment Share on other sites More sharing options...
FLApathy Posted May 4, 2006 Share Posted May 4, 2006 (edited) hummers arent made to crawl (if i had a hummer it wouldnt be for crawling), they are made for 'explorering' and trailriding, just look at how freakin big they are, jeeps would do better crawling then a hummer (assumeing both are stock) making IRS for our rigs IMO isnt worth the time and money and yeah hummers have cvs that come in off center of the hub enabling it to run coils and having more gear reduction at the wheels and i dont ever remember seeing a pic of a hummer flexing but i dont think they do it very good Edited May 4, 2006 by FLApathy Link to comment Share on other sites More sharing options...
Filthy Luker Posted May 4, 2006 Share Posted May 4, 2006 Hummers run portal hubs on independent suspension all round. Solid axles are much cheaper and flex much better than any IFS/IRS setup. Also solid axles are much more dependable due to less moving components. The only thing better than a straight forward solid axle is a portal gear solid axle. You see Hummers aren't really designed for off roading. They're designed to carry troops and gear over rough terrain and ripped apart roads. Just to give you an idea... a Unimog (Portal Solid Axles) would not only crawl over the hole that a Hummer was stuck in, it would crawl over the Hummer itself. Link to comment Share on other sites More sharing options...
Duffman Posted May 4, 2006 Share Posted May 4, 2006 Did someone say mog? Link to comment Share on other sites More sharing options...
Slick Posted May 4, 2006 Share Posted May 4, 2006 *pricks ears up* i heard, hole,s tuck, crawl and mog...... this could get interesting -study- Link to comment Share on other sites More sharing options...
vengeful Posted May 4, 2006 Share Posted May 4, 2006 I must've heard differently. I heard SMOG. Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 4, 2006 Share Posted May 4, 2006 Not to mention that portal axles weigh well over 1000 lbs each, complete. Can you imagine more than a ton of weight just in two axles under a Nissan? Wow. Link to comment Share on other sites More sharing options...
vengeful Posted May 4, 2006 Share Posted May 4, 2006 Would make off-camber situations slightly less harrowing though.... Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted May 4, 2006 Share Posted May 4, 2006 Just to give you an idea... a Unimog (Portal Solid Axles) would not only crawl over the hole that a Hummer was stuck in, it would crawl over the Hummer itself. So true. Well said. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted May 4, 2006 Share Posted May 4, 2006 The new Pathy is 4WIS too isn't it? Link to comment Share on other sites More sharing options...
Mr. Pickles Posted May 4, 2006 Share Posted May 4, 2006 The new Pathy is 4WIS too isn't it? Not exactly a Humvee though, and not exactly cheap. Link to comment Share on other sites More sharing options...
tmorgan4 Posted May 4, 2006 Share Posted May 4, 2006 This shows the flex (or lack of) but capability as well. :bow: Link to comment Share on other sites More sharing options...
Filthy Luker Posted May 4, 2006 Share Posted May 4, 2006 Not to mention that portal axles weigh well over 1000 lbs each, complete. Can you imagine more than a ton of weight just in two axles under a Nissan? Wow. There are some portal axles that are much lighter though. G-Class Mercedes and smaller mogs would have them, here's what one of the guys I know is doing: http://www.pirate4x4.com/forum/showthread.php?t=450288 (It pains me to look at that thread cause I was offered one of those mogs for sale for CHEAP but lack of room to keep a glorified farm tractor for extended periods of time prevented me from doing so) Link to comment Share on other sites More sharing options...
tmorgan4 Posted May 4, 2006 Share Posted May 4, 2006 That guys using Pathfinder calipers. Link to comment Share on other sites More sharing options...
unccpathfinder Posted May 4, 2006 Author Share Posted May 4, 2006 Not to mention that portal axles weigh well over 1000 lbs each, complete. Can you imagine more than a ton of weight just in two axles under a Nissan? Wow. well i'd def think u'd have to drop in a huge desiel if it'd fit humvees are tough tho...my buddies dad's got dropped from like 200ft from a chinook when a cable broke loose and the idiot piolot cut it loose when it was top down instead of wheels down but the next day they had a new top on it and were riding again just always thought they were cool runnin on those huge superswampers with the 15ft ham radio antenna and like a foot or 2 of ground clearance Link to comment Share on other sites More sharing options...
94extreme Posted May 4, 2006 Share Posted May 4, 2006 you sure hummers aren't locked? maybe the ones i have seen were modded but i am sure those were locked; either that or they have some low, low gearing. Link to comment Share on other sites More sharing options...
k9sar Posted May 4, 2006 Share Posted May 4, 2006 all this talk about hummers....... nah.. nevermind. I decided not to comment. Link to comment Share on other sites More sharing options...
94extreme Posted May 4, 2006 Share Posted May 4, 2006 ok i'll do it. hehehe Link to comment Share on other sites More sharing options...
Filthy Luker Posted May 4, 2006 Share Posted May 4, 2006 Actually I find that Hummers no longer do it for me ever since I discovered the VBL: VBL is a 4 ton class 4x4 armored vehicle offered in short or long versions, offered in various configurations including infantry carrier, scout, intelligence and EW, liaison, security, command, anti-tank and anti-aircraft roles. Over 2,400 are operational or on order with 15 world armies. The vehicle offers high mobility on land, and has full amphibious capability. It is also deployable on helicopters and transport aircraft, such as C-160 and C-130. The VBL has an integral steel armored hull, providing protection against 7.62mm and fragmentation, and anti-personnel mines. It has a payload of 1 ton, including crew and armament. Link to comment Share on other sites More sharing options...
94extreme Posted May 4, 2006 Share Posted May 4, 2006 ^^^ now we're talking. too bad it doesn't have 3 axles though. Link to comment Share on other sites More sharing options...
Duffman Posted May 4, 2006 Share Posted May 4, 2006 What powers that beast? Link to comment Share on other sites More sharing options...
Filthy Luker Posted May 4, 2006 Share Posted May 4, 2006 (edited) http://en.wikipedia.org/wiki/VBL Peugeot XD3T turbo-diesel: 2498cc diesel engine with 108 hp (79 kW) with a turbocharger, intercooler, and electronic fuel injection was introduced in 1987. Edited May 4, 2006 by Filthy Luker Link to comment Share on other sites More sharing options...
unccpathfinder Posted May 4, 2006 Author Share Posted May 4, 2006 no im not sure they're not locked but i've seen some pix where the least loaded tires were just spinning... i've always wanted a deuce and a half as well...theres a big 1 down on the coast that he drives out there and tows out stuck folks and that thing is awsome i've heard they're great in sand/mud but horrible in the snow Link to comment Share on other sites More sharing options...
snosnk Posted May 6, 2006 Share Posted May 6, 2006 What about wheelin one of these. Link to comment Share on other sites More sharing options...
